Question about Nokia 2100 HANDSFREE BOOM MIC Headset
Nokia 2100 shows no signal after dropping
My phone was set to vibrate, when it rang it fell off the bannister down one floor and no shows no signal..? What do I do? I have taken out the battery turned it back on and still no signal when there was plenty of signal previously.
SOURCE: Signal Problem with Nokia 2100 Mobile
You need to get it to a cell phone repairing service.
Posted on Aug 04, 2007
0 characters
1 Points
Bluetooth connectivity issues
My router extender did that once. A simple powered down and restarted fixed it. I hate to sound like Comcast which always tells you to do that but it's worth a try with wifi and bluetooth. Also obvious but check the battery, when it gets low enough the signal gets weak before it actually stops. Cellular telephones do the same thing. A low battery can affect signal strength.
Mar 16, 2014 | Motorola Headsets
The phones imei no is 358647040505733 and it doesnt want to connect to wifi,i tried formattting it but everything went out and i cannot reore factory settings to the phone without it..please help.thank you
Try hard reset Nokia 603, press the keys; Green (Call), Red ( Reject) and Camera whilst powering ON. you need to release power button only after first vibration keeping other three depressed until Nokia "Shaking hands" logo appears.
Nov 06, 2012 | Nokia 603 black
I have an old nokia head set i can't get it to conect to my nokia 5530
Hi,you can use this instruction below to connect your Nokia headset to your Nokia 5530 .
After following the instruction and it does not work,that means your headset will need to be tested on another phone to be sure it's working properly.
How to Pair (Connect) a Bluetooth Headset to Your Phone
So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
Things You'll Need:
* A Bluetooth cellular phone
* A Bluetooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the bluetooth menu.
On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
Have a nice day.....
Feb 22, 2011 | Nokia Headsets
I cannot pair my Nokia N95 with HBH-608 Akono headset
Press and hold down the headset volume key in the centre. Hold it for about 5 sec. The led will now flash on/off in red. This is the pairing mode. Set your mobile phone to blue tooth discovery mode,until it finds the headset, key in the pass key, 0000. It should now work. You may need to set the phone to select the headset as an automatic connection so it connects whenever it is on and in range.
Jul 15, 2008 | Sony Ericsson HBH-PV705 Headset
The light from my phone is not showing
its LCD connection is loose , it need to tight everything will be ok
Feb 14, 2008 | Nokia Handsfree With On/Off Button For...
No signal
May i know the phone model you are using? to locate the signal the steps are, go to menu -> settings -> phone -> operator selection-> select manual-> than you can select your network. but for that you must be in your network range.
Jan 09, 2008 | Sony Jabra Earbud Headset - Ericsson T610...
No signal
hi ive got the same signal. ihavent opened mine. im not sure how to. let me know if you get it fixed, what the problem is thanks trish
Sep 16, 2007 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Aug 04, 2007 | Nokia 2100 HANDSFREE BOOM MIC Headset
If the phone didn't come with FM the phone can't be upgraded with FM. There is no way of making the phone recieve FM-transmissions without a built-in FM-reciever. The built-in antenna is tuned for a different range of signals and can't be "tuned" to recieving FM.
Feb 27, 2007 | Nokia (6708) Consumer Headset
Headsets Logo
99 people viewed this question
Top Nokia Headsets Experts
Are you a Nokia Headset Expert? Answer questions, earn points and help others
