Question about Breville Die Cast 800ESXL Espresso Machine
My Breville800ESXL makes steam but does not make espresso.
The unit turns on, heats water and functions as normal, except when you turn to expresso mode, nothing comes out. The steam function works correctly. The pump seems to be working. I have thoroughly cleaned machine and parts, ordered new filter but still cannot get espresso. When you turn the machine off, the filter is full of water.
  • 2 more comments
  • jejones Nov 24, 2008
    I have the same problem and have even burned myself when I pop off the wand that holds the espresso.
    I went to the website and they said that it may be that the espresso is ground too fine. Also, I have started cleaning out the filter with an actual needle, clearing that central hole until I can see light through it. So far this has worked!
    We will see, not too happy with the whole machine!
  • Anonymous Dec 27, 2008
    I have a Breville Ikon (year and a half old), will not make much coffee, lots of steam and water pressure but very little water comes through the basket, even without any coffee actually in the basket.
  • Dean Stoneburner Mar 10, 2009
    Same problem - Heats water, makes steam, but little or no flow through the filter. I was able to improve the situation, but not fully resolve it. The filter appears to have an air space between the top surface (many holes) and the bottom (one hole). It appears that coffee over time becomes trapped between the two and restricts flow. I was able to improve this by first using the supplied probe to clean the center hole, then by filling a saucepan with water, just below the top edge of the filter(s), and then boiling the heck out them for twenty minutes or so. Boil the water first, then place the filters in the boiling water so they float like little boats. They will slowly fill, and bubbles will rise from the may holes. You'll see particles of coffee emerge. When no more come out, you're done. It's a problematic design or so it appears.
  • anigro May 03, 2009
    I replaced my Steam Gasket on an 800ESXL because it was leaking...now with the new gasket it leaks more than with the old one...when I say leak, it makes a shot of espresso, but it seems as though to much water is being pumped, so after making the shot, I have to remove the cup immediately or it will be deluted with water
Once it. while the actual filter needs to be cleaned, because it will get blocked. You can clean it and make sure you clean it well. For that purpose I use the metal spunges from the grocery stores the ones you use for pots and pans, as it gets a lot of the coffee out of the filter and rinse well. Best way to see if the filter is blocked by fine coffe grinds is to point at any light. Its valid for all espresso machines. I used to fix mine like that and had no problems what so ever with the filter and always enjoyed nice cup of espresso:) Good Luck to all!
Posted on May 08, 2012
Deanguzzi:
I tried the boiling of the filter, but didn't really work. Instead, I did something something which sounds stupid, but it worked!
I went to the sink, took a mouthful of water. Pointing my mouth at the ceiling (so as to not spill the water), I then put the filter in my mouth, so my lips sealed around the rim of the filter (the filter was back to front, as the single little hole was pointing down my throat, and the bit with many holes was pointing out).
Then, I bent over the sink, so that the water in my mouth covered the filter surface. I tend blew as hard as I could, keeping the seal of my lips around the filter, with my fingers helping close this seal.
This causes the water to push backwards through the filter, cleaning it out. After I first blew through the filter, the water went from my mouth, through the two metal layers, cleaning out the fine coffee grinds. My filter is now like new :)
Posted on Aug 19, 2009
THIS SAME THING HAPPENED WITH MINE - TURNED OUT I NEED A NEED RUBBER STREAM RING. THE ONE IN THE MACHINE HAD WORN OUT AND A PIECE CRACKED OFF. ONLY PROBLEM WAS FINDING ONE - AM WAITING TWO WEEKS ON A BACK ORDER. THAT SEEM SILLY WHEN THE MACHINE IS STILL ON THE MARKET.
Posted on May 02, 2009
    Problem Solver:
  • 7 Answers
Jejones is right. try a coarser grind. it still makes great espresso, especially if you really pack a lot of ground coffee into the filter basket. Just make sure it is a bit coarser than you would normally use for machines without the dual wall filter basket.
Posted on Dec 02, 2008
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
I can not get my expresso to come out, I had no manual with this product. Ariete elisir cafe model 1331
Once you have put the water into the reservoir, you have to turn the machine on (top button) and then let it heat up for 8 - 10 minutes before you turn on the espresso maker button (middle button). Once you're halfway through making your espresso, I would recommend turning on the frother button (bottom one) in order to get up the steam if you're going to make steamed milk.
I hope this helps.
Jul 26, 2011 | Ariete Cafe Retro Espresso Machine
We got a gagia expresso color machine recently. We used it for a week and now the machine is not is not dispensing expresso. The machine makes sound but no expresso comes out. The tank has enough water....
Your are propably need to prime the machine. This mean that air blocked in the machine and need to get out and fill all pipe system with water.
To do this you need to warm up the machine and turn the hot water knob so you will get one cup of hot water from the steam wand. After that try to get some water from the coffee head without any coffee in the filter handle. Now the machine is ready for coffee again. You will need to prime the machine very often so try to remember the procedure. This will happen again usually after you use the steam process and this normal for your machine.
http://www.fixya.com/support/r5772014-saeco_gaggia_spidem_ventilate_prime
May 01, 2011 | Gaggia 102534 Espresso-Color...
RE: F9 Upon startup the unit goes thru the normal cycles for making an expresso but, after the beans grind, little to nothiing is dispensed. The unit stops and the message is to fill water portion. I push...
Hi Bill
What happens when you do a tea ? (hot water only, NOT the steam button) do you also get little water ?
The fact that you are getting steam is good as there are 2 heating systems in the unit.
Have you ran the descaling recently (if you do not use filter ) ?
If you have or use a filter the problem is likely to be at the rear of the machine, however the back contents all the power and you will need to be happy to do some stripping down of the machine,
In the back you have the pump, valves, heater etc.
I am just about to draw up a flow chart of the water system inside the machine and have it published online (couple of days).
Are you happy to strip machine down ?
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Jura Capresso Impressa F9 Espresso Machine
When I try to make espresso with my new XP2070, water comes out through the steam arm and not through the nozzles. I've tried it without coffee and all the water still comes out through the steam/hot water...
David, the XP2070 won't operate properly until you've set the clock on the unit.
In case you don't have an owner's manual, I've attached a copy of the manual from the Krups site that you can download and print for free.
Please take some time to reaquaint yourself with the setup and procedure for using the expresso portion of the unit, as you might just have some sequence issues that is preventing the expresso from getting brewed.
Otherwise, it could be that the unit has a faulty seal in the pressure vessel that isn't allowing the expresso side to function properly, hence the reason the water might be coming out of the frothing tube instead of through the expresso brewing section.
http://www.krupsusa.com/NR/rdonlyres/C308FB44-1EC6-4119-A060-C73BD65F4789/7355/XP2070espresso.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
New to expresso machine - Cuisinart EM100c
This is a very loud machine. Here's the normal operation: You turn it on, and wait a few minutes for it to heat up, at which point the heating light will go off. Then make sure the function knob is turned to coffee, and it will start brewing. At first, it will make a short (loud) sound and then stop for a second. The purpose behind this is that the machine is pre-wetting the coffee, so that steam can more easily shoot through it in a couple of seconds. Then the loud noise will start again and run continuously until you turn the function knob back to the center. So, the sounds you were hearing were normal. There is a delay between when you hear the sounds and the water starts flowing out. If the coffee is pressed down (tamped) too hard, that delay will be longer. Hope this helps. You made a much better choice purchasing this machine rather than the more expensive EM-200, in my opinion.
May 10, 2009 | Cuisinart EM-200 Espresso Machine
Espresso machine loses steam than recovers in minutes
It sounds like a heating element issue. Those elements look like a single unit but are actually made up of 2 or 3 independent heating coils - one may not be working. So, you're only getting 1/2 to 2/3 heating capacity, which isn't noticeable until the machine is under heavy steam load.
Dec 11, 2008 | Nuova Simonelli Program VIP Coffee Maker,...
I have a expresso machine ESP6. it is not letting out enough steam or frothing milk. what's the problem and how to fix it?
The steaming wand's tip gets gunked up with milk so make sure to clear that with a needle first. Make sure the machine is fully heated before using the stream function (should have an indicator light). Typically this model will expel water first, then a low pressure steam. After about 30 - 40 seconds it should produce meduim pressure steam. Make sure the pump is making the proper clunk, clunk sound or it could be failing. Also, the steam wand arm may be obstructed and descaler solution will have to be used to remove the deposits. Hope this helps.
Sep 15, 2008 | Breville ESP8XL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
610 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Steve
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
