Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Unable to open the dispenser tray
This option was pre-selected as "free" for solution. I also logged into the website for research on other users similar issues, attempted to post this similar problem, however, wording on the terms of use indicated a potential fee, therefore, didn't accept the terms and rerouted to this section.
  • rhondalup Nov 22, 2008
    I AM GOING CRAZY!!! SO GLAD TO HEAR I AM NOT ALONE.
    Does anyone know how to open the dispenser tray/drawer where laundry detergent,softner and bleach are put in..H-E-L-P!!
Do you mean pull out the dispenser drawer so that you can remove it from the machine?
Posted on Nov 24, 2008
  • bpkaplan Nov 24, 2008
    If you want to totally remove the drawer, press down on the indent in the BLUE plastic frame (behind the area where you put the fabric softener) and the drawer will come out of the compartment.
    Sorry, I mean next to the LIQUID BLEACH dispenser. If you just want to open the drawer so that you can put in detergent, place your fingers under the drawer and gently pull forward. I hope this helps.
Actually, the softner was ajar and the drawer WOULD NOT OPEN. My hubby removed the cover and found problem. However, THANKS FOR THE INFO ON GETTING DRAWER OUT OF MACHINE. O.M.G. HORRIBLE BLACK MOLD IN BACK OF DRAWER. WE were unable to clean properly until now.---THANKS SOOOOO MUCH!
Posted on Nov 25, 2008
How to resolve the Roku paid channels not working issue?
sorry no idea here . possibly your tv is not compatible
Nov 13, 2017 | Roku Televison & Video
Tip
How To Change Password Of Users In Windows XP
On Internet, I found so many people are confused about how to change the passwords of users in Windows XP even though it is a easy job. As far as we know, changing logon password of our Windows regularly is a good habit to help keep our PC secure, I just researched and found out the below ways to change the password of users in Windows XP. You can use either one to achieve your goal.
Follow the simplest ways you thought to change your Windows XP logon password:
If you know any other interesting way, please let me know through comments.
Using Control Panel
Difficulty: Easy
Time Required: Changing your Windows XP logon password usually takes less than a few minutes
Here’s How:
go to Start –> Control Panel –> User Accounts
Tip: You can also open control panel by Start –> Run –> control. This will open Control Panel.
Select the user for which you want to change the password and select Change my password.
Note: you must need appropriate privileges to change the password of another user.
Using Ctrl+Alt+Delete
Difficulty: The easiest one in my opinion
Time Required: It just takes me one minute
Here’s How:
If your press Ctrl+Alt+Del when you are logged onto your Windows XP machine, it will show you the classic security options.
Select change password and change the password of the logged on user.
Note: If the security options does not appear. Task manager shows up instead of the security options. Just go to Start –> Control Panel –> User Accounts –> Change the way Users Log on or off.
Uncheck Use the Welcome Screen. Log off and logon again. Now pressing Ctrl+Alt+Del will show the security options window.
Using Command Prompt
Difficulty: medium
Time Required: It may takes a few minutes
Here’s How:
go to Run –> cmd.
Command prompt will open. Use the following commands to change the password:
net user username password /domain
Replace username with the original username and password with the new password you want to assign to that user. /domain is optional. If you are in a domain environment, specify the domain name otherwise, if you’re using a local user, leave /domain. If I want to change the password of user Sanix to 12345. I will issue the following command at command prompt:
net user Sanix 12345
It will change the password of the user Sanix to 12345.
Note: if you’re not logged on as an administrator, you will get the following error:
“System error 5 has occurred. Access is denied”
Using Control userpasswords2
Difficulty: Easy
Time Required: It may takes less than a few minutes
Here’s How:
go to Start –> Run –> control userpasswords2
This will open the classic user accounts management window. Select any user and select reset password.
Using Computer Management Console
Difficulty: Easy
Here’s How:
right click My Computer –> Manage –> Local Users And Groups –> Users
Right click the username for which you want to change the password and select Reset Password.
If you compare the ways hereinabove carefully .You’ll find that the premise of using above ways to change your PC users password is you must logon the system with a user who has the appropriate privileges to change the password of another user. But if you forget any user password including administrator, what can you do?
Tips:
Windows Password Recovery 6.0 is your best choice, it is an easy-to-use tool designed for resetting local administrator and user passwords on any Windows system. If you have forgotten your password , or are locked out, or you do not have access to the password of the system. No need to call a technician, no need to re-install anything, and you certainly don’t need to reformat, just download this effective utility .
Free Download Link : Windows Password Recovery 6.0
Quick Start: Get a quick start by following the step-to-step tutorial here…
on May 18, 2010 | Computers & Internet
Tip
Loading Blackberry Desktop Manager in the System Tray
By default, setting up the Blackberry Desktop will cause the Desktop Manager to pre-load full screen each time the computer is started. To pre-load the manager application in the system tray instead, do the following:
  1. Open the desktop manager,
  2. Select the "Options" pull-down from the upper right hand corner.
  3. Check the option to "Hide when Minimized"
  4. Click "START > All Programs > Startup"
  5. Right click the Desktop Manager icon
  6. Select properties
  7. Under the Run option on the general tab pull down and select the word, "minimized"
The desktop manager will now load but only show when the Blackberry device is attached.
on Apr 08, 2010 | Cell Phones
Everytime I try to change a template it always comes up with an error and shuts the program down.....
If the Templates are from a different program, it could not be responding/allowed with the program. Especially if you are using a trial / lite version.
Try to recreate, or even make a dummy template to see if Asure ID is working correctly.
It would be worth the look on the manufacturers website or a call to customer support. You want to determine if any critical updates have been introduced to the software. Your program may not have updated automatically.
Sep 24, 2014 | Fargo Asure ID Solo 7 - Single User...
My netflix screen comes up but won't do anything. ts is
Netflix offers users the ability to rent movies and TV shows through the mail on DVD or Bluray and also allows users to watch select shows or movies online using a computer or certain other devices.
Occasionally users encounter errors when attempting to log in to their Netflix accounts.
These errors can be as simple as an incorrectly typed password to more complex issues with the Netflix service itself.
Credential Problems
Many login problems are caused by an incorrect email address or password when attempting to log in.
This can be due to typos or other misspellings, or recent password changes that were forgotten. Netflix offers the ability to recover passwords and usernames via the "Need Help Signing In?" link below the login fields on the Netflix home page.
Clicking the link allows the user to recover her password by entering her email address, and also gives the option to advance to a second recovery screen if she does not have access to that email address anymore.
The second screen allows the user to prove her identity by entering the first name, last name and credit card number associated with the Netflix account.
Service Errors
Login problems occasionally occur due to errors with the Netflix service itself.
When these problems occur, a message appears that explains a site error has occurred, directing the user back to the Netflix home page.
The user should attempt logging in again in case of a one-time error, though site-wide service errors do occasionally occur.
Depending on the nature of the error, once logged in the user may experience problems when trying to watch movies instantly or attempting to edit his DVD queue.
Site-wide service errors do not affect the ability of Netflix to send and receive movies by mail.
Account Problems
If a problem exists with a user's Netflix account due to a failed payment attempt, the user can still log in but is directed to a page informing him of the problem instead of his standard account home page.
Until the problem is resolved, he will be unable to watch movies instantly, receive DVD or Blu-ray discs from the service and will be required to return any movies currently at his home to avoid additional fees.
Account problems can typically be resolved by authorizing Netflix to retry the last payment attempt on the user's credit card or by supplying a new credit card number for payment purposes.
Device Connection Errors
When attempting to watch movies or TV shows on Netflix-ready devices such as a Nintendo Wii, Xbox 360 or Roku streaming media player connection errors sometimes occur while the device attempts to log in to the user's Netflix account.
These errors may occur because the Internet connection the devices use is not properly configured, limited bandwidth to and from the user's home or problems with the device-specific version of the Netflix service.
If the device cannot connect and log in to Netflix, the user should check the device's Internet connection and try connecting again later.
Netflix log-in problems
http://www.product-reviews.net/2010/10/21/netflix-down-login-problems-are-you-affected/
Mar 10, 2014 | Computers & Internet
I made a 2nd facebook account under the same email address how do I log back on my first one?
under the tab where we go to log off.
there you will find option by which user you wants to log in.
select option of user and click on it
Dec 18, 2012 | Computers & Internet
Gateway GT5404 Recovery Disk
You could have provided an operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
Dec 11, 2012 | Gateway GT5040 PC Desktop
How to make a recovery disk for a gt5622 vista
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
or
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
vista recovery disk
not longer free
http://systemdiscs.com/?utm_source=neosmart&utm_medium=article&utm_campaign=Vista_Recovery
Hope this helps.
Nov 25, 2012 | Gateway GT5622 PC Desktop
I cannot sync movies with my iphone4 it says unknown error 13019?what does that mean?
Error 13019 during sync:
Please update to the latest version of iTunes. The latest version of iTunes can be downloaded from http://www.apple.com/itunes/download/. If updating to latest version of iTunes does not resolve the issue, continue:
Please follow the same steps if the error occurs while syncing content other than music (applications, podcasts, and so on), but deselect the content that stops the sync. Deselect one type of content, then attempt to sync. Continue until you sync without error. Deselect Apps last, since restoring your Apps would take longer than restoring other content.
Error occurs while syncing music: The error will most commonly occur while syncing music. This issue can be resolved by following these steps:
Select the iPhone or iPod touch in iTunes under Devices. Click the Music tab and under the Sync music option, choose Selected playlists. Deselect the Voice Memos playlist. Click Apply and then click Sync. If the above steps do not resolve the issue, check the device and the iTunes library for duplicate voice memos. If you find any duplicate voice memos, delete the duplicates and then sync.
If those steps do not resolve the issue, then follow these steps:
Select the iPhone or iPod touch in iTunes under Devices. Click the Music tab and deselect the Sync Music option. Click Apply and then click Sync. After the sync is complete, reselect the Sync Music option. Click Apply and then click Sync. Test in a new user account
If the steps above do not resolve the issue, attempt to sync with iTunes while logged in as a new admin user. Follow these steps to create a new administrator user:
Windows XP, Windows Vista, and Windows 7 From the Start menu, choose Control Panel. Open User Accounts. Select Create a new account and follow the instructions to complete the account setup process. Once the new account is created, choose Log Off from the Start menu. Log in to the newly created user account.
Mac OS X From the Apple menu, choose System Preferences. Choose View > Accounts. Click the "+" (you may need to authenticate to be able to click this). Give the new user account a name and short name and enter a password. Select the checkbox for "Allow user to administer this computer". This makes the user an admin user. Click Create Account. Log out and then log in to the new account. If the error does not occur in the new user account, other content is causing the error. Proceed to the next section.
If the error does occur in the new user account, the issue may be caused by content downloaded or created on the device, such as podcasts and voice memos. Removing content from the device may address the issue.
Jun 27, 2011 | Apple iPhone4 4G iPhone 4
Washing Machines Logo
73 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
