Question about Philips 36PW9525C 36" TV
TV goes into standby after approx one hour
Can anyone help. My tv works fine for about an hour then switches off and goes into standby. It can be switched on again but then goes to standby after about ten minutes. I've had this tv for six years now and this is my first problem with it. Any advice would be most appreciated. Many thanks. Maurice
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
Capacitors that are going bad in the power supply is the usual problem. Six years, however, would be a long time for this problem to show up. Cheapest fix is (in order): (1) Replace all electrolytic capacitors in the power supply board - about $20.00 for parts. The really, really big high-voltage ones are probably OK unless you see a bulge in the top.
(2) Replace the power supply board entirely (with new one - not used from eBay) (3) Come back here if these don't fix it. I have fixed many TVs with this issue and 90% is capacitor related.
Posted on Jan 15, 2018
techman
  • 3130 Answers
SOURCE: TV goes to standby without touching it
Soounds like the typical cold or bad solder connections somewhere in this set on the printed circuit board. Not the ez fix for a consumer. Must know how to solder and test solid state electronics
Posted on Sep 16, 2006
wooger
  • 9 Answers
SOURCE: Philips wide screen TV
OK sorted the problem on my set. Replaced the capacitor ref: 2455 on main board it is a 47uf 25v but i was told a 35v will work as well? But mine is a 28pw6506/05
Posted on Nov 17, 2007
chrispurs1
  • 372 Answers
SOURCE: Television reverting to standby
Hi Phil.
Try adjusting A1 on loptx it is very critical & can cause the symptoms you are describing.
You could be right in saying the crt, Philips tubes are notorius for failing.
Im hoping your a tv tech if you are not DO Not do what I have written below tapping neck to hard can cause seriouse injury to your self.
Run set & tap the glass neck of crt if pic flickers or you see red blue or green flashing while tapping tube neck it will be the tube.
Let me know results there are a few things that can be done.
Chris..
Posted on Dec 15, 2007
  • 60 Answers
SOURCE: I have an old CRT Philips TV. IDTV 100 Hz,
red cathode having more current chack cathod voltages crt is also suspected
Posted on Jul 19, 2009
  • 68 Answers
SOURCE: tv on off switch takes 20 to 30
Your power supply is probably failing, and will need replacement or possibly repair. If you're very good with a soldering iron, and very comfortable inside a TV, you might ba able to repair it yourself, but I would really recommend that you take it to a professional be cause it's easyy to get something wrong and cause a more expensive repair.
Posted on Dec 01, 2009
Testimonial: "many thanks help very much !!!"
Technika Tv is receiving power and is trying to switch itself on .the standby light turns green for a few seconds and then goes rd . this cycle repeats itself constantly. Tv will not switch on .
There is some short circuit inside any one of the circuit boards. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Feb 26, 2013 | Televison & Video
My sony KP-443X3U rear projection tv went to standby and I cannot get it to switch on. It is approx 6 years old. I think the bulb needs to be replaced?
Google the model number to locate it with "lamp" and You Tube has video instructions for replacing in most models--lamp has a 2,000 hour or 2 year average life and is meant to be replaceable by the customer who owns the set.
Nov 06, 2012 | Sony Televison & Video
Wont turn on from standby
Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 40BV801B LCD TV
Will not switch on
There's a problem with the video card of the lcd TV  needs replacement .
some chip are damaged .or gets over heated eg processor .
Good luck
Oct 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Onida stand by problem
sir my onida tv 21'' ineed un lock
Nov 07, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Re44sz21rd
HI,
All I can suggest is to replace the bulb. I experienced a similar problem after about 2 years viewing when the recommend lamp life was approx 8000 hours (I got to approx 3000 hours). There is a service menu you can access where you can reset the lamp hours time. I have read that if this is reached you must replace your lamp, but you can extended this by reseting the hours.
I have since learnt that a lamp bulb can go at anytime, so it is worth having a spare. Also I have noticed that switching the TV off at the switch (not leaving it in standby helps).
Try this to access the service menu. Holding down the menu button on the remote and the one on the TV for a few seconds. I think the TV needs to be off.
From memory, I think it is option 4 and option 5, then reset the lamp hours to zero
Sep 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Sep 16, 2006 | Philips 28PW6006 28" TV
TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Philips 36PW9525C 36" TV Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
