Question about Kenmore Elite HE4 Electric Dryer
Kenmore Oasis washer - water accumulates in bleach dispenser
Water is left standing in the bleach dispenser - up to the Max fill line - after running a wash cycle. It is not bleach; it's water.
  • 116 Answers
Somethinf clooging dispenser, remove water from dispenser and get small straw and un clogg,,,,,,,, thats it
Posted on Nov 30, 2008
Why does my drinking water from the auto water dispenser smell??
In some instances when the cool water and/or ice maker is not used for some time, mold can accumulate in the tubing between the water intake and the ice maker. Once this happens, it is very difficult to eliminate. One method is to disconnect the tubing from both ends and block one end off. Then fill the tubing with bleach or half bleach and half water and let stand for just a few minutes. Then drain the bleach from the tubing and flush the tubing thoroughly. Be sure to run adequate water through the system to completely eliminate the residual odor/taste of the bleach before reconnecting.
Sep 21, 2014 | GE Monogram Side by Side Refrigerator
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Washer Feels like there are gallons of water in the bottom
Hello Holly Davis -
Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately. However, regarding the odor my advice to you is first rub some bleach around the door gasket. Let this dry. Next rub some vinegar around the door gasket. Let this dry. (Do NOT mix the bleach and vinegar) Then run a hot empty load of bleach in all three dispensers. Put 1/2 cup of bleach in the detergent dispenser and fill the softener and bleach dispenser to the max fill line with bleach. Once that is done repeat the process with vinegar. Please make sure you run a load of towels or some sort of items that will not matter if you get a little bleach on them once this process is done.
Dec 11, 2012 | Frigidaire ATF6000ES Front Load Washer
The compartment that you put the soap in sometimes fills with water when the load is finished
THAT MEANS ONE THING. REMOVE IT AND RUN IT IN WARM WATER, CLEAN IT OF ALL SOAP FILM AND ETC. ON THE SLOT FOR THE BLEACH AND FABRIC SOFTENER, FILL WITH WATER TO THE MAX LINE, LET IT SETTLE, THEN ADD WATER TO IT AGAIN AND SEE IF IT FLOWS THROUGH DOWN TO THE BOTTOM OF THE DISPENSER.
Aug 04, 2010 | LG WM-2077C Front Load Washer
Kenmore Oasis Elite Type 580 flashing LF
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Mar 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore/Sears 417.43142200 bleach dispenser not dispensing
Before you do anything, make sure that the plastic part in the bleach dispenser container is pushed in. Fill with bleach to the "max" line, written on the plastic part. Start the wash cycle and make sure that water goes into the bleach dispenser. Once water flows into the dispenser, the bleach/water mixture rises and should automatically dispense into the washer. We had this same problem. We removed the dispenser unit and took it to the sink. We then filled it with water and it started coming out from the bottom automatically. So sort of suction is caused from the amount of water and it starts to flow. Basically, you aren't adding enough bleach into the dispenser if the water flows into it as the wash cycle runs.
Mar 22, 2009 | Kenmore 43142 Front Load Washer
Kenmore Elite HE3 Washer fabric dispenser not working
This is usually just as simple as adjusting the syphone up and down. releveling your machine or cleaning the dispenser itself. when the water enters the dispenser gravity syphones the water out . nothing really machanical about it. unless the water is not filling up the cup enough to go above the max line. you can test it by putting water in the dispenser above the max line and adjusting the syphone cap up and down.this should grab a suction.
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Dispenser problems
Open dispenser drawer and push down on center plastic tab at back of dispenser to allow you to take dispenser out of machine. Take the plastic pieces off and clean them. (they need to be clean in order to siphon the bleach, softener, etc out. If there is water left in them, the water fill valve is OK. Cleaning should fix your problem. If you are using concentrated additives, try diluting them a bit with warm water when you add them to the dispenser. Remember, only one tablespoon (max) detergent, one teaspoon (max) fabric softener per load.
Oct 18, 2008 | LG WM-2277HW Front Load Washer
Bleach dispener always full of water
call for service, they will probably order the dispenser assembly (includes new drawer.)
Apr 23, 2008 | LG WM2455 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
158 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
