Question about Toshiba Satellite A100-S8111TD Notebook
Power source not charcing battery
''power meter in power options properties''
current power source keeps flashing between AC power and batteries, until the total battery remaining time is zero, but the AC power source and battery still flashing?
have brought and tried replacement battery but still the same?
  • d_skelton7 Nov 19, 2008
    if i remove the battery, the PC runs fine,, i did this to prove the AC power source
    President:
  • 1,073 Answers
Its not the battery, its AC power source providing your problem.
Check if AC connector goes in as far as it should on your laptop, check so you dont have a weak link on the cables on the AC. My guess is that the power sorce or the cables on is defect someway.
Posted on Nov 19, 2008
  • Nicolas
    Nicolas Nov 19, 2008
    Since the problem is that the power is jumping until your battery is emty,
    i'm still sure that it is cable-problem and not a battery problem. If its not the cable from the AC is must be the cables inside your computer. From the connectionpoint goes 4 cables, two dirictly to the motherboard so it runs when u can use is whitout the battery and two to the battery for charging it, try to open your laptop and check that those cables are still in one pice. Sometime the solder on those cables isent good, if so u need to solder them again.
My dyson Max 08-21663b WHEN FULLY CHARGED I TURN IT ON AND IT RUNS FOR 5 SECONDS AND GOES OFF AND DOES THE SAME THING REPEATELY I BELIEVE ITS MY BATTERY PACK WHICH IS A 6 CELL CAN YOOU ADVISE ME?
Yes the battery pack would be the most likely culprit here. Go on eBay and buy the correct battery cells and build one using the old one as a guide. This method will save you about 50% over trying to buy a make up replacement if available. This is an easy job, just take your time, buy batteries with solder tabs.
Jan 11, 2017 | Computers & Internet
The battery is fully charged, and the ac adapter is plugged into the laptop, when i push the on button the laptop will not start
Remove the battery and power source. Remove the RAM and hdd. Power up with the power supply and it should do something. If it does, replace the RAM and hdd it should now restart. If nothing, check the GPU.
Jan 10, 2017 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
How do I get the battery out of my acer laptop
Your Model of Aspire has a different battery release method, see attached pic on how to do it. This is a pic from your User Manual, you can download it from here Download Acer Aspire E1 572
Manual
. I suspect that the information you have been given regarding battery removal and passwords refers to removing the cmos battery as in a PC in the hope that it will clear Bios activated passwords.
May 04, 2014 | Computers & Internet
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Jan 28, 2014 | Dell Vostro Computers & Internet
Button keeps blinking
It sounds like it could be either the battery is going bad and not holding a charge or the adapter is. I have had really good luck with similar problems going to places like Batteries +, and large electronic retailers, and my favorite the small local mom and pop computer store; where I end up asking them If I could try one of the adapters from the floor model to eliminate if is a faulty adapter. Other then that I'd if its not out of warranty contact Acers online chat support at http://us.acer.com/ac/en/US/content/service
Jan 19, 2014 | Computers & Internet
Removing bluetooth chip
Without knowing what the desktop computer motherboard is, I\'d only be guessing as to location of Wi-Fi chipset.
However even if I knew the motherboard manufacturer name, and model number; the point is Moot.
A) You remove that Wi-Fi chip, and kiss the motherboard goodbye.
It\'s designed into the circuitry of the motherboard.
Isn\'t going to be jumper wires taking it\'s place, and making connections to circuit traces on the motherboard.
B) Do you have a wireless router?
Dunno.
Do you have a wireless connection set up?
No.
You can use just a LAN connection. (Hard wired)
C) Suggest if having a Bluetooth option on your motherboard is not an option then use a different motherboard that doesn\'t have that option.
Regards,
joecoolvette
Apr 06, 2013 | Computers & Internet
Freezes on the warm boot screen MC9000
This can be for a number of reasons.
First thing would be to try and cold boot the device:-
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger
If that fails next thing would be to try and re-flash the operating system. This is done by using an SD card and loading the latest operating files onto it. The SD card slot is located under the keypad. A cross head screwdriver is required to remove the keypad. Search on symbol software download site for the latest. The download also has a readme with detailed instructions. Once the files are on perform a cold boot.
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger. Drop the terminal in a cradle so that it runs on external power.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 09, 2009 | Symbol MC9000-G Portable Terminal
Toshiba Satellite A100-S8111TD Notebook Logo
106 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
