Akai recording problem
When recording the left channel is 1/2 as weak as the right and a little scratchy
  • stugazz Nov 19, 2008
    thank you i am trying some contac cleaner as there is some scratchiness when i turn the dial
    President:
  • 2,992 Answers
You might have a bad cable to the recorder (try swapping the right and left connections and see if the problem moves to the other channel), dirty tape heads (use a cotton swab and head cleaner or isopropyl alcohol to clean them), or a circuit problem inside the recorder. Hope this gets you started!
Posted on Nov 19, 2008
How do play both sides if what looks like a reel to reel tape that has a side 1 and side 2 ? My Akai 1722II does not have auto reverse . Thanks
You take the spools off and put the right spool on the left and the left on the right.
The link also explains, but i started on reel to reel in the late 60s. :>)
how do play both sides if what looks like reel to reel tape Google Search
Good video here
Reel to Reel Basics
Apr 25, 2017 | Akai Audio Players & Recorders
I am getting a weak signal on the left channel of my T.80 on both digital and analog outputs
Most likely a faulty cartridge. To check disconnect the leads to the cartridge. With the amp switched on touch each of the wires one at a time with your finger. On two you will have little or no response but on one you should hear a buzz on the left and on the other a buzz on the right. If the buzz are equal in volume then the cartridge is faulty. If the buzz is weak on the left, then that suggest a faulty pre-amp stage in the amp. This pre-amp only affects the record deck, so you won't get it on other functions.
Jun 25, 2014 | Stanton T.80 Turntable
Akai x 360d tape deck shows recording in both channels in stereo mode on playback one channel has a weak sound
1) Clean the heads real well using denature alcohol. If this does not fix it then try spraying the record play switches with Deoxit contact cleaner. After that it could be the well known Akai garbage transistors that a Technician will need to change.
Apr 02, 2014 | Audio Players & Recorders
Sony str-de185 left channel very scratchy and poor; not speaker, wire, or connections
Could be an open resistor in the amp for that channel. Might have to have a pro look at it.
Mar 26, 2013 | Sony STR-DE185 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Sansui QS-100 Problem with one rear channel
There are 2 250v 4a fuses inside the amp. They can blow and
that channel will cut out. Check the fuses.
Nov 19, 2009 | Audio Players & Recorders
Failure to record on left channel
al capacitors need changing due to age this will help but all the switches need cleaning if you live in england take it to audio gold crouch end they love these
Oct 06, 2009 | Audio Players & Recorders
Numark CD MIX2 right deck skipping, sounding scratchy
Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
Aug 04, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Home stereos
Hi this is Compaqowner again NOTE: I know enough about home Stereos,and I am pretty sure to figure out 'power output' you take the total:in this case it takes in 110 watts total devide that by 2 so according to my math that is 55 watts (I guess this AKAI has a 55 watt amplifier) then you take the amplifier output (in his case 55 watts) and devide that by how many channels are being used,so in 5.1 DOLBY mode DVD movie,etc.(power to all 5 speakers) then it's 11 watts per channel,and in 2.1 stereo (power to the subwoofer,front right,and front left speakers only) it jumps up to a little over 18 watts per channel,again,I think?,when you find the answer,please let me know. Thank you for your time. Steve B.
Nov 03, 2007 | Audio Players & Recorders
Akai reel to reel GX230D
Try demagnetizing the heads with a head demag device. This is not the same as a bulk tape eraser or a tape demag device.
Oct 17, 2007 | Audio Players & Recorders
61 people viewed this question
 Grubhead
Grubhead
