Question about Ovens
Macic Chef electric Range stove won't heat accurately.
Oven preheat shuts off unless temp. button held down until temp reaches 105. When oven set to 350 it is more like 200 degrees actual.
ModelGS700 or 38HNGTVWSC, serial5922111465. purchased in 1992
  • Matthew Quinnan
    Matthew Quinnan Nov 19, 2008
    Should I hire a professional? Is it too old to fix?
barkencoa
  • 3463 Answers
SOURCE: my magic chef oven will
If it has a timer, make sure it is set to manual,and not flashing auto.
In the auto mode the oven will not work.
Plz rate this solutioin.
Thanks.
Posted on Jan 01, 2009
mastatech
  • 478 Answers
SOURCE: GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Posted on Mar 14, 2009
  • 260 Answers
SOURCE: Frigidaire stove with oven
I had a similar issue. Did you change the element in the bottom? Make sure you have a good seal on stove.
Posted on Apr 09, 2009
Maytag317
  • 1136 Answers
SOURCE: magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Posted on Jun 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Posted on Feb 26, 2010
Testimonial: "This advise seems right on. Thanks for your fast and detailed advise. Steve"
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
GE Range JSP68 shuts off while preheating
I have an aging JSP68. First, take out the range control (held in by just a couple of screws, disect it, clean it the best you can, dry it. Be careful not to break it because there is no replacement. Pay special attention to the membrane buttons. They tend to stick. Realize the broiler element turns on sporadically to reach the set temp quickly, the bake element should be solid on. Check the "header" (the long double strip of pins) connecting the range control. I had to resolder mine. Another insult was that I baked a bread recipe that required you put water in the oven to generate steam. The steam made this oven literally go bonkers. The relays started to chatter and just a half minute of this will destroy them. Also when you press bake keep it pressed for a few seconds while adjusting the temp to 170 then release. If you don't hear the bake relay click on, try again. Another thing you could try is to press all of the buttons once, this should help to unstick them if any are stuck.
Aug 07, 2013 | GE Profile JTP18 Electric Single Oven
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
Only preheats doesn't reach temp
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 09, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire gas oven, 5 years old, oven pre-heat light comes on and stays on, oven gets warm but not up to temp (it was like this for about an hour), also smell gas when oven door is opened. Burners work...
I don't have a solution, but I was wondering if it constantly beeps until you press the start button? I am having the same problem with my oven preheating. Until we can figure out how to stop this we unplug it and shut the gas off when not in use.
Aug 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Aug 14, 2009 | Magic Chef 9815 Electric Single Oven
Oven wont heat
That depends if the oven is electric or gas.
If it is electric, it can be heating element, temp probe, or control knob/buttons, board and wiring.
If it is gas it can be the igniter (check spark) , the thermostat, the safety valve that prevents accidental gas flow, or the control.
If the oven has self cleaning cycle, check that it is not stuck on self cleaning, try unplugging for a while and restarting self cleaning cycle in that case.
Check also What is wrong with your Range/Stove/Oven?
Mar 29, 2009 | Ovens
Ovens Logo
20 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
