Question about HP Computers & Internet
After 2 hours of continous work, my hp pavilion dv9500 just looses image and than after30 seconds it frezes the other programs who were still running on my vista ultimate After restart shut down etc I dont get image on my screen. Nothing. Athough I can still see that my lcd lights up. I cant even see POST. he laptop show hdd activity, no beeps but after 30 second automaticly restarts.
  • HP Master
  • 2,486 Answers
Its a notebook.
step 1: remove the main battery , run now on the line pack?
step 2 is BIOS screens if they are dead, then the screen is dead.
DV95000 has CCFL back lamps that fail, most this old have.
do the fish light trick next
http://www.pcdied.com/monitors.html#flashlighttest
the bios key is F10, it prompts you every time you turn it on
so if it stops prompting, you lost power, or the screen is dead
BIOS works even with the HDD removed.
does the fan blow , battery out, and power pack plugged in to wall ac power?
does it beep (sounds) or flash Caps lock keys? if yes those are codes. (Morse like codes)
what does this mean,?
"I can still see that my lcd lights up."
you mean LED,s'
get bios working,
first.
Posted on Aug 23, 2017
  • Larry Ng
    Larry Ng Aug 23, 2017
    this pc may be 2008 and has the solder ball problem, see on same link above;.
    first one was 2007, so.... do the flash light trick see if data is there.
    http://www.pcdied.com/monitors.html#sold...
    keep in mind i can see the screen
    nor press those bios hot keys.
    F10 your books says is it;
sandrew
  • 2961 Answers
SOURCE: Auto restart without warning
go to control panel>administrative tools>event viewer and look in the left hand listings at programmes etc and see if there are any red crosses or exclamation marks to give a clue as to the problem, but if you know it's not overheated and you have'nt recently installed any other software and recently scanned for virus and spyware it is probably a driver problem.
Posted on Sep 02, 2007
melnavz
  • 1226 Answers
SOURCE: LAPTOP HP PAVILION DV2000 problem
Hello!
That beeps indicated that there is a problem in the video Graphics adapter and in the memory.
try remove and clean the memory and then fix it back, im sure that would resolve your problems. however if this not solve then your should replace the memory.
If affraid to do so, then maybe let the repairman do it for you.
fixya!
best regards, melnavz
Posted on Feb 29, 2008
PABLOCSA
  • 1124 Answers
SOURCE: HP PAVILION LAPTOP SHUTS OFF AND REBOOTS AFTER A FEW MINUTES
This issue could be caused by any of the below possibilities
Software issue or error.
Hardware issue or error.
Heat related issue.
Computer virus.
Issue with operating system.
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
From the desktop right-click on My Computer.
Click the Properties option.
In the System Properties window click the Advanced tab.
In Advanced click the Settings button under Startup and Recovery.
In the Startup and Recovery window uncheck the Automatically restart check box.
Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
Reboot the computer and enter CMOS setup as the computer is booting.
After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows.
Posted on Nov 12, 2008
SOURCE: Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Posted on Jan 10, 2009
admin734
  • 268 Answers
SOURCE: hp Pavilion zd8000 shuts down loosing all opened windows
There is a software called "SpeedFan" which you can download here
This software will tell you the internal temperatures of the computer (so you can figure out if overheating is the problem). Most of the time overheating is due to excessive dust inside the laptop. The best bet is to get a can of compressed air and clean the inside out. This does require some disassembling of the system, so if you are not comfortable doing so I would advise you to take it to a local computer shop.
Another solution would be to purchase a "Laptop Cooler", this will lower your temperatures anywhere from 5-10 degree's, but can get annoying to lug around with you. You can view some laptop coolers here
If you happen to run the Speedfan application, let us know what the temperatures displayed as, and I can tell you if it is running too hot!
Posted on Apr 23, 2009
My Labtop boot only the windows logo and stop there, what is the solution
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 22, 2012 | HP Pavilion dv7-1132nr Notebook PC
I had graphics problem,after resolved by an exprt the power problem starts within a day. Now it is not starting. Do i have to change motherboard?
not yet,,
remove the graphics card, remove the pc memory remove the battery from the board, press and hold the power button for 12 seconds release put back, battery and memory and graphics card turn on, load default values and contine, should be fine.
Apr 04, 2011 | HEWLETT-PACKARD Hewlett Packard 459566-001...
I have a laptop dv9500. The monitor is black and no bios or any sign of picture,nothing is on the screen just faint blue light. where is the problem?
The HP Pavilion dv9500 is one of the Pavilion dv9000 series of Notebook PC's.
This is the problem, and the possible solution,
http://www.youtube.com/watch?v=bnkQNmKauEc
(TIP: I would use a Heat Gun instead of a torch)
Dec 02, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
The quick play button on my computer doesnt work and i'm using windows 7 for my HP Pavilion dv 9500 laptop
Try install quick launch buttons from hp site,if there isn't listed win7 download it for vista.
Jan 24, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
My HP pavilion dv9500 has failed with a mother board failure. Before I take action I would like to know whether the hp pavilion dv9500 has a history of motherboard faults; if so is there a good URL which...
The DV6000 and the DV9000 have a bad history of failure at the video card. Most of the failures are caused by an overheating issue. The most recent BIOS updates being released by HP have resolved many problems by making the fan run faster and more efficiently to reduce heat. Also when you buy motherboards for these systems, retailers are including small copper plates to put between the heatsink and processor and video chip to help reduce the heat load. Check any forum that mentions the DV6000 and the DV9000 and you will nothing but complaints about the motherboard problems. Most of which were or are out of warranty and consumers told to pack sand by HP support.
Nov 08, 2009 | HP Pavilion dv9500t PC Notebook
Webcam not working on HP Pavillion dv9500
The trick to the HP web cams is the fact that they work with one piece of software only. Go to the HP support site...here...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01415015&cc=us&lc=en&dlc=en&product=3985345
scroll to the bottom of the page to the "see also" header. Choosethe download youcam file. It is a binary file that can be saved to your hard drive and then installed.
Sep 25, 2009 | HP Pavilion DV9500T Notebook
Downgrading HP9500 Vista to XP Video Driver problem
go into ur control panel and use ADD NEW HARDWARE...run ur appilcation from here shold give u results use disc if u have one..in order to get all cataylist drivers for nvidia u might need to go to nividia supportcom for all latest drivers
Jul 18, 2009 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Hp dv9500 Pavilion/Vista Business locks up download pdf online
be sure to download last Acrobat reader: some PDF form are incompatible with older Acrobat Rdr version with unpredictable issue
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Open Questions:
HP Probook 6560b BIOS doesn't recognize working WD SATA HDD. I have verified that it works in another computer and two other SATA HDD's work in my Probook. I have a WD Black 500GB SATA HDD (model #WD5000BPKX) that was the Kubuntu OS drive in my old HP Probook 6550b and works flawlessly when I test it in my husband's HP DV2000, but the BIOS on my current HP Probook 6560b does not recognize it. Running a HD test within the BIOS returns no drive installed, however booting from Ubuntu 16.04 and 18.04 Live USB sticks shows the HDD in the OS's file manager and partition manager, and another (Seagate) SATA HDD works flawlessly in this laptop. I have restored the BIOS to defaults and the version showing within the BIOS - F08 - is newer than the one shown for Linux on HP's driver site. Are you aware of any incompatibility with this particular model of HDD? I have VirtualBox but no Windows computer, if it is advised to update the BIOS to the current F67 revision shown for Windows computers on the HP support site. EDIT: Solved. I had no access to a Windows computer, but figured for whatever reason the BIOS in a computer that shipped with a 500GB SATA HDD wasn't recognizing a 500GB SATA HDD. So I installed the original Windows Vista Basic on the older 320GB HDD, downloaded the current HP BIOS update for that OS (on my husband's Ubuntu computer, since of course Windows didn't recognize all of my hardware), copied it to the 320GB HDD, and installed it without a hitch. The Probook 6560b is now running under a fresh install of Kubuntu 18.04 on the 500GB SATA HDD that wasn't recongnized prior to that update. Maybe not the simplest way to resolve it, but at least it's fixed. Hope this helps someone else with an older laptop not recognizing their SATA HDD. :)
Aug 18, 2018 | HP Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
