Question about Yamaha RX-V1500 Receiver
Yamaha RX-V1500 Shuts down after 2 seconds
Hey all, I have a particular issue. I'd used a Yamaha RX-V1500 in my living room for about a year & one day it stopped working. The unit would turn on, but then immediately click off. I figured I had a short in one of the speaker wires or sub, and tested the unit without anything plugged in - same issue. On, 2 seconds, click off. I set the unit aside, and brought down my second RX-V1500 from my bedroom to try in the living room. This unit worked for about a week, then THE SAME THING HAPPENED - and it has been like that since. So I think I fried too amps. Any ideas? It is not hot in where the receiver is, and all the speakers tone fine. I understand how to fix things generally, but before I open these guys up, anyone know where to focus? Thanks.
  • 6 more comments
  • Anonymous Nov 06, 2007
    I have the exact same problem with my RXV1500. My amp worked fine for about a year and nothing happened to it which would explain the "powering off problem". One day it just started shuting down after power up. If I unpluged it and waited a day or so it would reset the protection and would work again for a while. Now it is doing it every time it is turned on. I am going to attempt to send in for repair and if I learn anything I will come back and post. It would seem this is some kind of common problem and a factory defect issue.
    Rick
  • Anonymous Dec 15, 2007
    The reciever shut down and will not turn on. If I try to turn it on, it shuts off in about two seconds and the front panel does not even light up. This was my third yamaha receiver, but I doubt I will buy a yamaha again!
  • zzjdbzz Dec 24, 2007
    I'm also having the same problem. Even with nothing connected to the receiver, it turns off after 2-3 seconds. Even disconnecting/reconnecting the power cord doesn't help.
  • 2cxm Aug 21, 2008
    amplier was playing fine until the mains electricity started fluctuating between 80 and 391 volts.
    Now the amplifier switches on and then switches straight off after about 2 seconds.
    Disconnecting the amplifier for a few days and retrying produced the same fault.
  • devans8 Sep 28, 2008
    Same Thing..! No problems then one day this amp turns on for 2 seconds & then clicks off. Nothing was moved, tampered with or shocked. What's up..?
  • Anonymous Jan 16, 2009
    I have a Yamaha HTR-5750 and it will shut down after two seconds of power. From this thread it sounds like Yamaha has a design flaw and should fix these units for us for FREE. Why should we be paying for poor engineering? I will never buy another Yamaha product again.
    kpappas@comcast.net
  • Anonymous Feb 08, 2009
    I have the same issue. I am about to throw the darn AV Receiver out the house. The receiver shuts down after turning the power on. I have unpluged it several times to reset but system shuts down everytime. Does anyone have a diagram of the circuit board that can provide some guidance in repairing the faulty component?
  • bigburt May 10, 2009
    My and I sister were listening to my dad’s stereo quite loud one night well my other family members were out. Then today I tried to turn it on and it turn itself off after about 2-4 seconds right after it kick in. The receiver is a Yamaha RX-V1500 PLEASE HELP
This set is getting old and is in the Archives section of the Yamaha consumer guide area. But, you can still download the owners manual if you need one. If it is going into protection mode even when there are no speakers connected OR when the sound level is very, very low or zero it is not good news. Yes, unplugging the line cord will cause the protection system to reset itself. But, if it shuts itself off again soon after rebooting it is a sign of bad grease in the output stages -- in all probability. Let me explain: The audio output transistors are mounted to a large heatsink which keeps them cool during operation. They are electrically isolated from touching the heatsink by an electrical insulating washer. But, in order to keep them cool and allow for good thermal conductivity of the heat generated by the output transistors the washers are treated with a heat conducting grease. Over time this grease will dry out and lose its heat conductivity ability allowing the temperature of the transistors to rise; as the heat goes up they conduct more current and cause the protection system to activate and shut the set down (in order to avoid damage to the set). That is the most common cause of your symptoms. However, there are several other possibilities, but I give this explanation a 90% probability based on my experience.
Posted on Jun 17, 2007
  • allister Sep 05, 2012
    alex you still on the forum ?
Asouth, I'm curious if you have solved the problem with your receivers? It sounds like the same problem that I am having with my RX-V1500. I would appreciate any response that you would have to this inquiry.
Posted on Jun 06, 2007
    New Friend:
I had a similar frustrating problem, the RX V1500 would simply turn off within a couple of seconds. Unplugged it for a full day, tried disconnecting all cables & inputs. Nothing made any difference. Just as I had resigned to write off this AVR with a heavy heart, I came across this site:
http://www.avsforum.com/t/689793/help-yamaha-rx-v1500-avr-shuts-down-after-on-for-3-seconds
(Wish to deeply thank Daniel Campbell who has discovered this CPR remedy)
The solution given here has worked spot on for me. Like a new lease of life, almost a miraculous resurrection !! Do try it before sending your set for repairs or dumping it, hope it might work for you too.
Posted on Sep 16, 2013
Receiver shutdown
change your power regulator it is leaky and there are some diodes around the regulator change them also check the caps and some of the resistors some also can be faulty.good luck.
Jun 07, 2007 | Yamaha RX-V1500 Receiver
My RX-V1500 Yamaha receiver shuts-off after 3 seconds .
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Apr 12, 2011 | Yamaha RX-V1500 Receiver
(A) channel doesn't work and there is a hum in the subwoofer ???
Check ALL connections as this sounds like an open circuit. check cables to and from all units and speakers.
Jul 26, 2010 | Yamaha RX-V1500 Receiver
Yamaha RX-V1600 shuts down in seconds
Your Yamaha RX-V1600 has an audio output transistors are mounted to a large heat sink which keeps them cool during operation. They are electrically isolated from touching the heat sink by an electrical insulating washer. But, in order to keep them cool and allow for good thermal conductivity of the heat generated by the output transistors the washers are treated with a heat conducting grease. Over time this grease will dry out and lose its heat conductivity ability allowing the temperature of the transistors to rise; as the heat goes up they conduct more current and cause the protection system to activate and shut the set down (in order to avoid damage to the set).
You need to check or replace the transistor that's on the heat sink. Or you may contact a pro to replace it for you.
Mar 14, 2010 | Yamaha RX-V1500 Receiver
Same as above
Replace the filter capacitors of the power supply
Aug 28, 2009 | Yamaha RX-V1500 Receiver
Yamaha RX-V663 delays 10-30 seconds between commands using the remote control. New batteries, new receive. For example, try to raise volume. It goes up 1 dB then cannot give any other commands using the...
I have seen this type of thing with several remotes.  You have some light source in the room that is interfering with the reception of the ir.  Turn off all light sources in the room and then try.  You might be surprised!
Dec 20, 2008 | Yamaha RX-V663 Receiver
Yamaha rx-1500 av receiver
some times the speaker cables are touching, double check, I had this with my amp and it kept turning itself off
May 20, 2008 | Yamaha RX-V1500 Receiver
DirectTV HD-DVR & Yamaha RX-v1500
The types of remotes are as follows
- Single item, or fixed. This unit will only operate the unit it came with
- Multi function, this type can operate the unit it came with and a fixed set of other types. Normally the remote comes with a list of supported device it could work with.
- Learning, the combine both a predefined list with the ability to learn functions by sensing input from the original remote.
- Programable. These are the newest remotes that work like multifunction but the list is maintained by the manufacturer and down loadable from the web.
I would guess that the DVR has a multi function remote.
If you can't find the specific Yamaha in the list, then
try another brand, this could take a while.
Some multi function remotes have an option that allow a semi automatic configuration.
You turn on the item and then using a special key sequence try to turn off the device. once the item turns off you should be able to control it.
If you can't the Yamaha has a learning remote. If you really want an easy solution try looking at a programmable remote. I just got a Logitech, (Harrmony). Life has never been so easy.
Mar 08, 2008 | Yamaha RX-V1500 Receiver
No subwofer operation 2year old system
Some systems don't send signal to subwoofer if speakers in SPEAKERS SETUP are set to LARGE, they redirect signal to center and front speakers. Maybe that's problem.
Oct 07, 2007 | Yamaha RX-V1500 Receiver
Yamaha RX-V1500 Receiver Logo
2,160 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
robert landry
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
