Changed out a Honeywell Thermostat with an Aprilaire Thermostat
I changed out a Honeywell Thermostat HPT 18-60 for my Goodman Mfr. Co. Heat Pump, Model CPKE36-1A with an Aprilaire 8870 thermostat, now I have a bad smell when the Emergency heat comes on.
  • wamsley71 Nov 20, 2008
    Discovered the problem to be that the thermostat was commected for a one stage Heat Pump and not two stage. Thatnks for the help. Don't understand why the difference, but this cured teh smell problem.
The thermostat was incorrectly hooked up for a one stage heat pump and not a two stage.
Posted on Nov 20, 2008
  • 182 Answers
The smell is usually dust on the wires for electric resistance heat.The thermostat shouldnt have anything to do with it.
5 ton goodman package unit not coming on
If you look on the install manual. It says it will work for a heat pump without backup heat. No heat strips.........If you do not have strips the guide says as follows
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
Mar 25, 2014 | Goodman Heating & Cooling
Blower on heat pump blowing with no demand
There is a contact in the blower control card that can stick on. There is also a possibility that the green wire which starts the blower motor could be shorting out with the red wire somewhere inside the thermostat wire. If that is the problem, either pull new thermostat wire, (the rest of the insulation is probably breaking down) or there is some new red link controllers from Honeywell that will completely eliminate wire because the controls are all wireless.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Central heating - room thermostat Honeywell T6360B
hI he has wired the pump to permanant live there should be link between two of them ? cannot recall which . not much help sorry
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
I have a TH8000 Vision Pro. It is controling a
Whats' so hard is the Honeywell thermostat has a built in 1@ differential. It is not adjustable.
You might ask your installer about a time delay relay installed in the furnace to break the thermostat heat wire (usually white wire).
Most time delay relays are 90 seconds. But that might be enough to reduce the furnace cycling.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Trane Weathertron XE1000 Thermostat Wiring
Check to see if you have the system switch accidently on em. heat. The way you have it wired is correct except for the having brown on e. disconnect brown wire and cut ofbare end just in case they have the wire hooked up for constant run on roof.
Feb 08, 2009 | Heating & Cooling
Heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
Nov 25, 2008 | Honeywell TH4210D1005 Heater
Heating & Cooling Logo
316 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
