Question about Admiral AW22 Top Load Washer
New Timer--New Problem
Ireplaced the timer on my washer and now it immediatley begins to aggitate and won't fill up with water. It will however fill when set to rince. Is there some sort of reset button that I need to press. Or better yet, "How about an EASY button?
    Scholar:
  • 116 Answers
Sound like you connected the timer up wrong, from my drawing check the following connections to the timer.
terminal 12 & 26 - Black (linked) mains supply
terminal 17 yellow/red (from rinse switch)
terminal 28 grey (from water level switch)
terminal 15 light blue (advance rinse switch water level switch)
terminal 27 brown (door switch)
terminal 25 brown (door switch)
terminal 62 green/black (motor)
terminal 7 red (motor)
terminal 32 yellow (motor)
terminal 9 blue (capacitor /motor)
terminal 8 white/yellow (motor) and white (water solenoids hot and cold)
terminal 71 pink (water selector switch and hot solenoid)
terminla 72 purple (water selector switch and cold solenoid)
terminal 70 white/blue (water selector switch)
Watch the light blue wires as there are several of them!!
Posted on Apr 13, 2008
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
My washer will fill up and begin the cycle, but half way through aggitation stops and will not rinse or spin the water out. Any ideas????
The timer is bad. Do-it -Yourselfers should be able to replace it. If not then consult with a repairman. Sometimes they can walk you through the process or at least point you in the right direction. Good Luck.
Aug 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not aggitate
LOOK AT THE LIDE SWITCH FIRST WILL IT FILL WITH WATER WILL IT DRAIN WILL IT SPIN IF THE ANSER IS NO TO ALL LID SWITCH IF ONLEY TO AGGITATE MAY BE A TIMER OR AGITATOR IT SELF
Apr 03, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
GE WJSR1070A top loader wont aggitate.
You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
Mar 05, 2009 | GE WJSR1070A Top Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't stop filling with water
In yor machine control panel you have A part called a pressure switch or water level switch. that controls the water level and tells the timer to start aggitating .If the part is bad the machine will over fill and keep running the water!!
Sep 01, 2008 | Maytag PAV2300 Top Load Washer
Keeps filling up even when full for over 4 hours (never changed cycles)
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Jan 13, 2008 | Maytag Performa PAV2200
MY LAT8824AAE machine just fills with water
if the tmer works on any of the cycles but not on all of them, you might need to purchase a new timer.
Mar 23, 2007 | Maytag LAT3600A Top Load Washer
Admiral AW22 Top Load Washer Logo
161 people viewed this question
Top Admiral Washing Machines Experts
Sal De
jimorris77
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
