Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
I need to disable my firewall on my router
So i can share files to my xbox
    Genius:
  • 1,061 Answers
Do not disable firewall add an exception to computer so it will file share with xbox.RICHARDM69
Posted on Dec 14, 2008
Need to configure port nubers for xbox
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Dec 19, 2010 | Belkin Share N300 Wireless N Router
Nat issues
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Dec 03, 2009 | Microsoft Xbox 360 Console
File sharing problem after installing Netgear DG834G ADSL/Wireles
- Run the Windows Network Wizard in each computer on the network.
Mar 10, 2009 | NetGear DG834G Router
Chanched NAT and got locked out.
Once you have logged into your router, enable the DMZ feature and put in the IP address of your 360.
This will put your 360 outside of the routers firewall and it will give you a full open connection to XBox Live.
Dec 02, 2008 | Belkin (F5D5231-4) Router
Desktop won't connect with printer connected to laptop
Make sure both computers can share files and can ping each other, if not, it's just a firewall issue. Try to disable your firewall first.
Oct 23, 2008 | Linksys Wireless-G WRT54G Router
Can't get Xbox Console to see my pc
THE pc OS is by default configured to NOT share files or folders
xbox will only see shared drives/folder on the pc,
if nothing is shared nothing is accessible.
On the pc
mark a folder as shareable and see whether it becomes available to the xbox
Jul 15, 2008 | Microsoft Xbox 360 Console
File sharing between windows 2000 and XP
1) I believe that Windows XP is not setup for that by default,
you may need to install the old BETBUI service.
2) Also, if the 2000 machine has a login password installed,
it will NOT allow any other machine to browse it, without
logging in.
3) Password-less file sharing over NETBUI was available
on the consumer side of windows:
Windows 3.11 for Work groups
Windows 95, 98 and Millenium.
The professional versions of windows, built on NT
technology require a login:
Windows NT 4.0, Windows 2000, Windows XP,
and now Vista.
4) The best work around is to login to the 2000 machine when
it prompts you for a password, using your regular USER ID
and PASSWORD.
If the 2000 machine is not setup with a secure login,
just create a new account, ranking power user or higher.
5) Note that you only need to login over the network ONCE,
because windows XP can REMEMBER your password,
and login automatically the next time.
6) Make sure that the firewall (or A firewall) is not
blocking access to either machine, just disable the
firewalls for testing.
Similarly, if your LAN is behind a residential router, using
the router as a smart hub or switch, make sure that
the routers MAC address access blocking is disabled,
until you get everything setup and tested.
7) Finally if a PC is not visible in a work group, this does not
mean that it is not accessible. This is a Windows quirk.
You can try to access another computer by using the
default/administrative shares. These shares cannot be
disabled in XP, at least they will not stay disabled, as
they will restart during every reboot, whether you like it
or not.
This means that you can ALWAYS access all the drives
on another machine, whether you share them or not, unless
you take extreme measures in the local policies.
To access drive "E:" on a computer called "Henry" on a
machine in the same work-group,
open up windows explorer, and tyr the following into the
address line:
\\Henry\E$
This should access drive E:, after some delay, and possibly
a login prompt, even though drive is is NOT marked as
shared.
Down you just love windows ?!
Security by obscurity ?!
Microsoft is getting very good at hanging massive steel doors
on paper walls.
Hope this solves your problem, or gets around it.
Please rate my answers,
Martin
Jul 05, 2008 | Microsoft Windows 2000 for PC
Westell 327W (Versalink)
you want to setup a peer to peer network using a workgroup. File sharing must be enabled in XP and Vista in order to share files. Temporarily disable the firewalls in Windows when setting up the shares....search on the Internet for setting up a Workgroup in XP
Jul 01, 2008 | Westell Wirespeed VersaLink...
Can't stream media through xbox 360 using WMP11
I had the same problem in Windows XP and I just created a workgroup to share files on the network. Follow these steps if anyone is still having this problem. My gf has vista and must do it automatically but it's just a matter of remembering to establish a workgroup.
To summarize:
- Enable sharing on WMP 11 --> This should adjust windows firewall automatically but be sure to unblock ports for other firewalls, if need be.
- Create a workgroup --> Start...Control Panel....Network setup wizard.
Follow the steps, if you're connectnig through a router, select "this computer connects through a residentail gateway", apply this to any other computers that want to share files on this network, if necessary.
Restart computer to let the workgroup settings take effect and voila...your computer will now be detected.
Jun 02, 2008 | Microsoft Xbox 360 Console
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
174 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
