Question about Nokia 3120 Cellular Phone
Have nokia 3120 , incoming call does not rings
Incoming ringing tone not coming, even tone folder having ringtones does not rings only a small pick pick sound coming, sometimes
message comes that file format not support even it is inbuilt ringtones.
  • Anonymous Nov 30, 2008
    incoming ringing tone not coming, even tone folder having ringtones does not rings only a small pick pick sound coming
  • Anonymous Mar 19, 2014
    i removed the charging port after suspecting the touch on the port. sometimes it rings. but now then is no ringing sound. but sometimes it rings.
  • 796 Answers
Check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Posted on Nov 19, 2008
Hi just got a alcatel 2036x cheap phone but cant change ring tones can i do it on this cheap phone thanks
go into settings, ring tones , and change it there , can only change to those listed,
Oct 03, 2016 | Alcatel Cell Phones
I have a Nokia E51, which has a theme song for incoming ring tone and I would like to remove it for the normal ring tone, can you help? Cheers Daryl
HERE IS THE STEP BY STEP GUIDE TO CHANGE RINGTONE FOR NOKIA E52.
STEP#1. ON YOUR FIRST MENU GOTO PROFILE SECTION.
STEP#2.SELECT THE PROFILE YOU USE MOST.
STEP#3.CLICK ON IT AND SELECT OPTION CUSTOMISE PROFILE.
STEP#4.SELECT RINGTONE OPTION.
IT WILL SHOW YOU ALL AVILABLE RINGTONE SELECT THE ONE YOU LIKE MOST.
NOW YOU DONE.
Jan 26, 2011 | Cell Phones
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
I have forgotten how to find my ring tones on my nokia cell phone.
you find your ring tones in gallery. In gallery folder you will go to tones folder. Here you get the original nokia ringtones and alerttones.
Jun 21, 2010 | Nokia 5310 Cellular Phone
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
Ringtone for incoming text??
Most samsung models dont let you use ringtones as txt alert. Soz.
May 21, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Ringing time
your phone accepts downloaded audios for ringtons, if you want a long ringtone, you may set a whole song to be your ringtone, or perhaps a long ring ring sound.
or if you only want your regular tones to be longer, try to set the ringer to "ASCENDING"
Aug 09, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Thr ringing tones
Hi. Before you could change your ringtone make sure you have other tunes/music files on your phone. It should be stored on your phone memory. Go to settings >> Incoming call then click the Ringtone, select the location of the tune you want to set as your ringtone. Then when you have accessed your music folder select the tune and then save your settings :) Hope this helps.
Jul 27, 2008 | Samsung SGH-U600
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 15, 2008 | Nokia 1600 Cellular Phone
Ringer doesnt work Nokia 3120
hi follow these instructions
1 menu
2 settings
3 tones
keypad tones (on)
once you have done them settings try your phone and see if it works if not then follow these instructions
1. menu
2 settings
3. profiles
4 general then personalise
the set like this
Incoming call alert (ringing)
ringing tone (choose ringtone)
ringing volume (level 5 )
message alert tone (choose tone)
Keypad tones (on)
warning tones (on)
once you have changed the last setting press back then select activate your phone should be now be working if not let me know ok
Mar 21, 2008 | Nokia 3100
Nokia 3120 Cellular Phone Logo
484 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
