Question about HP LaserJet 3030 All-In-One Printer
PRINTER JAM ERROR
HAVING REPLACED THE FUSER ASSEMBLY I HAVE RE ASSEMBLED THE PRINTER AND AM GETTING A PRINTER JAM ERROR ON THE DISPLAY. THERE IS NO PAPER IN THE PRINTER. I HAVE TRIED CLEANING THE PAPER ROUTE, RESETTING THE PRINTER.
  • 2 more comments
  • bbendall Nov 19, 2008
    PAPER JAM IS IMMEDIATE, PRESUMED I HAD DISTURBED A SENSOR BUT HOW CAN I TELL WHICH ONE, AND HOW CAN I TELL IF IT IS LOCATED CORRECTLY
    PAPER SENSORS DO SEEM TO BE SWINGING FREELY AND IN A POSITION WHICH SEEMS LOGICAL IF THERE IS NO PAPER IN THE FEEDER. HAVE HAD PRINTER ON AND CHANGED POSITION OF SENSORS TO NO AVAIL. ANY OTHER HELP?
    HAVE REMOVED PAPER INPUT TRAY STILL SHOWING PAPER JAM, WON'T PRINT AT ALL AS SHOWING PAPER JAM CLEAR PAPER PATH. ERROR IS PRESENT AS SOON AS PRINTER IS SWITCHED ON
  • comment
    comment May 11, 2010
    Is paper feeding partially, or at all, or is the paper jam immediate? If immediate, you may have disturbed a paper sensor when replacing the fuser. Dis-assemble and check for any broken or out of position paper sensor tabs / switches.
    Scholar:
  • 78 Answers
Paper sensors are pretty simple, in that they are used to sense if the paper has reached, or passed a specific position in the paper path. The sensors are typically small swinging arm like devices which when lifted, switch either on or off. Just check that the sensor arms are swinging freely, and not stuck in a open or closed position, which is what I suspect. If the paper pick-up does not even start to pick up the paper, then likely a paper sensor is stuck, or broken.
Posted on Nov 19, 2008
  • comment
    comment Nov 19, 2008
    Try puting paper in the Multi Media / Multi Purpose tray, and see if you can print from that tray. If the paper tray is removed, then turned on, do you get the same error, or a tray missing error?
  • comment
    OK, This then is a startup diagnostic error, and the diagnostics routine has found a paper path problem.. You may have to do some further dis-assemnbly, and search, but I can assure you that the HP diag routines are thorough, and reliable. If possible, Remove the toner, and gently move the printer around and see if you can hear any loose parts? I know this is kinda non-routine, but the parts broken are typically black plastic, and somewhat difficult to see.
    Aagin, I feel confident that the issue is with the re-seating of the fuser, if you used a maint kit, did you replace any of the pick-up rollers. Those too could be the cause of the problem.
Hp2300 jams half way out of tray 1 and tray 2
1. Up to where paper traveled.. If its reached up to Fuser assembly & curl folds accrued under cartridge.. replace Teflon sleeve or Fuser assembly.
2. If paper traveled up to Fuser out(near 2-3 inch)...Clean/replace/flag Fuser out paper sensor
3. If paper traveled up to registration assembly:Clean registration sensors/flags.
4. Check pickup rollers.
Feb 20, 2013 | HP LaserJet 2300 Printer
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
P3005 jams
Post the exact error message indicated on the printer LCD. 13.01, 02 paper feed issues, worn rollers or jammed paper inside of paper feed assembly.13.05, 06 fusing assembly issues, broken sensor flag in fuser or worn busing on fusing rollers (fusing assembly will be noisy or making grinding sound.) If this the issue being noisy, the fusing assembly has to be replaced along with one of the drive gears, about a 30 min. of work.
Sep 30, 2011 | HP LaserJet P3005 Printer
HAVING A 13.20.00 ERROR CODE ON A HP 43OO. PLEASE HELP!!
JAM IN TOP COVER AREA
A jam exists in the top-cover area.
A 13.20.00 error message indicates that the printer power was turned on or that the printer attempted to initialize while the pre-feed sensor (PS102), the top of page sensor (PS102) and/or the fuser delivery sensor (PS108) was detecting media.
When the paper feed assembly is installed, the sensor-flag spring must be correctly positioned
for the flag to operate. If a paper-jam error message (13.20.00 JAM) appears on the control-panel
display after you replace the paper feed assembly, verify that this sensor-flag spring is installed
correctly.
Hook the spring over the flag tab (see 1 in Figure). Fasten the paper feed assembly to the
chassis with the flag spring positioned in the hole in the transfer assembly. Release the spring
from the tab on the flag (see 2 in Figure). See figure below.
Verify that the flag is held in the upright position, can freely move, and always returns to the upright
position. If the flag does not move freely, or return to the upright position, an error
message (13.20.00 JAM) will appear on the control-panel display when the printer power is turned
on.
Aug 10, 2011 | Office Equipment & Supplies
Displayed always fuser error
It would help if we knew what printer you have but fuser error means that the fuser assembly ( near where the paper exits that fuses the toner to the paper ) is defective in some way. In most cases you need to replace the fuser assembly.
May 29, 2011 | Office Equipment & Supplies
13 Paper Jam - but there is no paper inside!
I have a long solution (possibly) to your issue:
Error 13 Paper Jam
  • Paper jams can occur in 3 places: Entry, registration and exit.
  • If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
  • If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
  • If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
  • Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
  • On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
  • Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
  • Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
  • On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
  • On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
  • On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
  • Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
  • On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
All this comes from:
http://www.fixyourownprinter.com/reference/errorcodes/hp
Good luck with it, I love the HP LaserJet 4 series of printers. I used to warm my coffee on the top of the fuser when I was doing large print jobs :-)
If this information helps, please give me a rating, thanks!
OpenSource13
Apr 07, 2009 | HP LaserJet 4 plus Printer
Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
Jan 30, 2008 | Ricoh Aficio AP2000 Laser Printer
Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Jan 23, 2008 | Xerox Phaser 7300DN Laser Printer
Paper jam problem in laser printer 4100
if this happens every time you need to replace the fuser. but there is a possibility it could be the main gear drive assembly, 9 times out of 10 it's the fuser. a gear on the fuser usually breaks a few teeth. the fuser is very easy to replace and is a part that will eventually need replacing on all printers.
Jan 07, 2008 | HP LaserJet 4100 Printer
HP LaserJet 3030 All-In-One Printer Logo
349 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
