Question about Acer AL2416WD 24 in. LCD Television
HDMI connection WHEN USING HDMI connection on my Bush LCD television, its says out of range
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
Change the HDMI cable, try other borrowed from a friend t make shure is not the cable
Posted on Nov 19, 2008
Tuning in skyview box to bush television
hi, how is it set up, are you using a scart lead or a hdmi lead if your using a scart lead you need to select av 1 or ext1 if your using hdmi lead you need to select hdmi 1, come back to me if your still having problems thanks.
regards
shaun
Apr 06, 2014 | Bush Industries IDLCD15W008HD LCD TV
Protron tv says input signal out of range when connecting laptop via hdmi
The TV can't process the digital signal. It might be out of range.
Nov 26, 2012 | Protron PLTV3250 32 in. LCD Television
How do i connect to pc using hdmi cabel its a sanyo pdp-42xr9da lcd
You have a cable called as the DVI-D to HDMI cable. Using this cable you can connect PC to LCD.
You have a HDMI port on left side of your LCD.
For easy understanding i am attaching a image.
Jul 24, 2010 | Sanyo DP42746 42 in. Plasma Television
Connect the hdmi out put of a bush hd set top box
its telling you that you cant use the format that your source is set up for .. like 1080P wont play on a monitor that wont support that ..also hdmi requires an exchange of information between units before it will allow 1080 resolution (thats to prevent recording of high resolution material) the adapter may block that exchange .. if you set the source to 720 or less resolution then its likely to start working .. problem is .. if you cant see it how do you set it .. if your remote has an obvious button for that then you can just try selecting different modes and wait 10 seconds to see if it works .. if its not obvious then perhaps you can temporarily use svideo or composite in order to set up the source machine ..
Jan 27, 2010 | Televison & Video
Bush 32" LCD 1080p tv
Is this the BUSH "LCD32F1080P" ?
Bort from Argos for £330 (then £370 now £300)
Cos I noticed mine doin that aswell, I thrt it mite be cos im using an old ASDA HDMI cable... but now i saw your post.
Nov 05, 2009 | Televison & Video
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Out of Range with HDMI cable on Bush LCD TV
If it is a low end cable that could be your problem. Also some players require a certain bitrate that must be transferred and lower end cables lack this. This is especially true for videogame systems.
Dec 09, 2008 | Televison & Video
Bush LCD
Hi Trev.
Do you only get the sound when using the tv tuner eg chans 1 to 5 ?
Or is it only when you try to play dvd,
http://dysonmanuals.inc.io/
Chris..
Nov 28, 2007 | Bush 5693D 24" TV
How do i connect my 360 to run on HDTV to a bush lcd tv?
HD is a new sort of signal transmitting/receiving technology; therefore, all software and hardware components you have to use must be able to support the relevant technology. (HDMI=High Definition Multimedia Interface)I am not sure if your 360 has an HDMI output, but if it has one, you have to use one of those HDMI cables. As well, the LCD model you mentioned has to be able to support HDMI signals. As I know, scart plugs don't usually support HDMI. Similarly, individual connector cables don't support it either. All you need to have is a digital coax cable.
Apr 16, 2007 | Microsoft Xbox 360 Console
Acer AL2416WD 24 in. LCD Television Logo
251 people viewed this question
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Rommel Balcita
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
