Question about Euro-Pro Super SC710Z Steam Vacuum
No steam release
Unit heats up but when trigger button is held down, no steam is released from nozzle. Steam pressure is built up in unit, when unscrewing the safety cap steam pressure is noticeable. Concentrator nozzle is not clogged, I cleaned all nozzles with a paper clip. Can I add a teaspoon of vinegar to water, to aid cleaning?
  • Anonymous Mar 12, 2014
    Steam comes out of the wand even when the trigger is not depressed, so the Polti never comes up to full pressure due to the steam escaping through the wand. I've replaced the hose and trigger unit but that's made no difference.
  • Anonymous Mar 15, 2014
    CLEAN WATER AUTOMATICLE COMES OUT WITHOUT SPRAING THE TRIGGER
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Posted on Nov 08, 2007
Sc20 trigger does not release steam
Clean jet(s) where steam comes out from . They may be clogged.
May 19, 2015 | Top Vacuums
Gets super hot but steam won't come out.
i have a simular steamer made by a different company. it used to work when i had first gotten it, but i think one time that i had plugged it in for a long period of time without using it has caused the plastic parts under the trigger that releases the steam flow to melt. so now the steamer that i have still heats up really hot but when i try to push the button it does nothing, no steam will come out of it at all... so i think my mistake was plugging it in without using it for too long, making it now inoperable basically garbage. sorry to say
Apr 17, 2014 | Scunci 52067 Handheld Steam Vacuum
Shark s3601a no steam
Don't you have to push down on the handle while mopping the floor to get the steam to release. I know the one I have has a handle that slides down the shaft in forward mopping motion which releases the steam.
Oct 15, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a turbosteamer 220 hand steamer. It heats up but won't spray steam
It's most likely the trigger not engaging the piston that releases the steam. Due to the fact that the plastic inside the 220 holding the trigger in place has cracked on both sides.It will need to be taken apart.That's another issue.Be easy on the trigger press down gentle.....
Jul 27, 2011 | Vacuums
The unit heats up when plugged in, but there is no steam released out the bottom of the mop when the handle is pushed up and down.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Dec 21, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-flex monster baby 1000 watt will not release steam
try running a descale through the unit. probably blocked with mineral deposits. Descaler available at most steamer retailers
Sep 20, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
Trigger not working correctly
You might need to de-scale the unit to free the stuck valve.
Keep the unit unplugged.
Fill the unit with a vingar and water (filtered or distilled is best).
Screw the cap back on and place the unit in a sink upside down to allow the vingar and water to reach the valve.
After a few minutes press down the trigger several time to work the solution into the valve.
Hope this helps.
Sep 15, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Steam will not eject
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
Apr 19, 2008 | Scunci 52001 Handheld Steam Vacuum
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Euro-Pro Super SC710Z Steam Vacuum Logo
675 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Marvin
Marvin
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
