Question about Acer Aspire 5500 5570-2609 Laptop
When I turn on starts shows microsoft windows then goess to startup repairs
Can go to recovery option but will not recover from backup disc, system restore under problem signature say auto repair will not repair
signature 09 says fix partion table
signature 10 says 1168
under repair action only failed action partion table repair error code 0x490
root cause found no OS on disc
can get to command promt
What do I do now?? I the same problem, but I am way over here in Iraq. I need help asap cause this is my only menas of entertainment. PLEASE SEND HELP!!!!!!
    Scholar:
  • 65 Answers
Maybe to start the computer in Safe Mode will work, maybe system restore will work from there. Basically to do this with XP as your Operating System, press the power button and immediately start tapping the F8 key, this will take you to a screen with options, here is a more detailed overview of that:
Start the computer in safe mode To start the computer in safe mode
  1. You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
  2. Click Start, click Shut Down, and then, in the drop-down list, click Shut down.
  3. In the Shut Down Windows dialog box, click Restart, and then click OK.
  4. When you see the message Please select the operating system to start, press F8.
  5. Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
  6. If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
when I turn on starts shows microsoft windows then - note.gif Notes
  • In safe mode, you have access to only basic files and drivers (mouse, monitor, keyboard, mass storage, base video, default system services, and no network connections). You can choose the Safe Mode with Networking option, which loads all of the above files and drivers and the essential services and drivers to start networking, or you can choose the Safe Mode with Command Prompt option, which is exactly the same as safe mode except that a command prompt is started instead of the graphical user interface. You can also choose Last Known Good Configuration, which starts your computer using the registry information that was saved at the last shutdown.
  • Safe mode helps you diagnose problems. If a symptom does not reappear when you start in safe mode, you can eliminate the default settings and minimum device drivers as possible causes. If a newly added device or a changed driver is causing problems, you can use safe mode to remove the device or reverse the change.
  • There are circumstances where safe mode will not be able to help you, such as when Windows system files that are required to start the system are corrupted or damaged. In this case, the Recovery Console may help you.
  • NUM LOCK must be off before the arrow keys on the numeric keypad will function.
    If this doesn't correct the problem you may be able to try the recovery in safe mode.Then depending on what disks you have available some of the below may be an option.
    Repair overviewWindows XP includes several features to ensure that your computer and the applications and devices installed on it work correctly. These features help you solve the problems that can result from adding, deleting, or replacing files that your operating system, applications, and devices require in order to function. Most of these features are available on all three versions of Windows XP: Windows XP Home Edition, Windows XP Professional, and Windows XP 64-Bit Edition. The recovery feature or features that you use depend on the type of problem or failure you encounter. Use the following list to determine which features to use to address a specific problem.
    Feature: Recovery Console
    When to use it: If using Last Known Good is unsuccessful, and you cannot start the computer in Safe Mode. This method is recommended only if you are an advanced user who can use basic commands to identify and locate problem drivers and files. To use the Recovery Console, restart the computer with the installation CD for the operating system in the CD drive. When prompted during text-mode setup, press R to start the Recovery Console.
    What it does: From the Recovery Console, you can access the drives on your computer. You can then make any of the following changes so that you can start your computer:
    Enable or disable device drivers or services.
    Copy files from the installation CD for the operating system, or copy files from other removable media. For example, you can copy an essential file that had been deleted.
    Create a new boot sector and new master boot record (MBR). You might need to do this if there are problems starting from the existing boot sector.
    Available on: All versions of Windows XP.
Posted on Nov 25, 2008
  • hdpanama
    hdpanama Nov 25, 2008
    Please ignore the "Start the computer in safe mode" entry at the bottom of my previous post, or it may be just above if this was posted onto my previous post
    Hope this helps,
    Matt
It is looking for the windows automated system recovery disk and I have reistallation cd. how would I get this
You will need to create one.
Windows system errors, crashes and other problems may lead to a malfunctioning system or an operating system that doesn't load properly. You can create a Windows system-repair or automated recovery disc that contains tools for fixing the operating system. The CD you create will contain system-recovery options and tools like Windows' Startup Repair, System Restore and the Windows Memory Diagnostic tool.
Insert a CD into the CD/DVD-ROM drive. Click the "Start" button. Type "backup" in the search box and click the "Backup and Restore" search result entry. Select the "Create a System Repair Disc" option in the left column. Click "Yes" or "OK" if a user account control message appears. Click the "Drive" drop-down menu and select the name and letter of your CD/DVD drive. Press the "Create Disc" button. Wait for the progress bar to turn completely green and Windows to finish the repair disc. Click "Close" and then "OK" to exit the repair disc wizard. Hope this helps.
Jan 04, 2013 | Dell OPTIPLEX 745 PC Desktop
Tip
How to perform a Sony VAIO System Restore
NOTE: A recovery also can be performed using recovery discs.
  1. Close all open programs and turn off the computer.
  2. Disconnect all network connections.
  3. Disconnect all peripheral devices.
  4. Turn on the computer.
  5. When the VAIO screen is displayed, press the F8 key.
  6. At the Advanced Boot Options screen, ensure Repair Your Computer is selected and press the ENTER key.
  7. In the System Recovery Options window, under Select a keyboard layout: , click the Next button.
  8. Under To access recovery options , next to User name: , click the down arrow , and click to select an account with Administrator rights.
  9. Next to Password: , type the appropriate password for this account.
  10. Click the OK button.
  11. Under Choose a recovery tool , click to select the desired option: NOTES:
    • The Startup Repair option can automatically resolve certain issues that can prevent the operating system from starting.
    • System Restore can return the computer to a previous configuration of the operating system when it was working properly.
    • Windows Complete PC Restore will restore a previous backup of the computer created using the Windows Backup and Restore Center .
    • The Windows Memory Diagnostic Tool can determine if any problems being experienced are caused by issues with the computer's memory.
    • The option to open a Command Prompt can be used by advanced users and technical support personnel to perform troubleshooting on the hard drive or the operating system.
    • Clicking VAIO Recovery Center will launch VAIO Recovery Center from the Recovery Disc.
on Feb 11, 2010 | Computers & Internet
F9 doesnt work on asus a52f just says windows 7
You might try the Delete or all the F function keys also some computers use cntrl +alt +delete
http://download.cnet.com/%7Bvalue=http://www.download.com/keyfinder-thing/3000-2094_4-10491989.html Finding lost application install keys is quick and simple with this handy executable, a complete rewrite of a well-received earlier version.
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer." If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option. g) At the DOS prompt type the following three commands: bootrec.exe /fixmbr bootrec.exe /fixboot (may return an 'Eliment not found' message) bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
Hope this helps. Keyfinder Thing's simple, easy-to-understand interface has Wizard-like efficiency. This application quickly scans your system registry for 90 supported software titles and displays product names and icons in the result window. Single-button clicks copy all keys to either a text or HTML file. b> http://download.cnet.com/product-key-finder/3000-2094_4-10694022.html Product Key Finder is a single function utility that executes in a GUI, but displays a Command window result. You merely double-click it to display the 25 character Microsoft Windows Product Key. then store it away for safe keeping not on your computer
Dec 08, 2012 | ASUS A52f-xe4 15.6" 2.13ghz 4gb 320gb...
When I turn on the computer it says boot mgr is missing. I guess I totally messed up when I tried to do a full system recovery. The discs I have are from geek squad there is tow of them.
An operating system would have been nice ?
How to Create a Windows 7 System Repair Disc:
or
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
bootrec.exe /fixmbr
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
hope this helps
Nov 24, 2012 | eMachines ET1810-01 PC Desktop
I need to find a set up disc
What operating system set up disc are you referring to ?
bootrec.exe /fixmbr
http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid
windows xp pro start up disc
http://systemdiscs.com/?utm_source=neosmart&utm_medium=article&utm_campaign=Vista_Recovery
vista recovery disc
Hope this helps.
Nov 20, 2012 | Computers & Internet
How do I make a recovery disk?
Which operating system ?
there are some you can download
If you computer crashes and your hard drive fails, you can lose a lot of data and spend a great deal of time trying to find all your discs and re installing all of your information.
It can be very difficult to find and re-install your operating system if you do not have the original CDs that came with your computer.
But if you create a recovery CD for your computer, the restore process can be much faster and quite easy.
Put the blank CD in your CD writer.
Click on the Windows Start button.
Click on the Control Panel option.
Click on Backup Your Computer from under the System Maintenance section option.
Click on the Backup Your Computer button on the Backup and Restore menu.
Select your CD drive from the drop-down list and press the Next button.
Click the Start Backup button to begin the backup process.
you might need to use dvd rw depending on the size of the backup
This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you dont have a Windows installation disc, cant find your Windows installation disc, or cant access the recovery options provided by your computer manufacturer.
or
b) Select the correct keyboard input method and click Next.
Note If you are using the Windows7 Install DVD then at the Install Now prompt (Do not pick the Install Now option) instead choose the Repair your computer option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that Windows found problems with your computers startup options.
Do you want to apply repairs and restart your computer ?
d) Click Repair and restart and reboot again to the Windows 7 System Repair environment.
e) Click Next at the keyboard selection prompt and when the System Recovery Options screen appears verify that the Use recovery tools that can help fix problems starting Windows is selected.
Click the Next button.
f) Now from the menu list select the Command Prompt option.
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an Eliment not found message)
h) Close the command prompt window and click the Startup Repair option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages Windows cannot repair this computer automatically and Startup
Repair cannot repair this computer automatically.
Ignore the Send/Dont send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Dont send window.
Next click on the View advanced options for system recovery and support option and from the main menu once again click Startup Repair.
This time the repair process may only that a few seconds and when prompted Startup Repair could not detect a problem, click Finish and run the Startup Repair option one more time, click Finish, and then remove the System Repair DVD and click Restart.
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
vista recovery disk
not longer free
hope this helps
Oct 22, 2012 | Compaq Presario CQ70 Laptop AC Power...
HP dv6000 turion processor. machine starts and all blue lights appear. dvd briefly lights and then machine turns off and then turns itself back on and repeats the process.
Preforming a system recovery to return the computer to its original condition may be necessary if the operating system is damaged, or the hard drive is corrupted, or the computer is infected by a virus.
___Also look this> HP expanded the battery pack recall on May 19, 2010. Click here to validate your battery. Performing a system recovery removes all software and files saved to the hard drive, reinstalls the original operating system, and then configures the settings for the default programs. Since the merger of Compaq and HP, several different recovery tools and processes Names for these tools include: Recovery Solution, Recovery Manager, F11, Recovery Disc, Driver and Application Recovery Disc, Roxio BackOntrack, Microsoft Backup & Restore. have been provided for recovering notebook PCs to their original operating condition. To help you select the correct recovery process, the table below identifies the different models, the time frame when they were produced and sold, plus the originally configured operating systems. Click on the name of the document in the right column for detailed information. Choose the Correct Recovery Process for Your Notebook Notebook description Recovery procedure information HP and Compaq Notebook PCs and Mini PCs shipped with a Windows 7 operating system. Recover Windows 7 Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Windows 7 instead of an HP solution. Recover Windows 7 Operating System Using Microsoft Windows Backup and Restore Presario, Pavilion, and HP Compaq Business PCs shipped with a Windows Vista operating system. Recover Windows Vista Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Vista instead of an HP solution. Recover Windows Vista Operating System Using Microsoft Windows Backup and Restore HP and Compaq Mini with Windows XP using the HP solution. Recover Windows XP Operating System On Mini Notebook Using HP Recovery HP and Compaq Mini with Windows XP using the Roxio recovery feature instead of the HP solution. Recover Windows XP Operating System Using Roxio BackOn Track HP and Compaq Mini with Mobile Internet Environment (MIE ). Recover Windows MIE Operating System On Mini Notebook Using HP Recovery Presario, Pavilion, and HP Compaq Business PCs manufactured and sold in 2006 or later . Recover Windows XP Operating System Using HP Recovery (2006 or Later)
Presario and Pavilion PCs manufactured from 2001 and 2005 . Recover Windows XP Operating System Using XP Operating System Discs (2001 to 2005)
And
Recover Applications Using Drivers and Applications Recovery Disc (2001 to 2005) Pavilion PCs with Windows Media Center edition of XP manufactured from 2001 to 2005 . Recover Windows XP Media Center Edition Operating System on HP Pavilion PCs Using HP Recovery (2001 to 2005) Compaq Presario PCs supplied with a Compaq Recovery CD and manufactured from 2001 to 2005 . Recover Windows XP Operating System on Compaq Presario PCs Using HP Recovery (2001 to 2005) Omnibook and certain Pavilion PCs manufactured pre-2001 . Recover Windows XP Operating System and Applications on HP Omnibook and Pavilion models Using HP Recovery (Pre 2001)
Nov 13, 2010 | HP Pavilion dv6000z Notebook
WINDOWS WILL NOT START - CANNOT START IS SAFE MODE OR ANY OTHER
OK try doing this below.
You will have to use a Windows DVD and boot on it, try a "Repair" install, If this doesn't "Take" then you will have to do a complete reinstall.
Feb 11, 2010 | Sony VAIO Notebook
I can't restart my window vista laptop solve plz
Windows Vista is not starting due to missing or corrupt files.
Run Startup Repair using Vista Operating System disc
  1. Place the Windows Vista Media Backup DVD into to the optical drive and start the computer.
  2. Press any key to boot from CD or DVD.
  3. On the Install Windows screen, click Next.
  4. On the Install Windows screen, select Repair your computer.
  5. In the System Recovery Options dialog box, click Next.
  6. In the System Recovery Options dialog box, select the appropriate operating system, and then click Next.
  7. In the System Recovery Options dialog box, select Startup Repair.
  8. The Startup Repair attempts to locate and resolve issues with the computer.
  9. If prompted, Do you want to restore your computer using system restore?, click Restore.
  10. In the System Recovery Options dialog box, click Finish. This screen can vary, dependant on if a problem was found or not.
  11. System restarts.
  12. If the problem was resolved, the computer restarts into Vista.
  13. If the problem was not fixed, the error may present itself again.
  14. Run Startup Repair again.
  15. If Startup Repair runs more than three (3) times, when available, select View advanced options for system recovery and support.
  16. For further troubleshooting, select one of the following options:
    • System Restore
    • Command Prompt
    • Last resort - Recovery Manager. Recovery Manager is not available if accessing WinRE via Vista OS Backup Media DVD
or you can use any software that can repair and recover your windows files.
Best regards
Mar 02, 2009 | Microsoft Windows Vista Ultimate Edition
formattt that hard drive sound like bad secters in hd run xp dish cheak chdisk u know to fix those bad secters on hd froma bug or sumthign best best u have orginal xp cd not recovery dish operting system disk boot into that del partions make new one then formatt it then install xp fresh update it so on ok
Jan 24, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
