Question about Cuisinart TOB-175 1500 Watts Toaster Oven with Convection Cooking
CUISINART TOB 175 CONVECTION OVEN MANUAL
I BOUGHT AT GARAGE SALE A CUISNART TOB 175 CONVECTION OVEN AND DID NOT GET MANUAL WITH IT. DOES ANY ONE OUT THERE HAVE SUCH? THANK YOU KATHY
  • 30 Answers
Cuisinart has the manual on their website:
http://www.cuisinart.com/manuals/index.php?cat_id=15
Scroll down to the link for the TOB-175.
Posted on Dec 30, 2008
How can I get a copy of instructions for Cuisnart convection oven TOB 165?
Cuisinart has the manual for the TOB-165 on the Product page; it's a discontinued model. See https://www.cuisinart.com/discontinued/toaster_ovens/tob-165.html . The direct link to the instruction book is https://www.cuisinart.com/share/pdf/manuals/tob-165.pdf . (Note: you will need Adobe Reader or a similar program to read or print the manual.)
I hope this helps.
Aug 09, 2015 | Toaster Ovens
Door spring broke on Cruisinart CTO 350 series Toaster Oven
I had same problem with my cuisinar 350 series broken door spring. After disassembly found a broken extension spring measuring about 3/16 dia.,by 6.5 inches long.Spring was broken about a third down. I lifted ,or bended a loop and a halve up from each broken section and joined the two sections together. lifting each loop of the spring is tricky at first, requires a small screwdriver to be inserted between loop to be lifted and then gently bent the loop with needlenose pliers.
Not knowing how to disassemble the unit I had a hard time assembling the unit back.
I would start by taking off the screws holding the front black backlite first, then the main cover.
The main stainless steel cover does not have to be removed completely, by just gently unbending
the cover I was able to access the spring for removal.
Lots of luck
Jan 29, 2010 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Where can I purchase the three knobs for the TOB-30? I cleaned all the ink off of them.
You can get them from Cuisinart at 1-800-726-0190 - the availability varies -sometimes they have them in stock, sometimes they don't
Jul 20, 2009 | Cuisinart TOB-30 Classic 1500 Watts...
Cuisinart TOB-30 toaster oven
I have the identical problem. Where can I find a replacement foot?
Mar 14, 2009 | Cuisinart TOB-30 Toaster Oven with...
Cuisnart Toaster Oven Broiler TOB-165 Element
there not replaceable . metal straps are welded to the ends to make the electral connections . thats why there are no elements for this oven , sorry factory-store-home-dump AS FAST AS WE CAN
Jan 20, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
I have a new toaster oven and the clock won't set properly
I would call Cuisinart - this one has a 3-year warranty, and all they would need is a serial number, not the receipt. Do any of the lights turn on? When you pressed clock, did you hold in the hours button?
-Tha Mp3 Doctor
Jan 07, 2009 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Cuisinart TOB-175
It is roughly 17 inches across from left handle to right handle, but slightly less. About 15.25 inches from front to back.
-Tha Mp3 Doctor
Dec 30, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Lower heating eliments don't heat or glow. Only top ones work
The elements are not orderable, but you can call Cuisinart with your serial number - the product has a 3-year warranty, and that is definitely a defect - will they glow if you put them on Toaster setting?
-Tha Mp3 Doctor
Aug 03, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Toaster oven power failure
Call Cuisinart - that product has a 3-year warranty.
May 06, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Cuisinart TOB-175 1500 Watts Toaster Oven with Convection Cooking Logo
414 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
