Question about Ubi Soft Entertainment Brothers in Arms: Earned in Blood for Xbox
I get the following message when I try to load the BIA EIB
Application: setup.exe
Build: EIBPCRC1.03 (Feb 1 2007 11:45:48)
OS: Windows XP 5.1 (Build: 2600)
CPU: AuthenticAMD Unknown processor @ 2012 MHz [1417188999168.000000 0] with 510MB RAM
Video: No Video
Setup: Missing version number
: USetupDefinition::Init <- WFilerWizard::WFilerWizard
Script Stack: Not executing script code
Normal DVDs run on purt ok
  • Anonymous Dec 20, 2008
  • alphasl Dec 23, 2008
    CPU: AuthenticAMD Unknown processor @ 1819 MHz [1043963641856.000000 0] with 1471MB RAM
    Video: No Video
My mtu failed. i am using a laptop and i do not have a router or switch or wireless signal. i changed the settings but it still does not work. i really need help.
Posted on Dec 19, 2008
Trying to load CanonScan N124OU onto Windows 7 and get error message "there is no application registered for this event"
canon scan n1240u will work on Win7
here's how:
go to this site: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u#DriversAndSoftware
click "Drivers and Software" then select OS "Windows XP" then download "WIAdriverN670UN676UN1240U.EXE"
Install the WIA driver on your Windows 7 OS and used only mspaint to capture image on the scanner
TWAIN doesn't work on Win7 but WIA still doesGood Luck!
Dec 06, 2010 | Canon CanoScan N1240U Flatbed Scanner
OS: Windows XP SP2 .NET 3.0 Product: Pinnacle PCTV HD Pro Stick Hardware: Dell Latitude E6400 - 4Gb Ram Error PMCLoader.exe ''Application has generated an exception that could not be handled'' I get this...
check the requirements of the your application make sure the requirements of that application is properly installed, if not reinstall the requirements and delete the registry keys for PMCloader.exe or Pinnacle and reinstall the pinnacle software...
Feb 23, 2010 | Office Equipment & Supplies
TI Interactive will not install on Windows 7. It just keeps determining disk space requirements and does not get any further
Try doing a "silent" installation.
Click the Start button
Click the Run button
Type cmd then press enter
In the command box type the drive letter for your CD Rom Drive, followed by a colon (example, D:) then press enter
Type tiinteractive.exe /quiet then press enter
Wait 5 minutes then close the command box
TI interactive should be now installed
If it doesn't work, e-mail me at brumed@verizon.net
Nov 11, 2009 | Texas Instruments TI InterActive!...
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
But notify me when critical errors occur
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
May 05, 2009 | Acer Computers & Internet
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
2.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.
Do not choose the option to press R to use the Recovery Console.
4.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
D:\setup.exe is not a valid win32 application
I don't the problem in the drive, please try to copy the file to your desktop then run it again the same error appears, download the installer for your windows then try from the CD
Dec 04, 2008 | Microsoft Windows XP Professional With...
Explorer.exe Application error in Windows XP Professional SP2
This could be a memory problem or a problem with the OS (XP). If you can boot the original XP CD like your doing an install then it's not a memory problem more the likely. Can you boot your XP CD?
Nov 27, 2008 | Microsoft Windows XP Professional
Windows could not start because the following file is missing or corrupt: \system32\ntoskrnl.exe Please re-install a copy of the above file.
Fix the problem
Best Method would be this one, if you have the Windows Disk.
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file: 1. Use the Windows XP CD-ROM to start your computer. 2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key. 3. Select the Windows installation that you want, and then type the administrator password when prompted. 4. Type bootcfg /rebuild, and then press ENTER. 5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
[Type Y in response to this message.]
Enter Load Identifier:
[This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
Enter OS Load options:
[Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
Nov 11, 2008 | Computers & Internet
Canon i250 printer will not work with window vista os
The Vista add-on module driver (whatever THAT means!) can be found here. Have you tried downloading this Vista driver already?
Hope this helps :)
Scott
Oct 06, 2008 | Canon Office Equipment & Supplies
Ubi Soft Entertainment Brothers in Arms: Earned in Blood for Xbox Logo
312 people viewed this question
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Colin Stickland
Colin Stickland
akigawa
Level 1 Expert
Adam Jasar
Level 1 Expert
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
