Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
How do I set up a network
I got a reply from Rasheed Peters but after following the steps my I could not get back into my computer. I'ts safe to say that I am clueless with computers but I know there must be a way.
The IT guy at work explained that because my laptop is set up for work and logged into a domain I can't setup another network. I'm running windows XP. I want to play red alert against a friend at home. Got the cables and everything so all I need is a plan.
Is there any way of setting up a network so I can play this game without disturbing my office settings?
    Genius:
  • 1,913 Answers
Ya sure
first u need administrator password if any guy gives admin pasowrd for local system.
then alos if your it guy give u password for llocal system or domain adminpasword.enter in windows.u must have to enter in adin user for set this setting for your account .
go to my computer right clik u see manage then user and groupas then groups then u see in right pane side administrator
then u see bottom add button press on it.
then find your user name on the domain then add it in.then ok.
thats it.u have all right for this laocal pc.
Posted on Nov 19, 2008
My problem is that i cant figure out why i cant get internet on my D-Link router and i cant figure out how to scan it?
Scan for network will not work because of 2 reason
some times the Software utility causes the Problems
start - run - msconfig .. stop the services
but check the following ..
Check the Following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2.Find and double-click “Network Connections” to open up the list ofconnections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field onpaper, and store it in a safe place. THIS IS YOUR WEP KEY, it will beneeded later on.
* Click “Save Settings”
Jan 24, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
If your connection remains non-functional, run the Windows Network Repair utility on your computer.
If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Tip
HOW TO CONFIGURE WIRELESS ADAPTERS TO ADHOC MODE
Don't have a router and want to connect the two wireless computers with each other you need to set up both computers to an adhoc mode.If using Windows XP in your desktop computer follow the steps below to configure the wireless adapter to adhoc mode.
Go to control panel> Network Connections> Right click on wireless network then hit properties> Click on Wireless network Tab and removed everything under preferred networks. Click on Add button then type on the Network name SSID "Linksys". Remove the check for "The key is provided for me automatically" then enter the network key. Make sure that you enter 10 or 26 characters on the network key box. You can only set a network in using alphanumeric characters. You can create a network key by using numbers only,letters only or combination of numbers and letters from 0-9 or A-F characters. Put a check mark on the box says "This is a computer-to -computer (adhoc) network." Hit the ok button. Under the preferred networks highlight the SSID that you have set "Linksys"then hit the advance button. Click on computer to computer [adhoc]networks only then hit close and ok all the way out.
You need to do the same thing on the laptop where you have the installed a wireless adapter. SSID and network key should be the same on your network card. It should be set to adhoc as well.
Both computers must have static IP address. For the desktop computer you can set an IP address of 192.168.1.2 and the subnet mask is255.255.255.0. The laptop must have an IP address of 192.168.1.3 and the subnet mask is 255.255.255.0.
From the desktop computer, under network connections right click on wireless network connection then click on view available wireless network. Highlight Linksys then hit connect. Do the same thing on the laptop. Once they are both connected try to ping each other and see if you will get reply. To ping the laptop from the desktop computer,follow the steps below:
a.On WinXP/2000:
Click Start > Run. On the Open field type cmd then hit OK. On the DOS prompt type ping 192.168.1.3 then hit enter.
b.On Win98/Me
Click Start > Run. On the Open field type command then hit OK. On the DOS prompt type ping 192.168.1.3 then hit enter.
Do the same thing on the laptop but instead of pinging the 192.168.1.3you need to ping the 192.168.1.2.
If you got replies it means that you are already communicating with each other.
If you are getting a low signal you may change the channel on the adapter. Follow the steps below on how to change the settings of the adapter:
For Windows XP and 2000
Right click on my computer properties>click on hardware>device manager>under network adapters right click on wireless-G notebook adapter then select properties>click on the Advance Tab then look channel then change it to 11. You may try to use other channels like1, 6, and 9.
For Windows 98 and ME
Click start>control panel>network>look for wireless-G notebook adapter with a green icon left beside it then double click on it>click on the Advance Tab then look for channel then change it to 11. You may try to use other channels like 1, 6, and 9.
Hope this help everyone.
on Jan 26, 2010 | Computers & Internet
Wireless card does not connect to Linksys router, all other computers have no issues. I have a Toshiba M55-S331 with Intell Pro 2200 BG wireless card
Check the Following
Windows XP
* Push “OK”
# Click “OK”
# Click “Wireless”
For WEP:
* Click “Wireless”
* Click “Generate”
Jan 24, 2010 | Intel PRO/Wireless 2200BG 802.11g/b
Setting up wireless connection on aceracer, aspire sa90- wireless connection
Check the Following
Windows XP
* Push “OK”
# Click “OK”
# Click “Wireless”
For WEP:
* Click “Wireless”
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
Jan 18, 2010 | Zonet Fast Ethernet Adapter Realtek 8139D...
My wireless picks up my network but wont connect. It doesnt even ask for the pass key, which it does for other neighbour networks. I have just wiped my computer.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 28, 2009 | ASUS Computers & Internet
Help wireless usb adapter connected to my computer but will not connect to the internet. i have got a wireless broadband box with sky it would be great if you could help me many thanks
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router
Nov 27, 2009 | Belkin Computers & Internet
Bought Netgear wireless G network starter kit for my Fujitsu Siemens ESPRIMO Mobile V5535 - the router came with a usb adapter which I stupidly used on my wireless-capable computer. However, I used it...
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Mar 16, 2009 | NetGear WG111 802.11g/b Wireless Adapter
I can't set up my wireless protection security error message " wireless security unable to set up"
hi i guess you must reset the router to factory defaults, then setup the router again from scratch. If you saved a router configuration file, DO NOT use it. To reset your router to factory defaults, use the following procedure:
1) Power down all computers, the router, and the modem, and unplug them from the wall.
2) Disconnect all wires from the router.
3) Power up the router and allow it to fully boot (1-2 minutes).
4) Press and hold the reset button for 30 seconds, then release it, then let the router reset and reboot (2-3 minutes).
5) Power down the router.
6) Connect one computer by wire to port 1 on the router (NOT to the internet port).
7) Power up the router and allow it to fully boot (1-2 minutes).
8) Power up the computer (if the computer has a wireless card, make sure it is off).
9) Try to ping the router. To do this, click the "Start" button > All Programs > Accessories > Command Prompt. A black DOS box will appear. Enter the following: "ping 192.168.1.1" (no quotes), and hit the Enter key. You will see 3 or 4 lines that start either with "Reply from ... " or "Request timed out." If you see "Reply from ...", your computer has found your router.
10) Open your browser and point it to 192.168.1.1. This will take you to your router's login page. Leave the user name blank, and in the password field, enter "admin" (with no quotes). This will take you to your router setup page. Note the version number of your firmware (usually listed near upper right corner of screen). Exit your browser.
If you get this far without problems, try the setup disk (or setup the router manually, if you prefer), and see if you can get your router setup and working. If you still have trouble setting up wireless security, please explain exactly what you are trying, and exactly what is (or is not) happening. What exactly is stopping you from setting up wireless security?
If you cannot get "Reply from ..." in step 9 above, your router is dead.
If you get a reply in step 9, but cannot complete step 10, then either your router is dead or the firmware is corrupt. In this case, use the Linksys tftp.exe program to try to reload your router with the latest firmware. After reloading the firmware, repeat the above procedure starting with step 1.
If you need additional help, please state your ISP, the make and model of your modem, your router's firmware version, and the results of steps 9 and 10. Also, if you get any error messages, copy them exactly and report back.
Please let me know how things turn out for you.
Dec 23, 2008 | Computers & Internet
Wireless network card & sky broadband wireless router
5. Power cycle.
Oct 20, 2008 | NetGear RangeMax NEXT WN511T...
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
41 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
