Question about AT&T (1718B) Digital Answering Machine
Fax and answring machine on same line
I have a Kodak 5500 printer/fax and an AT & T answering machine on the same line,they have seperate numbers coming in on the same line,the problem is that the two machines will answer witch ever machine is set on the least amount of rings,it is an analog line coming in from Sasktel,how do we fix so the machines will recieve on the number dialed in on?
  • bitzgarry Nov 19, 2008
    tried that,that doesn't work,Kodak are telling me that the only printer that they have that has the ability to do what I want is the ESP9,not sure why this one will and the 5500 will not,when I bought the 5500 they told me it would work fine for what I was trying to do.
    I bought the 5500 only two months ago,have made 5 or 6 calls to Kodak and I am not getting a solution.I am going to try a few different settings at lunch today,to say the least,this is getting very frustrating.
    President:
  • 2,992 Answers
I assume you have distinctive ringing since both numbers are on the same line. According to the manufacturer's specs, the fax machine supports distinctive ringing. Set it up for the ring pattern assigned to the fax number and to answer on the first ring. Then it will pick up right away when someone calls the fax machine, and the answering machine will pick up the other number.
Posted on Nov 19, 2008
  • Nov 19, 2008
    Does the user manual for the 5500 confirm it doesn't do distinctive ring? That's such a standard feature today I have trouble believing it. How long ago did you purchase the fax machine? If it's possible to return it you might want to do so because it doesn't do what they told you it would, and get a model that has the distinctive ring.
    Without distinctive ring recognition it's impossible to have separate answering machine and fax machine on the same line. The only other option I can think of would be a fax machine with answering device built in, but the last time I went looking for one of those for an uncle (and that's well over a year now) I only found one model available at two different office big-box stores.
    Sorry...I really thought that would get you going.
I am trying to set up the fax. I have a phone
there should be a dedicated fax line to the printer. there should be no answering machine also. if ur using an dsl line,then u have to have a splitter on the wall outlet.fax line should be different from normal telephone line
Jul 13, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5500 Fax won't connect
Most likely problem is your phone company is blocking it for some reason.
Apr 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Having troubles with fax not dialing out
Disable call waiting is only set to "yes" if you have call waiting, press "menu" then scroll down to "reset all setting" make sure to backup phone entries before doing this . Follow the "fax settings" below:
FAX SETTING FOR 5500 (VOICE MAIL)
- ANS. MODE TO "YES"
- ANS. MACHINE RINGS "3"
- FAX RINGS TO ANS. "4"
FAX SETTING FOR 5500 (ANSWERING MACHINE)
- ANS. MACHINE RINGS "4"
- FAX RINGS TO ANS. "3"
Nov 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
How to fax
First you need to get the fax service activated with your phone company. Make sure that you do not have distinctive ringtones nor voice mail activated on your line, because these features are not compatible with the 5500 printer.
Once you got that, then you need to:
- Put what you need to fax on the ADF (automatic document feeder)
- Press the FAX button on the printer
- Dial the number (including area code)
- Press the START button
And your fax should get going.
Nov 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Fax pick up
Greetings Nana,
I believe that you can specify how many rings should occur before your Kodak 5500 Ai Printer automatically answers an incoming call (default = 4).
If you have a dedicated fax line, set the Rings to Answer to 1 or 2.  If you have a shared line for voice/modem and fax, set the Rings to answer to 3, 4, or 5. This setting only applies if Answering Machine Mode is set to OFF.
When the Answering Machine mode is disabled, Rings to Answer applies and your AiO printer answers the call. When your AiO printer detects a fax tone, it receives the fax. When a voice call is received (no fax tone), the call is ignored.
1 Press Menu to display the main menu. 2 Press scroll down until Fax Settings is displayed. 3 Press OK to display the Adjust Fax Settings menu. 4 Press scroll down until Rings to Answer is selected. 5 Press right or left arrow to change the number of rings.
Give it a try, Nana, but let Kodak know if you need additional help. They will be there for you.
Ron Baird the friendly Kodak guy
Sep 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Fax machine settings for distinctive ring line setup. Kodak 5500
This 5500s don't receive faxes if you have voicemail. You can still send faxes. Just make sure Disable call waiting is set up correctly in Fax Settings
Jul 29, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Can't fax
Fax machines will not work on digital phone lines. You need to have a seperate phone line to run one. If your office is using DSL for internet, usually they can run one off of that line with a filter installed.
Jul 12, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Fax issue on X5495
Yes you do unless it is a seperate phone number for your fax line.
Jun 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
Fax machine
what do you mean? you cant send? or you cant receive fax?
first know if you are using a digital or analog line. if youre using digital line you need to have a micro filter and it must be connected to the fax line. if you have an answering machine it must be connected at the back of the printer(EXT-2) to make it work. then on your printer press menu and then choose fax settings
answering mode must be YES(if you have an answering machine)
rings to answer is 1 ring less than your answering machine
disable call waiting must be set to NO.
let me know what happen
May 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
My model Kodak 5500 printer/fax
Just found your post and I'm having the same problem. Everything else seems to be working correctly. I can copy, scan, print and I THINK I can send a fax correctly, I should have called the person and made sure it arrived. However, I cannot receive faxes. I have an answering machine on the line, but it is not plugged into the Kodak Pinter, it is in another room. The answering machine answered the call, the FAX noise came across, but the Kodak Printer never picked it up and printed out the fax. I think I have all the settings correct, but the instructions are not very clear. Do you think I HAVE to have the answering machine plugged into the Kodak Printer? That doesn't make sense, but I might try it.
Feb 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
AT&T (1718B) Digital Answering Machine Logo
137 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
