Question about Texas Instruments TI-83 Plus Calculator
Random characters lines and pixels
I've never dropped my 83 but the last time I turned it on, it displays random characters and pixel sometimes short lines. I can still perform calculations, but they are mostly obscured by these symbols, the same applies to nearly all aspects of the calculator including the graphing screen, programs, and apps.
I've had a similar problem in the past with my TI-86. It still happens sometimes when I don't use it for a while. To fix it, all I did was set the screen to its darkest setting and left it on for 10 minutes (keep it from turning itself off, by pushing buttons every few minutes.) It works great, and the calculator is fine unless you leave it unused for a month or so. A similar solution may work for you.
Posted on Jul 10, 2007
Ip3500 printing misaligned vertical band
my copier nashuatec 3722 .when start copier give me code E-4
Dec 07, 2013 | Canon PIXMA iP3500 Printer
Acer monitor has green lines on the scren
Liquid Crystal Display (LCD) screens use less energy and display a clearer picture than the Cathode Ray Tube (CRT) displays that preceded them. These new LCD screens now dominate the computer monitor market. From time to time, however, pixels can become stuck and a green line can display on the screen. Removing this line is sometimes possible without sending the screen to the manufacturer for expensive repair.
Locate the pixels that are stuck on the screen. Download a free screen repair software program, such as UD Pixel or JScreenFix. Run the software and allow it to find and attempt to repair the stuck pixels. Turn off the LCD monitor. Apply the damp cloth directly over the stuck pixels and use a gentle pressure to spread the liquid within the screen.
Things You'll Need Pixel repair software Damp cloth LCD screen 5 Ways To Fix A Stuck Pixel On Your Screen
http://www.makeuseof.com/tag/best-software-solutions-to-fix-a-stuck-pixel-on-your-lcd-monitor/
Feb 22, 2013 | Acer Computers & Internet
When I turn on the calculator, I get a screen full of random black pixels. The AAA's and the lithium batteries are both good. Nothing I do will change the screen, except turning the calculator off.
Try to reboot your calculator to see if it helps by doing this:
*Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message. *
Let me know if it helps or not.
Aug 19, 2010 | Texas Instruments TI-83 Plus Calculator
When turning on the calculator random symbols & pixelated images appear. when i press numbers, only 1/2 of the number appears, it's skpping spaces.
Turn the calculator ON and press Clear, the display will clear. If not Press [2nd] the yellow button followed by [MODE] the one to the right to it.
Hope this will help.
Aug 24, 2009 | Texas Instruments TI-83 Plus Calculator
Mits WD-52525 random 1-pixel jitter
if you are a profetional replaced all capacitors on FMT and DM board.. or replaced the chassis........
DM and FMT board N/L/A .........
Jun 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
First time used in months
Check the batteries polarity.
Perhaps it needs a "reset", some calcs do have a "button" therefor, some do if you press the start button for some seconds.
Try to leave the calc overnight without any batt. inside.
Sep 19, 2008 | Texas Instruments TI-83 Plus Calculator
Screen crazies
Doesn't sound like a good situation. My knee **** reaction would be to reseat the cable and power to the LCD screen. If that doesn't work, I'd take advantage of the warranty. They might be able to get you up and running in short order.
Hope this helps!
Ron
Jul 28, 2008 | Dell Latitude D630 Notebook
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Sharp Actius AL27 pixel problems
From what you described, it seems as though your LCD panel is going bad or the inverter board is bad. Does it change colors if you were to reposition (tilt) the LCD back and forth in either direction?
Nov 30, 2007 | Sharp Actius AL27 Notebook
Texas Instruments TI-83 Plus Calculator Logo
1,629 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
