Question about Epson Expression 10000XL Flatbed Scanner
Scanner won't turn on
I have an epson expression 1680 scanner. we use it to scan xrays in our pediatric dental office. this morning it just won't power on. i've done everything. unplug - leave unplugged - reset the surge power strip - change outlets - other things are plugged in they are fine - nothing is working. does this mean i just need a new one?
  • 189 Answers
Try to test the power cord of the scanner (cable from scanner to outlet) using multitester if there is an electricity or if you have extra power cord test it. Maybe that's the defect. If that's not the problem it is now the scanner itself, have it for the repair man or technician.
Thanks
Posted on Nov 19, 2008
I have an Epson expression 1680 with the latest drivers and a usb hook-up to my Windows 7 computer. I can scan, the computer recognizes everything but I cannot get it to work to copy film...it won't let me...
Hi, most if not all scanners don't work when you try to use it on film. Usually, the only way for you to scan film or transparencies is you have to buy an accessory for the scanner called a "transparency unit" which does not come installed with your scanner when you buy it. Unless your scanner says that it came with that accessory then you won't be able to scan films or transparencies at all.
Feb 05, 2018 | Epson Expression1680 Professional Desktop...
I am using the Epson Perfection V700 photo scanner to scan dental xrays. Sometimes the xrays come out perfect, other times I get streaks across the image. Sometimes the streaks are colored, othertimes...
You have to use the "FILM AREA GUIDE" included with the scanner. This black plastic guide leaves a small area at the top of the glass open so that the scanner can calibrate itself at the start of each scan. Use the guide or leave at least 8mm between the top of your film and the top of the scanner glass.
Jan 24, 2011 | Epson Perfection V700 PHOTO Flatbed...
During preview and scan unit will freeze up and I have to restart the computer
try to just let it chill maybe its to hot wait about 10 minutes then try again
Apr 22, 2010 | Epson Expression 1680 Professional Flatbed...
SORRY MAY BE A BLONDE QUESTION
well now there's something i've never tried.... i would suppose you can but they will likely turn out like... well negatives
Robert
Feb 17, 2009 | Epson Expression 1680 Flatbed Scanner
Door/Hinge is very tight, have to push down hard when scanning
Remove the transparency unit from the scanner. Then carefully remove the six screws holding the hinge. Use WD 40 to lubricate hinge.
Jan 13, 2009 | Epson Expression 1680 Professional Flatbed...
Lines through negative scans
Clean the glass surface with Iso propyl alcohol (Industrial grade is enough). Dont use any solvent. Just for immediate usage, you can use your aftershave and clean. Clen with a soft cloth.
S. Mohan, Chennai. India
Nov 28, 2008 | Epson Expression 1680 Professional Flatbed...
Hi-
Do you have any existing drivers for new epson scanners( models), if you have then there are compatibility issues between new drivers and old drivers, are you using a leopard 10.5 operating system or tiger 10.4.**? try uninstalling every epson info from applications folder and from library/image capture and library/preferences. you an use the finder to search for epson scan and drg them all to trash. Try using image capture application as well if it will scan when you run it, then reinstall driver.
One more thing, when you click on epson scan, does it bounce continouosly from the dock? if it is then look for a subfolder and install everything in it.
Keep me posted, thanks!
Aug 27, 2008 | Epson Expression 1680 Flatbed Scanner
Xrays
You can't scan xrays unless you have a scanner capable of scanning film, which requires a film attachment.
Jul 29, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
Communication with scanner
You could take it apart and see if you can lubricate the shaft the the scanner sits on with some vasoline. If that doesn't it could be that the stepper motor that controls the scanner is going bad in it.
Jul 18, 2008 | Epson Expression 1680 Professional Flatbed...
Epson Expression 10000XL Flatbed Scanner Logo
985 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
