Question about HP Compaq nx6310 Notebook
Print Spooler service not running
I have HP Compaq nx6310 notebook. I just cleaned the system of some spywares yesterday. I discovered today that printers attached links are all gone.
When I tried to do the add a printer task, I got an error message "operation could not be completed. The print spooler service is not running"
Please help out.
  • samsher Sing Jan 10, 2009
    please send print spooler service
  • charles lane Feb 12, 2009
    printer spooler will not strat
    Genius:
  • 1,124 Answers
Go to Start, Control Panels, Administrative Tools, Services.
Windows 2000: Go to Start, Settings, Control Panel, Administrative Tools, Services.
Right click on the print spooler and select Properties.
Click on Dependencies to view a list of all the system components that the print spooler depends on.
Under Services, go to each of these dependencies and check the properties. In each case, ensure that the Startup type is set to Automatic, and that the Service status is set to Started.
Posted on Nov 19, 2008
Spooler turned off
The print spooler servie might be turned off.
Click on start go to run type services.msc
locate print spooler double click it and then select startup type automatic and then click on start. close all the windows, restart the computer and then try again it should work.
Jun 22, 2010 | HP Photosmart C5280 InkJet Printer
My compaq Nx6310 notebook pc can not detect the USB ports when using windows XP
loadTOCNode(2, 'resolution'); To fix this problem on a Windows XP-based computer, you must be running Service Pack 1 (SP1) or later. To determine if you have Windows XP SP1 or later, click Start, click Run, type winver, and then click OK. If SP1 or later is not listed in the About Windows dialog box, then use Windows Update (http://windowsupdate.microsoft.com) to install the latest service pack before you try to fix this problem.
this will be the link : http://support.microsoft.com/kb/314634
ERNZ
Feb 09, 2010 | HP Compaq nx6310 Notebook
I have been using my printer often, but today I am told: ''Print spooler service is not running.'' so it will not print. What should I do to correct this so it will print?
Turn on the Print spooler service from Services.
Click Start > Run
Type services.msc
Services window will open
Look for the "Print Spooler" Service in the list.
Oct 13, 2009 | HP Photosmart C5180 All-In-One InkJet...
Compaq computer running vista trying to add a printer message local print spooler is not running I have started the print spooler through admin tools but everytime I close the control panel it must switch...
Start the simple route: uninstall and reinstall the printer and its software. If the software is old, head to the printer manufacturer's website and download the latest driver package.
Meanwhile, track back to when the print spooler worked successfully. Was there any new software installed that may have caused the problem? A possible update from Windows, perhaps?
Sep 24, 2009 | HP Compaq Presario C500t Notebook
Cannot restart services error 1068
To resolve the problem, fix the dependency information for the Spooler service.
Click Start, Run and type the following:
CMD /K SC CONFIG SPOOLER DEPEND= RPCSS
Alternately, to accomplish this using Registry Editor: Click Start, Run and type Regedit.exe
Navigate to the following branch
HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Services \ Spooler
In the right-pane, double-click the DependOnService value
Delete the existing data, and then type RPCSS
Close Regedit.exe
And workstation is only needed if you are on a network.
May 11, 2009 | HP Compaq Evo n400c Notebook
It does not give any sound
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP Windows version of the drivers you require and install them.
Use this link to download the drivers
http://h18000.www1.hp.com/cpq-country/cpq_support.html
May 10, 2009 | HP Compaq nx6310 Notebook
Print spooler service not running on Windows XP
Spooler depends on the RPC service being running. But you really need to get into event viewer and check for anything related to either RPC or Print Spooler. If you're trying to print to a network printer you could have firewall issues either within Windows or your router. Think about what changed on your system around the time this problem began.
Dec 30, 2008 | HP Pavilion dv6000z Notebook
How to remove keyboard HPcompaq nx6310?? cause, I want to clean the headsink
Here's a link to the maintenance and service guide for the nx6300 series. It has keyboard removal instructions and diagrams.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00805752/c00805752.pdf
Jul 23, 2008 | HP Compaq nx6310 Notebook
HP Compaq nx6310 PC Notebook Problem
Start your system enter BIOS, under the configuration settings disable SATA NATIVE MODE. Save changes and exit. Boot from the CD format.
Jul 02, 2008 | HP Compaq nx6310 Notebook
Stuck print on HP Deskjet F380
Did you restart the computer? I know, a little obvious. But restarting should clear out the print queue.
I think what you're thinking of is typing services.msc at run. There you can stop the print spooler.
You can also get to 'services' by going to control panel > administrative options > services.
May 20, 2008 | HP Compaq dc5700 Microtower - Free Flat...
HP Compaq nx6310 Notebook Logo
130 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
