Question about Pioneer PRO-200 60" Rear Projection Television
Pioneer pro-200 I came home today to find that the convergence (both blue and red) on the left side of my tv have gone haywire. I am not able to adjust them. This is affecting only the left 1/3 of the tv screen. The other 2/3 of the screen are great. It is causing a double color and image on the left side of the TV. I tried to adjust the convergence and it worked fine for the middle and right side but the left side won't adjust. Any ideas would be appreciated. Garym
  • theglick711 Dec 16, 2008
    I have the same problem. Were you able to fix it. If so,what was involved. Can I repair it myself. Please help.
    Thanks Burt
  • kweenEl Mar 13, 2009
    I have the same problem and I dont have the remote and of course you cannot use any other remote.Is there anything else that can be tried manually. Also does anyone have the manual that they can email me a copy of it would be greatly appreciated. baby5thgirl@yahoo.com
    Problem Solver:
  • 13 Answers
Here's a lead to a guy that can help...
http://www.avsforum.com/avs-vb/showthread.php?t=402397&pp=30&page=38
Good luck.
cell
Posted on Jan 16, 2008
SOURCE:
CALIBRATION IS COMPLETELY MESSED UP. CANNOT LINE UP RED, BLUE WITH GREEN. HAS AUDIBLE NOISE IN MULTI POINT CALIBRATION.
The convergence board in your tv has failed and it will have to be refurbished. Use this kit
http://www.tvrepairkits.com/xcart/product.php?productid=24909&cat=1428&page=1
Jan 19, 2011 | Pioneer PRO-200 60" Rear Projection...
My Pioneer PRO-200 60 in. Rear Projection Television picture looks great however it appears to be dark and blacks all blend together on the screen.
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Nov 03, 2010 | Pioneer PRO-200 60" Rear Projection...
How do I get rid of a red shadow in the upper left of the screen?
U can't tv have parts problems.Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment anywhere in the picture,have picture colors shadows or 3D pictures look like.The tv have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced on the tv convergence board to solved the tv convergence picture problems.The Shop,will cost u like $300-350 for parts and labors.
Oct 22, 2010 | Pioneer PRO-200 60" Rear Projection...
Blue color gun just went out of wack. cannot re adjust. Blue lines make horizontal hour glass. down on top and skewed up and to left on bottom
Sounds to me like a convergence problem. There are two convergence amplifiers inside the tv that keep the red and blue lined up with the green tube. This repair requires solder/desolder equipment and test equipment. What needs to be done is the parts need to be replaced on a circuit board. Most repair shops charge about 200-350 to do this repair. This set was very expensive and has many years of good life in it. If the service person says they need to replace the entire circuit board they are wasting your money. This board can be rebuilt by anyone with some experience in tv repairs. I would think that if a repair on that set doesn't exceed 450 most people would fix it. The set should stay in the home although some shops prefer to remove the circuit board to return to their shop for repair. Good luck, Russmann.
Apr 28, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Pioneer Pro 1009W
Replace conv ICs. This usually does it.
Mr Bob
www.imageperfection.com
Jan 11, 2008 | Pioneer PRO-1009W 57" Rear Projection...
Pioneer Pro-119 Rear Projection TV
HEY DF-YOU SET HAS 2 BAD STK392-110 CONVERGENCE ICS.THEY WILL NEED TO BE REPLACED AND IF NO OTHER CONVERGENCE CIRCUIT PARTS HAVE FAILED YOU SHOULD BE ABLE TO SET YOUR CONVERGENCE ALIGNMENT PROPERELY.TV REPAIR ESTIMATE SHOULD BE ABOUT 300.00$.DO IT YOURSELF FOR ABOUT 40.00$.
Nov 24, 2007 | Pioneer PRO-200 60" Rear Projection...
Pioneer PRO-200 60" Rear Projection Television Logo
186 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
