Question about Timex T276B Clock Radio
Times Indiglo Nature Sounds Clock Radio T466W
Cannot find the manual and do not know how to remove the setting for snooze. Radio shuts off during the day every 90 mins.
  • Anonymous Apr 03, 2009
    how do I cancel the "sounds" wake up
    Problem Solver:
  • 16 Answers
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS.
Posted on Feb 22, 2009
Push alarm set button then off/reset button. You will see the "00" go off an on.
Posted on Mar 14, 2010
Hold down time set, snooze and slow (button for advancing time) . Hold down all three buttons at the same time and the display should cycle zero thru nine (minutes), let go of buttons when desired snooze time is reached. I'm not sure this will work with your model , but I found it worked with two different clock radios I have just by experimenting with different button combinations. Good Luck!
Posted on Jan 27, 2010
CD player doesn't work on Timex Indiglo Radio Sounds CD player. No manual available. Can't use.
I never have seen this model but guess it's similar to any other CD-Radio model. You can download a manual from here
https://timexaudio.com/media/uploads/product/files/T618_IB59176_84.pdf
It should have a switch to select CD player.
Once you select CD player, open CD lid, insert a CD and play
If won't play, CD player is defective and if you don't know how to repair it you should take it to a repair service and evaluate if it's worth to reapir.
Aug 07, 2015 | Timex Audio Players & Recorders
How do i increase the back light. IT has gone dimmer while setting clock
Press the snooze button 4 times. The display toggles between lo/high brightness. ;-).
Mar 31, 2012 | Sony ICFC218 Clock Radio
How to set alarm on timex t425s alarm clock radio with nature sounds?
T-425s or t425-a-a-(s) by Timex: rotate the clock so the snooze button is on top. The display will show the sun go down and turn on the alarm.
Jan 03, 2012 | Audio Players & Recorders
I need a manual on how to set the time and alarms on fm/am cd clock radio model # rp 5600a
To set the time, press Set (furthest left button in the line including the Snooze) repeatedly until the clock icon shows on the display. Then press the FWD or REV buttons (on either side of the Snooze button) until you reach the current time. Press and hold to advance the time more rapidly. Press Set to save the time.
To set the alarm, press Set until Wake 1 or Wake 2 is shown on the display. Then follow the same directions as changing the time. Press WK1 or WK2 on the front of the clock to select the type of alarm.
The manual for the RCA RP5600 is available on the product page: http://www.rcaaudiovideo.com/audio/clockradios/?sku=RP5600 . See the Support/Manuals tab. The direct link to the manual is http://audiovox2.info/docs/common/RP5600/RP5600_OM.pdf .
I hope this helps.
Oct 22, 2011 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
Hi i have a rca Clock Radio RP5435C i need to know how to set it.
Move the switch on the top back to either the clock symbol to set time or alarm 1 or 2 depending on which one you wish to set. On either side of the snooze button is a fwd and rev button. Push fwd to advance the time or rev to go back. If setting the alarm it will automatically turn the alarm on when you set it. To turn alarm on or off manually, push the button for the alarm you choose on the top rear right side.
Jul 19, 2010 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Timex Indiglo T436B alarm clock
my timex t436b's radio stoped working on f.m. but a.m., audo in works the sounds work so if you have any clue how to fix it please tell me
Sep 23, 2009 | Audio Players & Recorders
Snooze -- NO
sounds like it is working. shut off sensor if you want snooze to work
Feb 16, 2009 | Emerson Smartset Clock Radio
Timex Indiglo Clock/Radio/CD alarm clock
whats the brand and the informations about it ?
Mar 03, 2008 | Audio Players & Recorders
Changing between the buzz and cd setting for alarm clock
From the manual (miraculously, I still have it)...
To switch the alarm sound between buzzer, church bells, radio or CD, press MODE one time, and then press REPORT.
If CD is selected, press TUNING up (>>+) or down (-<<) to select desired wake-up track.
When alarm sounds, press ALM ON/OFF to silence alarm and reset it for the next day.
SNOOZE-BOOST
To postpone the alarm once it sounds, press SNOOZE/LIGHT. Each press of this button will add 10 minutes to the postponement time. (Pressing three times will give you a 30-minute delay).
Sep 14, 2007 | Sharper Image SI686 Clock Radio
Timex T276B Clock Radio Logo
1,435 people viewed this question
Top Timex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Gyula Lacz
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
