Question about ASUS Computers & Internet
Problem with built in sd cad reader
The built in card reader in my laptop has to be rebooted after reading one card
  • noboat Nov 19, 2008
    don't know what you mean by front panel usb, it's a laptop with a built in sd card reader slot inthe side. it works fine for one card, then won't work again untill machine is shut down & restarted. it only works once between reboots. thks. noboat
REmove your front pannel usb and try to install it
Posted on Nov 19, 2008
How to insert sd card from my mobile to laptop
You probably need a USB memory card reader that can read SD cards. I do not any brand of laptop that has an SD card slot built-in. You can probably find printers with card slots.
Dec 15, 2014 | Cell Phones
My sd port cannot read ma sd card
Remove the SD card, reboot insert the card. Is your Card reader enabled in Device Manager? Have you done any updates? install the Card Reader driver. Toshiba Support : http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Jan 17, 2013 | Toshiba C855s5214 15.6 Inch Laptop
Do they have a micro sd card reader
Most recent laptops (2006ish and up) have an SD Card reader built into them. Your best bet is to get a Micro SD card adapter and use that to get your micro SD card into the laptop.
May 23, 2011 | Acer Computers & Internet
My Acer 3692WLMi does not read my Fuji 8 gig SDHC card but it will read my Panasonic 2 gig SD card. Can someone give me an answer/solution. Thanks C
While I'm not directly familiar with this Acer model, it looks to be an older laptop. It's almost certain that it was built prior to the SDHC cards being created - a lot of older memory card readers are not able to read the High Capacity (HC) flash cards. I actually own a couple of devices that also would not read the 8GB card.
To test, I would recommend finding a newer USB SD card reader that you could either borrow or purchase (they're usually not too expensive) to see if that reader could get the information from the SDHC card.
If that works, the problem would be that your flash card reader does not support the higher volume cards. This is the most likely possibility.
If it doesn't work, there may be an actual problem with the SDHC card itself.
Hope this is helpful!
May 13, 2011 | Computers & Internet
How do i transfer pictures from cell phone to laptop?
two known options:
-email photo to yourself from the phone.
-this phone seems to have a micro sd card slot - you can insert a micro-sd card and transfer the photos to the card, then read the card on the laptop with a reader that supports micro sd.
so, you should check into the laptop and see if it has any card readers built in since you may need an additional adapter or device in order to connect the micro sd card to the laptop.
some micro sd cards will come with adapters to the larger sizes of mini and standars sd card, which may help.
you might also have luck putting the card from the phone into some other connectible device (ie a camera) and move the files in that manner - but depending on your hardware and software this may not be a viable option (inexpensive to try, though, if you already own some compatible device)
Nov 01, 2009 | LG RUMOR Cellular Phone
Laptop built-in sd card reader won't read
i think your sd card reader has damage and you need to change it
i hope i can solve your problem
Aug 25, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Have a aspire 5735 laptop need to know how to insert sd compact flash disk
If your laptop does not have a built-in memory card reader then purchase an USB multi memory card reader that can read a variety of memory cards such as SM/XD, SD/MMC and CF/Micro drives memory cards.
All you need to do is plug in the memory card into the card reader and then plug the card reader into the computer's USB port. The computer will see the memory card as an external memory device.
Aug 03, 2009 | Aspire Computers & Internet
Vaio won't register micro sd
Have you installed the driver for the SD card reader ? built in vaio ? check within the control panel, devices, sometimes removing the device then rebooting sorts it, press delete on the device within device manager then reboot, check it, should be back and hopefully working
Jun 14, 2009 | SanDisk 2GB microSD Memory Card
Can't insert SD card Evesham Voyager laptop
pls parchesh the cad redar and install the card redear in your laptop in usb slot and fist card is add your card reader and copy all file of data in your laptop and save it you have allso save the pendirve and trnsafre ayour data in other laptop are destop .......................ok
Mar 30, 2009 | Computers & Internet
HP Pavilion ZD8000 Digital Media Reader Issue
Try updating you drivers for your digital media reader. Also check your dcos to see if the DMR will read a 2GB card
Jan 11, 2009 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
91 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
