Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Potential bad start relay
Kenmore Cold Spot 20 #106.9710680, 16 years old. When compressor starts I hear a 5 second buzzing sound. At times its louder then others. If thru process of elimination I replace it. What does it look like and or where do I find it under the frig. Thanks much.
Karl
  • karl_juers May 11, 2010
    Kenmore Cold Spot 20 #106.9710680, 16 years old. When compressor starts I hear a 5 second buzzing sound. At times its louder then others. If thru process of elimination I replace it. What does it look like and or where do I find it under the frig. Thanks much. Karl
    This is not a side by side, it has the freezer above. I did get a FixYa reply to my intial question.
    I actually suggested that it was probably the start relay vs the over load relay. The person, I think it was John thought it was the same thing. My question yesterday was where will I find the relay under the frig.
5 Suggested Answers
watugot
  • 290 Answers
SOURCE: Kenmore not cooling, compressor cycles on and off
It sounds like the compressor relay mounted to the side of the compressor is out. Very common problem on these units. The replacement relay is supposed to be stronger and less likely to give a problem. Remove the relay and shake it. If you hear it rattling inside it is definately burned out.
Do not replace it with a 3 in 1 or kickstart relay. It will work fine for a few months and burn the compressor out. Get the correct replacement part.
Post back to let me know what you find.
Posted on Nov 19, 2007
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
  • 1169 Answers
SOURCE: my kenmore frig is not staying cold in frig. or freezer
Also check the defrost element in the freezer side mounted on the evaporator coil. They tend to burn out over time causing the coil to freeze up causing the same problem.
Posted on Apr 20, 2009
localwonder
  • 6784 Answers
SOURCE: kenmore refrigatorstart/relay/overload switch has burned spot on
HI. i would recommend to check the relay first, then the compressor last to confirm total failure. If both devices test out ok, this will lead to a failed main power control board.
THE RELAY
The compressor relay starts the compressor. A fault relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator. The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. On some units. the relay may not be covered at all.(each model may vary). Beneath the terminal cover(if equipped), you will find the compressor relay, and the overload protector as well. The electrical terminals of the compressor motor are located here also. Remove the compressor relay by pulling it straight off from the compressor, gently. Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing. Test the relay with a ohm(multimeter), for continuity. Set the meter to the ohms setting X1. With the relay upside down, place the probes into the terminals labeled "S" and "M"(the labeling may vary on each model). The meter should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up). With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The meter should now display an ohm reading of infinity (or the tester should not light up). Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L". The meter should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity. With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M". The meter should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms. Now, if the relay fails these described tests, it should be replaced asap.
COMPRESSOR TEST PROCEDURE
The compressor is accessed from the lower rear of the refrigerator. Generally the same proximity of the relay. The compressor motor can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. The main testing points will be the actual terminal post that hold the relay, gently pull the relay of the terminal box on the side of the compressor, and use the relay holding probes for testing. Once the relay is removed, Place one probe on any terminal and then touch the other probe to each of the other two terminals. The multimeter should display a reading of zero ohms. Be sure to set your meter to 1X before beginning. Now move the first probe to a different terminal and test the other two terminals with the other probe. Finally, move the first probe to the last terminal and test each of the other terminals with the other probe. Every test should have continuity with the multimeter displaying zero ohms. If the compressor motor does not pass all of these tests, the compressor will require professional service. Now test the compressor for ground. With the multimeter still set to X1, touch one probe to bare metal on the compressor housing (it may be necessary to scratch away a little paint to expose the metal). Touch the other probe to each of the three terminals in turn. None of the terminals should have continuity; the multimeter should display a reading of infinity. If any of the grounding tests show continuity, the compressor will require professional service.
Posted on Jan 10, 2010
  • 82 Answers
SOURCE: compressor is making very loud clunk when shutting off.
I think the wire was kinda expensive. If I were you I would try to save the fridge. I think you should unplug it for a couple hours, take everything out for a while and remove any ice. Once the fridge reached room temp, the refrigerant should have made its way back to the compressor. Plug it back in and see if it makes the noise again.
It might just be the fan in the freezer. I would try the unplug/deice for a few hour method first because it is free before you try to replace a fan that might be bumping ice. Good luck!
Posted on Mar 10, 2010
Not staying cold
tell me do you hear a buzzing sound for about 5 sec ending with a click sound. every so often?? if so then you have a start device (relay) problem on the compressor you may think the unit is running b/c the lights are on and fan is on but if you hear that noise coming from the back of the unit while turned on then its the start relay or worse case the compressor is locked up..9-10 though usually its the start device
Mar 15, 2012 | Kenmore Side by Side Refrigerator
I have a Maytag refrigerator model# PTB1953GR, (probably well) over 10 years old, with upper freezer, lower refrigerator and no icemaker. I am a "snowbird" so that it is unused and unplugged for...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Maytag Refrigerators
I have a Kenmore fridge model 53542300 the fridge and freezer are not cooling I can not hear compressor running nor is it hot. I do see the fans running for Fridge and freezer. I went to check the start...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 28, 2010 | Kenmore Refrigerators
Help!i have a maytag refrigerator model #mtb2172hr that stopped getting cold on and off and i hear a buzzing noise on and off around compressor area.the fridge is 5 yrs.old.i hear the motor and fan still...
Sounds like a bad overload relay capacitor on your compressor, or a bad compressor. If it is under 5 years you usually have a 5 year sealed system warrantee that pays for parts and labor on the compressor. It does not pay for a relay overload capacitor. The problem is some warrantee companies will void your warrantee if you or an unauthorized servicer works on your unit. I would recommend you have maytag send out a technician to diagnose this, mainly because I have seen a lot of bad Maytag compressors lately. If it is over 5 years old you can replace the overload relay capacitor and test to see if it works. Before you do this you should remove the old overload relay capacitor from the compressor and do a continuity test between all three terminals and between the terminals and the compressor case. You should have continuilty between the terminals but not between the terminal and the case. If you dont have continuity between the terminals or if you do have continuity between a terminal and the case, then you have a bad compressor. Do not install the new overload relay capacitor as you cannot return these to the parts house once they have been installed. Even after all the tests and even if your compressor starts up you can still have a compressor failure within a couple of days. A technician can hook up your compressor to a tester and determine if it is good or bad. If a compressor is bad it usually costs 900 to 1100.00 to replace through any of the service companies in my area. Not worth repairing. Hope this helps, Appliance Specialists
Dec 15, 2009 | Kitchen Ranges
I have an Amana SxS (model DRS2663B) that is about 8 years old. About a week ago, it started making a sound - kind of a buzz coming from the compressor area (or the little box I identified as a...
You may have a bad relay/overload part number 12555902 runs about $15 but if the compressor is going bad it may not work.If you take the relay/overload off  turn it into your hand and shake it if you it sprinkles out like a pepper shaker go with the OEM part afore mentioned,but if it sounds solid and nothing comes out go with a hard start(SUPCO RC0410 also about $15) it will buy you at least another couple years in which to shop around for a replacement or save the money for a new compressor.You can call Amana to check on the warranty but most only had five years on sealed system.
Sep 27, 2009 | Amana DRS2663B Side by Side Refrigerator
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Kenmore Elite bottom freezer making a clickbuzzzzzzclick sound
you need to check to see if you have a control board by compressor.if not change relay and overload to compressor if you have a grey box with a board in it then you need to most likely change it
Mar 14, 2009 | Refrigerators
Buzzing compressor
heres a part number for the overload relay assy 5304468029.. its mounted on the side of compressor. its a tricky one, usually my experience has been the noise comes from a bad compressor( which you should have 5 year full warr from manufacture). sometimes the overload relay does go bad preventing compressor from starting,the n ew compressor will come with a new overload relay
Nov 19, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
I hear a buzz sound for 5 seconds when compressor starts.
The grommet simply holds the start relay in place.  Unless it is torn, you won't need it.  Likely the start relay.  The buzzing is possibly the relay contacts on the start relay burning if the problem occurs when the compressor starts...although it could be the compressor making noise as well.  You might try to "hear it out".  The start relay gives a boost to the compressor by adding in another winding inside to 'kick' the compressor.
If all you hear is the buzz, you might just wait a bit to see what fails!
Nov 14, 2008 | Refrigerators
Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
Dec 06, 2007 | Maytag MFI2568AE Side by Side French Door...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
