Question about LG 42LP1D 42 in. LCD HDTV
LG 32'' LCD TV aspect ratio self switching
Hello everybody, I discovered this forum surfing the net to find a solution for a problem I have with a new 32" LG LCD TV.
When I use DVD player or VCR on AV1-2 input, regardless the aspect ratio I select, after 10 minutes or so the aspect ratio switches back to 16:9. I tried with 4:3, 14:9, Zoom 1 or 2, Original. In all cases after a few minutes it's on 16:9 again. It id annoying at best. It seems that there is an automatic aspect ratio setting up functionality, working in a slightly odd way. Anu suggestions?
Thanks in advance for cooperation.
Massimo Moruzzi
Italy
  • Anonymous Jan 04, 2009
    i will change it to fit the screen after a few minutes it will be 16:9 again.. should nt expect this from technology these days.
  • timokl Apr 14, 2009
    Just as described -- the TV switches to widescreen after some minutes, when I have set up the correct aspect ratio for the programme. Very annoying.
  • 3 Answers
I have an LG LCD TV with the same problem.
The solution is to go to
MENU
OPTIONS
FACTORY RESET
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Posted on May 17, 2009
Yes,that fixed my problem,my son had switched to "store" mode thinking it would brighten up the picture, then the tv started switching to 16.9 mode for all channels,setting it back to home mode fixed the problem,thanks FixYa.
Posted on May 10, 2010
Not a real solution actually. The store where I purchased the TV changed mine with another one...
Regards,
Massimo Moruzzi
Posted on Nov 30, 2008
How to change aspect ratio on lg rz-32lz55?
Any chance you are using a box with this set for signal?
Dec 17, 2012 | LG RZ32LZ55 32 in. HD-Ready LCD Television
I have recently purchased a LG LCD TV Model 32LK330. Everything seems to work fine except all of the people look as if they had gained an additional 100 pounds. Is this distortion natural.
It is aboslutely normal. The aspect ratios on LCDs are different from the good ol' CRTs and CRT based projection tvs. As a matter of fact when I got my first LCD tv, it took me a few months to get used to it. You can try other aspect ratios though by going to Menu-> Picture->aspect ratio and try the different settings available to see if any of them works for you.
Jul 14, 2011 | LG Televison & Video
A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
Jun 07, 2011 | LG 32LG30 32 in. LCD HDTV
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Aug 16, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Edges of picture being cut off LG 37LG30 LCD TV
Yes, it is possible the settings from your cable box maybe set to the wrong ratio eg:letterbox. Depending on what type of box you have, look in the cable box menu for a settings option, then change the aspect ratio to a different format.
Jun 30, 2009 | LG 37LG30 37 in. LCD HDTV
32LG30 LCD TV screen aspect 4:3
I went into options or menu on LG remote and checked 480i and it worked.
Jan 10, 2009 | LG 32LG30 32 in. LCD HDTV
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
Ilo tv
You need to change the aspect ratio of the screen. The cable box remote has an aspect ratio button and the tv remote also has an aspect ratio button or picture size button. You are probably on a zoom aspect since its too big.
Nov 13, 2008 | iLO 3200 32 in. LCD Television
Heads cut off and no score...
Try your setting on your cable box (Screen position)
also maybe wide mode try switching to wide zoom good luck
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
LG 42LP1D 42 in. LCD HDTV Logo
3,427 people viewed this question
Henry  Thomas
Henry Thomas
