Question about Samsung SV5000W VHS VCR
VCR Samsung SV-5000W
Doesn't take a power on, no any sign of life
  • Peter Romankevich Jan 04, 2007
    The main fuse not popped. What is the problem on the power supply in this unit, can I fix it myself?
    Thanks, Peter
    President:
  • 3,130 Answers
You should take off the top cover with the set unplugged and see if there is a main fuse that popped. If there is, put in another fuse,. If that blows, then your going to need to have the power supply in this unit repaired. Good Luck
Posted on Dec 28, 2006
My repairer for my SV-DVD3E needs a circuit diagram to complete the repair of my unit.
all diagrams can be found here on this full service manual
http://www.givemefile.net/smanuals/dsrvrc_players/samsung/sv-dvd3e.html
Please vote for me if you found this info useful
Mar 16, 2011 | Samsung SV-DVD3E DVD Player/VCR
When convert PAL-NTSC w/ SV-5000W to Samsung Plasma only B & W pic
Switch through the TV input selector until you find the proper input channel , probably you are using the wrong input.
Oct 28, 2008 | Samsung SV5000W VHS VCR
Samsung VCR SV-5000W Tracking Problem Symptom: I've used Maxell VCR Head Cleaner VP-100. Still having small white streaks across screen. I can apply small amount of pressure to bottom or top of VCR deck...
Your chassis ground is intermittant. Remove the VCR cover and look just behind the head drum. You will see two copper tangs sticking out, these supply the ground to the grey chassis and are a pressure fit. Remove the 7 screws from the grey chassis, two are underneath the VCR, two on top near the VHS tape opening, and three larger screws are on top of the chassis (2 near back and 1 near front). This will allow you to lift the grey chassis about a 1/2" and you can then reach below the copper tangs and gently pry them up. Reinstall the 7 screws and the VCR cover and the snow will disappear.
Nov 26, 2010 | Samsung SV5000W VHS VCR
Blinking white sparks during playback. My unit has this problem during playback, and I discovered that the SV-5000W has the same problem too ( see http://www.fixya.com/support/t151239-major_dropout ). At...
I looked at the link provided and there was no cure mentioned. From my experience with VCRs in general, I would suspect a flaw in the video pre-amp circuit used for playback. This could be distortion. Without seeing the actual unit and examining the signals on an oscilloscope, I can't be sure where the problem exists. It should be fixable however. Something as simple as a bad filter cap at the heads could cause this as well. The signal levels at the heads are extremely low. This unit requires test equipment that the homeowner is nit likely to posess. I would take this to a service shop.
Dan
Oct 11, 2010 | Samsung SV7000W VHS VCR
Samsung SV-5000W VCR. Voltage regulator?
This unit has a universal power supply that automatically detects proper voltage. No buttons or adjustments required, just plug her in.
Jan 04, 2009 | Samsung SV5000W VHS VCR
Cannot download.please send manual in english
You can download the user manual for Samsung SV-DVD440 here:
Samsung SV-DVD440 User Manual
To get the price of this player, you need to first mention your country.
Thank you
Oct 23, 2008 | Samsung SV-DVD440 DVD Player/VCR
Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
Aug 22, 2007 | Samsung SV5000W VHS VCR
Faintly blinking power light
This may indicate power supply problems, or perhaps an overload condition, causing the power supply to go into overload protection. If you have a voltmeter, schematic (helpful but not 100% necessary), you could check voltages. You should see at +5 volts, +12 volts, and one or two others. A frequent power supply problem is one or more electrolytic capacitors go wacky, and cause the voltages to be way off, and a non-operational unit. If this is one of the newer low cost rigs, then taking it to a service center isn't cost effective. Toss it and purchase a new one.
Mar 14, 2007 | Samsung SV5000W VHS VCR
Samsung SV5000W VHS VCR Logo
273 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
