Question about Sharp AR-BC260 Color Copier
Sharp AR BC260 color printing Lots of ghost lines in color prints
Appears to be fuser unit. How can I clean it or is that possible
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Depends on what is the problem with it? if it's only toner on it, let it cool and clean w soap and water rag, then wipe clean. I suspect that it is most likely scratched and the coating on the fuser is missing, it should be a shiny smooth surface.
Posted on Nov 19, 2008
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
Printer constantly paused during printing
Is Post Script Key in the Mahcine? (PS must be intalled on the machine)
Do you have the Correct Driver
www.sharpusa.com
Aug 08, 2008 | Sharp AR-BC260 Color Copier
Sharp AR-BC260
I would inspect the fuser unit for abraising on the roller or missing and/or broken pauls.
Jun 06, 2008 | Sharp AR-BC260 Color Copier
Sharp arc 262
Turn off machine, open drawer where fuser unit is and gently pull out the jammed paper. You may have to replace the fuser unit.
May 27, 2008 | Sharp AR-BC260 Color Copier
Sharp arc 262
Open the Left side door and remove the fuser unit by unscrewing the large green wheel located under the frame on the left side door below the fuser unit. Lift the fuser unit using the handles front and rear sides. (be careful it is very hot). Set the fuser unit on a table or counter or desk. Look carefully at the left side, as it sits in the machine, near the middle. You should see a actuator for a sensor. Make sure both ends of the arm are in the holes where they shoud be. If it is out of place, put it back into place and carefully place the fuser unit back in the machine. Secure the fuser back in the left door and close the door.
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Printing
No, but go to www.sharpusa.com and search in the upper right corner search box for print driver. It will come up with a "click here to download drivers for your MFP". Select the AR-BC260, and you windows version and dowload the PCL 5C print driver. Run the downloaded file. You need to know the IP address of the copier first.
Oct 22, 2007 | Sharp AR-BC260 Color Copier
Sharp AR-BC260 Color Copier Logo
207 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
