Question about Sony KV-35S42 35" TV
Standby Indicator flashing SONY KD-32NX100UWhen I turn the TV on the TV goes straight into standby red light, I press the on button on the remote and the TV comes on for about twenty seconds then it switches of to standby and the standby red light flashes five times red and two seconds green continuously.
  • jokiex Dec 12, 2008
    I have the same problem with my Sony KV-35S42. Seems to have started when I began using a new Directv remote after programming it with Sony TV code 10000. I had also just setup a DTV receiver using the the TV's s-video input for the first time. Those maybe just coincidences, though.
  • Anonymous Apr 16, 2009
    same as above anybody know why?
  • Sony Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV '
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
What does standby mean? my tv will not come on but the red standby light is on. How can i fix my tv.My tv is an sony 40" trinitron wega brand.
If standby red light is solid then press power or channel button on remote of tv itself to turn it ON.
And if red light is blinking/ flashing then it is an indication that tv got problem and tech visit is needed to sort out problem.
Apr 20, 2011 | Sony Televison & Video
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
hello if the lamp cover is not mounted securely the self diagnostic function works and the power /standby indicator flashes 3 times when you've corrected it power/standby indicator goes out the tv enters standby mode
Oct 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link -
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
Dec 22, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
Sony KV-35S42 35" TV Logo
831 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
