I've somehow hidden my Eee PC linux desktop icons; bar down the bottom shows, and all else is black, with mouse visible. How do I get the icons back?
It came out of the box loaded with Xandros Linux, and nothing has been changed.
Posted on Nov 24, 2008
    Genius:
  • 1,689 Answers
What is the loaded OS on your EeePC?because I ran across this issue before and it was more than a hidden icon.
I have no voice at all, how wood i get my volum ajusted.
Hi!
1. If it is visible, single left click on the 'Show hidden icons' button, which is usually located near the bottom right hand corner of the screen. 2. Single left click on the 'Volume' icon, which looks like a gray speaker.
3. Single left click and hold down on the slider in the 'Volume' dialog box. As you are holding down on the left mouse button, drag the slider up to raise the volume or drag the slider down to lower the volume. When you let go of the left mouse button, you should hear a tone to give you an example of how loud the volume is now set. 4. Single left click on the on the blue 'Taskbar' to make the 'Volume' dialog box disappear.
Hope this helps. :)
Apr 16, 2011 | Dell Dimension 2400 PC Desktop
It starts up fin but there are no icons its black but the tool bar at the bottom is the what happened to the icons
Pls be more specific to your issue, if you cant see any icons on the desktop, try to restore you PC by using the restore option as under.
Start/All Program/Accessories/System Tools/System Restore.
Chose a date u think the PC worked fine.
Dec 07, 2009 | Asus Eee PC 701Sd Notebook
No icons or tool bar on desktop at startup
In your desktop, Right click your mouse and properties will show and look for show desktop option. And then move your mouse to the bottom of your computer screen, if toolbar will show, then your toolbar is set to automatic hide. Change the settings in your Taskbar and Start Menu Properties and change there the settings, uncheck the auto hide task bar.
Nov 10, 2009 | Acer LX.W530X.012 Gateway M7325u 15.4in...
Eee Pc 701SD/linux. No icons appear at startup, just blue screen
Try opening a terminal (Ctrl+Alt+t) and type the following:
sh startsimple.sh
and press enter. It worked for me, hope it will for you!
Jun 07, 2009 | Asus Eee 701Sd Notebook
Eeepc has no icons, just blue screen, can't access anything! Linux
When I was using Linux, there were 4 screens. On the bottom an icon showed which screen I was on. If you have that Icon, click the main screen (upper left) and you should be OK. Let me know if this works.
May 25, 2009 | Asus Eee 701Sd Notebook
THE BOTTOM BAR ON THE LINUX DESKTOP HAS DISSAPEARED
u might have to reconnect to ur network (exp.linksys) to get to internet access but also u might have accidently right mouse clicked on the bottom bar and clicked lock the taskbar so try right mouse clicking on ur screen when not on another program and click personalize or right mouse click where the task bar used to bar and some how unlock it. hope this helps!
Jan 26, 2009 | Acer Aspire One PC Notebook
Only task bar shows up when eee pc is turned on
I had the exact same problem, what helped me out was restoring to factory settings.. When turning it on, press f9 repeatedly right away until a screen pops up with 3 options. choose the option "restore factory settings" or whatever its called and then type in yes. This is restore your eepc to the way it was when you first bought it. It will erase all your personal data, and changes, but it will give you your desktop back!!
Jan 04, 2009 | ASUS Eee 4G Notebook
My start button on my computer is not showing up how do i fix it
If you open the case there is a small wire that runs from your motherboard to the light on the front of your PC. Just unplug it from your motherboard and reseat it. It may have come loose.
Dec 27, 2008 | Dell Dimension 4600 PC Desktop
My Notebook donot Show all desktop Icons
follow these steps;
1) start--all programs--accessories-- windows explorer.
2) you will find 2 sides on the screen , on the left side you will find the first item , desktop .. click on it, so some icons on the right side will appear .
3) on this page also there is a main menu bar , click on tools---folder options .
4) you will find 2 choices on the bar ( generl/ view )
5) press on the view , then you will find a list of choices ,,,
under choice name (hidden files and folders) you will see sub-choice
6) choose show hidden files and folders.
7) press ok .
all icons will be appeard on the left side of your page .
go to the desktop of your computer ( the blue screen ) then in any area with right mouse button press refresh .
you will see all the icons appeared .
good luck ..... Maha - Egypt
Nov 30, 2008 | Lenovo R61 T7300 Notebook
Desktop
hi gauravas, just right click on the desktop then select arrange icon by then goto right pane and check the show desktop icon.
for stable of start menu rotate your mouse to lower down of the scren then your taskbar will popup, right click on task bar and uncheck the Auto-hide the task bar.
Jul 30, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
