Question about Frigidaire FGX831C Top Load Stacked Washer / Dryer
Clothes Burning There is a bit of a gap at the front of our dryer. It has been grabbing clothes. It seems to like my daughter's clothes the best. I've read that this can be fixed by a novice on the stand along models, does anyone know if we can replace the part on our own for this model?
SOURCE: Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Posted on Dec 23, 2007
  • 868 Answers
SOURCE: front load washer frigidaire leaving small marks on clothes
Do you use Fabric softener sheets??If so, than look in the dryer foe one to be caught in there and as it  makes contact with the clothes it will actually mark them.If you dont use them than take a long look inside of your washer ,look for something stuck in the tub or around the top clothes gaurd that sits above the edges of the tub.Also ,are you sure its not oil?Oil will leave a distinctive mark that is almost impossible to remove.Most likely it is a item stuck in the Dryer and not the washer.I'll be happy to guide you through this at any time .
Posted on May 22, 2008
  • 1314 Answers
i tell customers to remove the drain hose from the stand pipe and vacuum the water out of the washer from the drain hose but because of the pillow this might not work in your case. Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
Posted on Jun 11, 2008
SOURCE: Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Posted on Oct 07, 2008
  • 423 Answers
SOURCE: clothes are dirtier after washing...
The problem with your front load washer is a broken rear bearing. If you remove the rear panel, you will see brown "gunk" all over.
If you want to repair it on your own, order this:
Good Luck!
Posted on Apr 01, 2009
  • 1456 Answers
SOURCE: ATF6000FS1 Frigidare front load washer The
Suggests that motor not not tuning heavy loads due to worn belt or motor.. you could check if Carbon Brushes are worn if they are fitted some motors dont use them..good luck
Posted on Nov 16, 2009
0 characters
1 Points
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
Dryer door won't stay open while removing clothes
Likely the feet to the dryer are not level. Grab a large level and check to ensure the top front is level across.
If your door opens to the right, raise the front left foot by screwing it counterclockwise. Check level, and repeat.
Mirror the operation for a door that swings to the left.
Jan 25, 2012 | General Electric WCVH6400J Front Load...
Excessive shaking at start of spin cycle
I have the same prob with mine when the electricity is dim. Also when the clothes in it are put in unevenly and when only a bit or very large amount of clothes is put in. shuffle the clothes about, or put in some more clothes/ remove some clothes. that might fix it.
Apr 08, 2011 | Equator EZ 3600 CEE Front Load Washer /...
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
Clothes come our smelling bad
Run a load empty on the hottest setting with a cup of bleach.
Then, after finished using the machine each day, leave the door open for a few hours to allow the rubber seal to dry.
Jun 30, 2009 | Zanussi FLA1001W Front Load Washer
Black stains sticking to white clothes on washing
If your clothes get marked or torn in your dryer, check these:
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Jun 08, 2009 | Washing Machines
sounds like brushes they can cause a burning for clothes smell after drying the fan in the heater could be dirty but generally that would mean the heater will not work
Mar 18, 2009 | Hotpoint Aquarius WD63 Front Load...
Rubbing and Clicking Noise in Dryer.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Mar 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Clothes getting caught on inside of dryer
There are a couple of guide wheels in the back of the dryer. when they get worn out the tub will have excessive play and will trap clothes inside. Just remove the front cover loosen the belt and remove the drum. the worn wheels will be easy to spot. It is an easy and cheap fix.
Nov 02, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryer marks clothes
it could be the adhesive that holds the felt bearings on the front housing. you see the back of the dryer drum has a bearing in its center, the front of the drum rotates on two or more felt pads or bearings in/on the front cover where your door is. you'll need to remove the front cover to replace these felt bearings. there should be two screws, maybe more holding the front cabinet to the rest of the dryer. the bearings will be mounted to the front cabinet right around the hole for the door.
Aug 09, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Frigidaire FGX831C Top Load Stacked Washer / Dryer Logo
21 people viewed this question
Top Frigidaire Washing Machines Experts
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
