Question about Gb Electrical 1 30 Amp Ground Fault Circuit Breaker
Air handler circuit breaker
Bad circuit breaker was taken out from the AC air handler by tec, ($75.00) he bundled wires together without a breaker. He said, since the main circuit breaker panel is near by, I didn't need the air handler breaker. TRUE???
I purchased a new breaker ($75.00) and would like to put it back in. I'm presently unemployed, and cant afford for tec to come back for another service call. Do you, or can you please tell me which wires go where on the breaker it would help if could help me with a schematic ? I do most electrical work around the house and am familiar with the AC jargon.
Thanks for your attention.
Eric
  • vrcohanim Nov 23, 2008
    Thanks for your help, I had the original tec reconnect it for free.
    Problem Solver:
  • 10 Answers
You realy need to reffer to schematic.if u try to rewire make sure ur breaker's r off both air handler/heat pump.top of breaker is normaly the load which means wires coming from air handler bottom of breaker is the line side(lL-1 L-2) there should be a schematic on blower or one of doors are there electric heaters.if so what watt r they to asure u have right breaker.
Posted on Nov 24, 2009
    Sergeant:
  • 359 Answers
WITHOUT ANYTHING TO LOOK AT I WOULD SAY HE CONNECTED HALF THE LOAD TO ONE OF THE PHASE WIRES AND THE OTHER TO THE OTHER PHASE WIRES , PHASE WIRES MEANING 120/240 SINGLE PHASE , SO IF THAT IS THE CASE TAKE THE WIRES HE HAS BUNDLED TO ONE PHASE OR ONE TERMINAL ON THE BREAKER AND THE OTHER TO THE OTHER TERMINAL OF THE BREAKER IN SOME CASES IT IS NECESSARY TO CONNECT THE WIRES WITH CONNECTOR, APPROVED TYPE AND THEN TO THE BREAKER TERMINAL ,THIS JUMPER SHOULD BE RATED THE RATEDING OF THE BREAKER YOU ARE INSTALLING ,GOOD LUCK
Posted on Nov 23, 2008
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
Problem with Air Conditioner
there will be an access panel where the motor is located. 1st thing to check is fuse or circuit breaker feeding the air handler. this is on seperate power from compressor unit outside and usually has a fused or breakered disconnect on the side of the unit. if fuses are good or breaker is not tripped then switch fan mode to on. if blower runs in on but not in auto then it is a thermostat problem. if still no go then turn off power, remove access panel and find the squirrel cage fan blade. make sure it turns freely. it is very common for these motors to go bad. it can usually be removed easily and taken to a motor shop. I use Roy's Electric in Richmond, Va. They can test the motor on the bench and replace it if it is faulty.
Sep 08, 2012 | Heating & Cooling
My ac thermidistat control box is out how can i turn it back on i drain the out side pipe and the box won't turn on i check the fuse box and it's on
t stat is bad jump t stat red white yellow wires tie together will start ac if it works t stat is bad .shut breaker off first for air handler .Run to test untie wires when done.
Dec 15, 2009 | Heating & Cooling
Air handler and compressor on ac is not working
Check the breakers,if they are not tripped then you have a problem with either the t-stat or the low voltage transformer in the furnace may be bad.To check for low voltage remove the front cover of the air handler and using a volt meter check for voltage between the red and common wire.
Sep 05, 2009 | Heating & Cooling
Type of circuit breaker for a rudd handler the one attached to the handler
These are special breakers you amy ahve to contact Ruud. Go online for ac parts you will need your model number. If you have a disconnect within 6 ft of unit you can install a terminal block in place of the breaker. Rus
Aug 19, 2009 | Heating & Cooling
Goodman a/c unit outside not coming on. buzzing
Sounds like compressor is bad...taken out by a bad contactor.
Aug 17, 2009 | Heating & Cooling
Why is my air handler fan motor tripping the 20
sounds like fan motor is going bad - replace
Jun 15, 2009 | Heating & Cooling
Central AC unit sent smell and smoke film
thermostat can short out turning on system a short in wiring will do same --smoke can be from fan or circuit board have a mechanic service the system
Jun 11, 2017 | Carrier Adit 600 Base +24V Phone...
Fuse blowing on tappan air handler
most of the time its out by the ac unit . you have a shorting thermostat wire .. the outside unit has a large wire thats 240v and a small one that 24v thats the one you want to look at . look for bare wires , look where it goes into the wall , thats the common place . "critters" love to chew thermostat wire . so take a look . .....please rate this answer , i need votes . thanks
Jan 24, 2009 | Heating & Cooling
York Air Handler trips main circuit breaker
almost has to be the electric heat strip coils. they usually come on in stages. when the damaged strip comes on it kicks breaker. turn off all power, check with a meter , gently remove strips and inspect for broken or shorted coils. usually best to buy a new heat strip module. they are usually held in place as a module with 4 screws and a snap together wire connector .good luck. i have had some success if the wires are broken and not to brittle by bending a minute loop in the end of each wire and reconnect with the tiniest screw and washer and nut you can find, i'm talking real tiny. about the size of a bb if you can find em , or you can remove the damaged strip wire entirely to get some heat from remaining.
Nov 23, 2008 | Heating & Cooling
Gb Electrical 1 30 Amp Ground Fault Circuit Breaker Logo
676 people viewed this question
Top Gb Electrical Electrical Supplies Experts
Steve
ken skalski
Are you a Gb Electrical Electrical Supply Expert? Answer questions, earn points and help others
