Question about Dishwashers
Smart Dispense on GE Dishwasher
I no longer want to use the Smart Dispense on my GE Dishwaher (I used it in the past). How do I get the light to go off (the smart dispense light that says to add detergent) without keeping it filled. I have decided to no longer use the smart dispense, but add detergent tablets which I find work better.
Thanks!
  • Anonymous Mar 18, 2014
    Clog
  • 1,543 Answers
Press the ADDED HEAT pad 5 times within 3 seconds. You will hear 3 beeps; then the light will go off. You can turn the feature back on again by repeating.
Posted on Nov 19, 2008
I have a GE profile PDW9980N20SS dishwasher that has a smart dispense feature to auto dispense the detergent. The manual warns to not interchange enzyme based and chlorine based detergents or it will...
Hello, ajswave
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
May 01, 2011 | Maytag Dishwasher
What can I use to plug the dishwasher drain connection I no longer need?
Push a cork into the hole.
Garbage disposal doesn't have a lot of pressure pushing water out dishwaher tube until full sink of water is drained.
You might put gorilla glue or caulk on the cork to keep it in place.
Nov 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do i drain my ge nautilus dishwaher
Pour hot water into the bottom and force the timer to drain cycle. Keep doing this until the suds are gone.
Aug 18, 2009 | Dishwashers
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
No water
GE's are bad for the water supply line freezing inside the freezer door. Also,a clogged water filter will cause the same thing. I have used a hairdryer in the past to unthaw my water dispense line.Good Luck!!
Feb 21, 2009 | GE GSH22JFR Side by Side Refrigerator
Smart dispense detergent dispenser
There are two different types of dishwasher detergent types, bleach based and enzyme based.  The owner's manual states that if the two are ever mixed that the mixture will congeal, clogging the dispenser.
I don't know exactly how to safely remove the detergent that is in there, perhaps a wet/dry vaccuum.  There is likely a service mode for the dishwasher if it has electronic buttons, in the service mode you could activate the pump that dispenses the detergent.  Use caution, the thicker the clog, the harder the pump has to work and it may fail.  Hope this helps.
Nov 08, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Where is the drain screen at in my My frigidaire dishwasher
generic reply normly in the center and looks like a plastic grating, but is your drain hose kinked?
Oct 25, 2008 | Frigidaire Dishwashers
Zug Adora 12s Dishwasher
Perhaps the solution to your problem can be found in the User Guide-
Your model number appears with two suffixes; WW and BB thatmay only be color codes but user guides (which appear to be identical) areavailable for download from GE’s site:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-55031.PDF
Oct 02, 2008 | General Electric Adora GHDA670N Built-in...
Dishwasher noise
see the fix at the following link:http://www.fixya.com/support/t204050-ge_adorda_dishwasher Simply zip tie the water tube for the middle spray to the upper basket.......it works!
Sep 02, 2008 | GE Profile PDW8400J Built-in Dishwasher
How do I make sure the dispenser is completly empty?
Just use the manual dispense. The smart dispenser is horrible. You will never get it empty AND you will have congealed soap in the dispenser for ever.
Jul 21, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwashers Logo
298 people viewed this question
Top Dishwashers Experts
