Question about Vivitar ViviCam 5385 Digital Camera
Lens won't open
My Vivicam5385 lens will come out, all of the settings seem to work, but the lens doesn't seem to open at all. Every picture taken is blank, black...nothing is there.
  • yaralyn Nov 21, 2007
    the lens won't open at all and this happened suddenly
  • dmwittsr Dec 27, 2008
    In any picture taking mode (Auto, Portrait, Landscape, etc) you cannot see the subject (or anything else) through the LCD monitor. All the symbols appear as they should, but the LCD monitor is black. If you take a picture, it comes out black. This camera has always taken good pictures and it has not been used for 3 months. We put new batteries in and re-formated the SD card and the LCD monitor is still black.
    Help!
Lol
Posted on Oct 06, 2008
I don't know about that, because I just repaired my digital camera by taking it apart and straighting the plastic lense on the inside. Now not every digital camera is the same, but if you like to tinker with things like me then unscrew the small screws and explore the inside until you find the problem. It's no that hard if you have a gerneral understanding of machanics Hey if me a 15 year old can do then so can you, besides it makes more scence than buying another one if the other one works just fine.
Posted on Dec 04, 2007
  • 34 Answers
The internal shutter on the lens assy. is stuck.Turn on the camera look into the front of the lens and zoom,it will be possible for you to see if the shutter is open or close. If it is close you may have to replace the lens assy.
Posted on Sep 30, 2007
Cleaning the lens from the inside
Cleaning the lens from the inside is not possible from a practical point of view. However, if you don't care that your camera won't work after you've taken it apart but you just want to see what's inside, then go ahead. If you see dust inside the lens and this is what is concerning you, please know that all lenses have dust inside...it can't be totally eliminated. In 99.999% of cases, the dust doesn't show up on the actual pictures.
Oct 17, 2011 | Casio EXILIM Card EX-S770 Digital Camera
Our camera seems to be okay but when i'm attempting to get picture, i can't see any image in LCD, is it the lens?
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, try taking a picture with the screen black. Is the picture also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 13, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
I can't get the lens to focus at all on any close up setting manual or auto. I have been trying to take pictures of flowers and insects with it set to close up and I have tried also with it on manual...
The 70-300mm lens won't focus closer than about 5 feet (1.5 meters). If you need to get closer, there are several alternatives. Here are some in descending order of cost (and picture quality).
A special "macro" or "micro" lens. Some lenses are designed to focus closer than others.
Extension tubes. These are tubes that fit between the lens and the camera body. By putting more distance between the camera and the lens, the focus point moves closer to the camera.
Close-up lenses. These are like filters in that they screw onto the front of the lens, but act like a magnifying glass.
Sep 04, 2011 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
When I turn on my camera, it shows a black screen, so I'll take a picture anyways and its black.. no picture ..is it fixable or should I throw it away? Next to where the flash goes off..there is a...
Is the lens protector opening in the front of the lens???
If it is and things are still black then throw it out... it will cost more then it is worth to fix...
Lens Errorfix for Digital Camera
heatman101
May 26, 2011 | Fuji FinePix F460 Digital Camera
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
My canon EF-S 17-85 IS USM lens will cause an error 99 when in wide angles at 35mm or less. The iris closes but will not open until I "re-boot" the camera. Other lenses work fine on the camera and the...
Zborn, did you find any solutions? I have had same lense for 2-3 years, taken maybe 10000 shots and just yesterday started to get error 99. Spent most of today trouble-shooting to repeat problem and it seems that when I set to less than 35mm I get the error 99. other settings and my other lense has no problems.
Dec 18, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Cannot see anything in the sd750 LCD
flexible pcb is broken or sutter unit is stuck
Aug 22, 2009 | Cameras
Black screen, black pictures
Set to auto shooting mode, take pictures, if still get black pictures, you need to repalce the lens unit. CCD or shutter defected.
Jul 08, 2009 | Olympus Stylus 720 SW Digital Camera
Pictures are blurry; quality of photos seem compromised
As simple as this may sound, have you cleaned the lens lately? A lot of image quality deterioration comes from a finger print or other smudge on the lens. Digital cameras are succeptable to even the smallest gunk on the lens. Because the lens element is very tiny, use a cotton swab with a drop of lens cleaner (or isopropyl alcohol) to thouroughly clean and dry the lens. If it isn't a dirty lens, check your file-size and flash settings.
May 06, 2008 | Canon PowerShot A95 Digital Camera
Vivitar ViviCam 5385 Digital Camera Logo
631 people viewed this question
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
DMS-UK
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
