Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
Toshiba 51H84
I have toshiba TV 51H84, is not powering up the tv clicks but in wont come on. please help.
I have had my TV get into this state twice and both times it ended up being a blown transistor. Cost $300 each time to get fixed though shopping around for part numbers I think the transistor was only about $20.
Symptoms were a click sound when trying to power up but the power light would not go on and no picture or sound.
Posted on Jun 02, 2008
I have this same problem and replaced the entire convergence circuit board with the IC's included and the problem was not fixed. The convergence board costs $181. at Vance Baldwin electronics. I now have two and still have a tv that won't turn on.
Posted on Apr 18, 2008
    President:
  • 3,130 Answers
I would not replace the convergence ic's just yet. first, pull off the CRT sockets off the picture tubes and lay them aside, making sure they are not touching anything. Next disconnect the Plugs off the convergence board, where the STK IC's are. Next see if the set will turn on now with sound. if it does, replace the convergence IC's. If it does not check the sweep power supply and or the main regulator IC and circuit. Good Luck Please do not forget to rate this thread.
Posted on Dec 15, 2006
  • 81 Answers
Convergence IC's need to be replaced
How do i turn off the closed caption on my toshiba 51h84 tv? i tried setting via the remote and changed the CC option to OFF but i still see the closed caption wording...it is driving me crazy!! help!
What is the source of your TV signal: Cable? Dish Networks? DirectTV? Antenna?
Many times the Cable/Dish Networks/DirectTV controller also has an option for closed captioning. Please verify that a controller is not setup to deliver the CC data.
Also, try setting the TV CC using 'C1' or 'T1' and selecting 'Enter' to accept the change; then come back and set CC to 'Off' again to see if toggling on/off helps.
Dec 31, 2014 | Toshiba 51H84 51" Rear Projection...
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
Toshiba Theaterwide HD 51h84
It is your projector tub if you are getting alot of blue in the picture. Those guns are very expensive to replace. I am sorry to tell you that. It would be cheaper set from wal-mart for your kids to play on.
Nov 23, 2009 | Toshiba 51H84 51" Rear Projection...
Help! Toshiba 51H84..Power light flashing, tv picture won't come on!
First thing that needs to be checked is the convergence IC's. Those IC's are located in the signal board and are really hard to remove. You need an experience technician to fix it for you :)
May 27, 2009 | Toshiba 51H84 51" Rear Projection...
TV wont come on
One of the tubes are gone. You need to replace one. The easiest way is to disconnect the board from the tube. power it on and if the correct tube is disconnected, the TV will turn stay on. Research the problem a bit. This is a common problem
Jan 06, 2009 | Toshiba 51H84 51" Rear Projection...
Tv turns blue the shuts off.
symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
Sep 05, 2008 | Toshiba 51H84 51" Rear Projection...
My TV clicks, stays on, but still shifts to the left. I have a Toshiba 51H84 51inch
your looking to parts at the convergence area , either check for DRY SOLDER around the power supply area or replace the IC IN THE CONVERGENCE AREA starts with STK- ___ and numbers. try that , hope this helps
Apr 25, 2008 | Toshiba 51H84 51" Rear Projection...
Fuzzy picture
does it look like this set?
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 51H84 51" Rear Projection...
The solution is you have to buy a new better tv with a good extended warranty in payments. JZ
Jul 09, 2007 | Toshiba 51H84 51" Rear Projection...
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
321 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
