Question about Kitchen Ranges
Short in touch pad jenn air range/oven sve47600
Is there any way to fix a short in the touch pad other than getting a new one? I just recently read that using ammonia based glass cleaner, the touch pad will absorb the ammonia directly causing it to short.
KevinWhite
  • 1902 Answers
SOURCE: I need to replace the
Hello & Welcome to FixYa
The heating issue can be caused by the oven temp sensor that is bad and needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement. You can view this video for glass replacement:
Please get back to me if you have any other questions.
Kevin
Posted on May 28, 2011
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
I need to replace the seal AND the inner door glass on my Jenn-Air sve47600 range. Haven't found anything online that helps with the glass replacement. Another question: above the oven door (and...
Kevin
May 28, 2011 | Kitchen Ranges
What des error cde F1 mean on a Jenn-Air D156 drp-in range
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
JENN AIR
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
Mar 22, 2010 | Food Processors
F1 Failure , need to know how to advance the clean timer to get unit to unlock
Hello welcome to fixya,
Below I pasted the fault codes for the two different years of this range.
To diagnose these difference you will need a hands on tech !
this is not an easy thing to determine
JENN AIR
Failure
Code
JENN-AIR
Failure
Code
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Electronic Display
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
Oct 29, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn Air range model SVE47600 Beeping
f7 is the code for a shorted keypad or membrane have your husband disconnect the mylar ribbion from the range and gently clean the end with a pencil eraser then reconnect and try again if that doesnt work replace the touch pad
Mar 11, 2008 | Kitchen Ranges
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air Convection Oven
Our 7 year old "Jenn-Air Convection Oven", Canadian Model # SVE47600 also has a very dim display. We can barely read the temperature on the oven. Does anyone know what is wrong, how to fix it, and what it may cost us?
Dec 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air slide in range/convection
I put a $.12 capacitor on the display board and the display came back. capacitor in position c3, part from mouser electronics, #746-uvy1v680med
Dec 19, 2007 | Kitchen Ranges
Kitchen Ranges Logo
74 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
