Question about HP LaserJet 2420dn Printer
Fuser paper out actuator broken
Is it possible to buy just the parts needed to fix the fuser ie has anyone got a parts breakdown for lj2420dn fuser assy (RM1-1537-050CN)
thanks
Are you looking for fuser film??
Posted on Mar 24, 2009
Erro code e02 in toshiba estudio 181
hello
dear you have to verify all the exit sensor related
1. do u have look on fuser unit drive gears.
2. is the exit rollers are good some time exit roller got damaged they don't hold hold paper to run out from machine.
3. do u have clean the exit sensor.
4. do you have verify that the exit sensor actuator is free to operate the sensor.
5. some time exit sensor actuator broken.
Aug 28, 2014 | Office Equipment & Supplies
How do I fix Samsung Clx-3185 Fuser
The micro "flag" located at the fuser has been broken or dislocated or some gears broken and fuser not spinning.
If you cannot get spares, buy a new printer
May 06, 2014 | Samsung Clx 3185 Multifunction Printer...
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
I need to change the fuser exit sensor assembly on my Xerox Phaser 7300dn. My actuator is broken and I have no idea to get the old part out and then replace it with the new part. Anyone have any insight...
If you are not knowledgable about the printer, I would suggest having a printer repairman fix yur problem.
If the sensors is not installed correctly, it will still not print and you will either have to ave a printer repairman fix it or buy a new printer.
The fix is not an easy fix for the average person to repair.
Sep 21, 2010 | Xerox Office Equipment & Supplies
Toshiba 2060 Paper Jam at the fuser
I would have to say that you are missing the fuser drive. I would remove the fusing unit and look to see if you are missing any gears or any missing teeth from a gear or just missing a gear...
Jun 18, 2008 | Toshiba 2060 Copier
B door open
There are two switches, so if you changed the one that was working....
Possible parts affected could be
- cover top
- cover fuser
- cover front assembly
- the switch
1) check the condition of the cover - top, front assembly and cover fuser closed?
2) on the cover top there is an "actuator", a plastic bit, which presses down on the switch assembly top - is that plastic bit broken, bent or deformed?
3) on the cover front assembly there is also an "actuator", check this
4) and of course same for the fuser cover
5) top cover, check the switch, disconnect the switch (P116-1) and press/release it - does that make a difference. If not replace switch
6) same procedure with the switch (P115-1) for front cover.
Feb 04, 2008 | Epson Aculaser C1100 Printer
Xerox 416 Fuser
Is it getting thru the "pinch of the fuser and catching on the stripper fingers? If so clean the fingers, ensure they are not worn or tips broken.(Running sheets with dark lead edge can cause sheets to stick to rollers,try running blank sheets to clean up, if they get thru then try normal copies)
If the sheet stops before entering the rolls more likely to be dirty entry chute, drive problem or sensor problem....need more detail
Jan 25, 2008 | Office Equipment & Supplies
Brother 8840 Fuser Roller Gear
You can buy the gear , I always just replace assembly to reduce possibility of later breakdown
you can Purchase gear or Fuser HERE
Dec 08, 2007 | Brother MFC-8440 All-In-One Laser Printer
Gestetner c7435 paper jam at fuser unit
It sounds as if the actuator is out of position or bad. In the fuser exit there should be a thin little black (usually) actuator that hangs down and the paper pushes/ lifts it off of the switch/ sensor as the paper passes. If this is pulled out of its holder or broken it will act like there is still paper jammed. The actuator looks like a little ' j ' and is pressed into its holder. If this is seated properly then the switch is probably bad and needs replaced. About resetting --- a paper jam is considered an 'A' code and does not need the machine to be ' service reset '.
Please let us know what you find out.
Aug 18, 2007 | Gestetner C7435n Laser Printer
HP LaserJet 2420dn Printer Logo
70 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
