Question about Maytag PAV2300 Top Load Washer
Monster growling coming from my washer
My Maytag washer started growling something fierce last night. Everything still works, but I'm scared to be in the same room with it. The noise only comes from the first cycle when the agitator is working. The spin and rinse cycles are trouble free. Could this be some kind of bearing problem or is it a component problem??
    Problem Solver:
  • 6 Answers
I have a PAV2300 and I recently experienced a grinding noise. Turned out to be the pump pully has a sleve between the pully and the bearing that has slid out of position and was grinding against the base of the pump. You could see where it had ground the paint away. I took the pump out and using a small bladed screwdriver, wedged it between the selve and the base of the pump and working my way around it several times, managed to press it back into place. On the PAV2300 the pump is in the back of the unit. Looking at the picture the sleve is between that pully and the black base. Hope this helps. Good luck :)
Posted on Feb 28, 2007
My wife put a load in last night and a couple of hours later the laundry room smelled like something was hot and the washer had stopped on the spin cylce. The control panel didn't feel hot but I unplugged...
Something caught in pump & belt burning. Motor start capacitor (If fitted) is US & needs replacing. Timer faulty, motor has burning smell, replace timer & or motor. Motor switchgear failed motor sitting there & humming, adjust switchgear or replace motor.
Dec 19, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Our Maytag washer started making a noise like metal rubbing on metal. After looking and the bottom of the washer the noise seems to be coming from the pulley that is hooked to the drain hose. The main...
It sounds like it may be a bad pump and you will probably need a new belt. I would recommended calling a service tech this is a fairly difficult job to fix and there may be other things going on that you cannot see. Do not attempt to use the machine until it is checked out.If I can do anything else to help please let me know.
Ken
Mar 18, 2010 | Maytag PAV2300 Top Load Washer
How to get fingerprints off my screen
Its called Monster Cleaner.. You can find it at best buy wal mart comes with everything you need...
Mar 15, 2009 | Sanyo DP42746 42 in. Plasma Television
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Squeeling Noise (from the pully pump I think) Maytag MAV8600AWW
you need to replace the pump the pump bearings are starting to wear out eventually the washer will not drain
Dec 20, 2008 | Maytag MAV8600 Top Load Washer
Power light blinks, but tv won't come on
I have the 52" version of the Viera model. Mine went out last night and started blinking twice over and over again. I suspected overheating so i just went to bed and tried it in the morning with no luck. Then I unplugged it for more than ten minutes and plugged it back in and everything worked fine. I hope this helps.
Jan 08, 2008 | Panasonic Televison & Video
Maytag PAV2300 Top Load Washer Logo
288 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
