Question about Acer Extensa 4620 Notebook
The switch of power baton is damaged plz replace with new one
I was saffored a lot i have waranty
plz provied the switch case
How do i fix a drivers side motor
Aaron, if you are talking about driver side power window motor, first check that power is getting to switch, if it is replace power window motor. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Diagnose your Power Window Problem Is the Switch or motor bad
AGCO Automotive Repair Service Baton Rouge LA Detailed Auto Topics...
How To Install Repair Replace Power Window Motor Chevy Impala 00 05 1AAuto...
How to Replace Power Window Motor
Apr 23, 2016 | Cars & Trucks
Why wont my new starter engage flywheel. have replace solonoid
Are you sur you have the correct starter? When you turn the key if nothing happens check the starter solenoid and relay. Does the starter spin at all?
If power is getting to starter the problem must lau there. If no power to it also check the ignition switch , whether the key is damaged and has lost its chip... in that case the mimmobiliser may still be on.
Lots to check
good luck
Jul 04, 2015 | Dodge 1997 Ram 1500
My sinotec has power but it dnt wnt to switch over to show piture plz help
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Feb 15, 2015 | Televison & Video
What is a stun baton?
A stun baton is basically like a baton except that it carries an electric charge. Some have a switch on the handle that the officer can switch when the baton is in contact with the assailant. Other types have a constant electric charge going through the baton, with an insulated handle, so if anyone is touching the baton (other than the handle) they will be shocked
Jan 13, 2013 | Work Safety
My iphone's touch screeen is damaged and i have a new one but dont know how to seprate touch screen from display
If your phone is still in waranty try to have apple support fix it. Trying to do it manually is very hard since all the casing is glued down. hope it helps
Jan 24, 2010 | Apple iPhone 3G
Stuck in provied air postion
this is usually down to 1 or 2 switching transistors. unfortunate i have not worked on this rig so can not help alot.
May 25, 2009 | Superstar Radio Communications
GPRS Setting
use the data account setting
Mar 20, 2009 | Siemens M56 Earbud Hands Free Headset
My touchscreen does no work and games don't play right
The touchscreen replacement isn't too bad if you've got some technical knowledge, about 1 hour and a lot of patience.
I'd get the new touchscreen from a popular web auction site and the replacement is quite straightforward but fiddly, if you can wait for the new touch screen to arrive in the post, have a tri-wing screwdriver and a lot of patience you might as well go for it. Just take great care when replacing the bottom case to line up the power switch (and volume control) with the external plastics so as not to cause any damage as a broken power switch isn't an easy replacement.
HTH
Mar 06, 2008 | Nintendo DS Lite Console
Acer Extensa 4620 Notebook Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
