My dell optiplex 170l does not display when i power it on. all it does is a blinking orange light on the front panel of the system unit. this light continue to blink on and on
    Genius:
  • 1,689 Answers
The amber Power generally means PSU issues of one sort or another. (Dirty / Dusty machine)
Using canned air blowing out the PSU and case area has fixed several occurances of this issue.
Posted on Nov 24, 2008
Power supply cord diagram dell optiplex 170L
Apr 02, 2014 | Dell OptiPlex 170L PC Desktop
Del 320 optiplex orange lite blinks won't boot up
For the Optiplex 320, a flashing amber light with no sound indication can mean 3 things.
1) Your power supply has failed
2) Your motherboard failed, most likely from a bad capacitor.
3) The front panel board (where the power button is located) is faulty or not connected properly.
I've worked with 10's of 1000's of Dell Optiplex's over the past 8 years and the flashing amber light is well known as a tell-tail sign of one of those three failure. Always start your trouble shoot with a PSU tester, then inspect the motherboard for domed or split/leaking capacitors...then on to the front panel which would require another panel and ribbon from the same model.
Jan 25, 2014 | Dell Optiplex GX280 (99301) Motherboard
DELL GX 520 Motherboard power led is orange, power button led is orange, the fun is running, no beep, no display....somebody help me with this dell gx520. sometimes it displays 3 and 4 lights on the front...
you should replace the motherboard or the power supply of your computer. to determine which one to replace is a simple test. disconnect all that is connected to the motherboard and if the problem is still there, then the problem is the motherboard.
May 06, 2011 | Dell OptiPlex GX520 PC Desktop
DELL OPTIPLEX GX 620 PC WONT SATRT ONLY ORANGE LIGHT KEEPS BLINKING
DELL OPTIPLEX GX 620 PC WILL NOT START.
ONLY ORANGE LIGHT.
Aug 31, 2010 | Dell OptiPlex GX620 PC Desktop
My computer is blinking orange light
In addition to the power supply, motherboard issues can cause the blinking power light and no boot problems. The Optiplex 270, 520, 620, 745 and 755 units are all known to have issues with capacitors on the motherboard. Here is a link to an article about this issue and what to do about it:
http://www.ccl-la.com/blog/index.php/dell-optiplex-745-repair/
I hope this helps, if sol please rate my solution.
BuddyMc
Aug 10, 2010 | Dell OptiPlex 360 Desktop Computer
My Dell Optiplex 170L
If I recall correctly, we had this happen when we first got our 170L's. The problem was the actual on/off switch on the unit was defective. Ours were still under warranty so Dell replaced the units. If you have spare 170L's you can pop the faceplate and swap on/off switches to see if that corrects the issue and then order a switch from Dell.
Oct 27, 2008 | Dell OptiPlex 170L PC Desktop
Orange light on Dell GX270 power button
A solid orange light, usually indicates an internal power problem but just in case try reseating the memory. Also its become a habit on a GX270 to check the capacitors to make sure they aren't bulging.
Jul 07, 2008 | Dell OptiPlex 170L PC Desktop
Dell optiplex gx260
Reference the Power LED States
Dell OptiPlex and Dimension computers and Dell Precision workstations have incorporated the use of the multi-state power button LED as a hardware status indicator. The power button LED illuminates in two different colors and can also blink, which allows for indication of five different system operation states. (Table 1)
LED State
System State
Steady Yellow The power supply is functioning, but the system is not processing data. This may indicate an issue with the system board or CPU. Blinking Yellow The power supply is receiving power from the source but is unable to properly distribute it to the components. This may indicate a power supply problem. Steady Green This generally indicates that the system is functioning normally. However, if problems are detected with installed components, the system may initiate a beep code. Blinking Green The system is in a Standby ACPI state. Off The system power is off.
Feb 24, 2008 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
544 people viewed this question
David Payne
David Payne
