Question about Jenn-Air 24 in. JDB1090AWS Stainless Steel Built-in Dishwasher
Jenn air dishwasher with black grease?? spots on bottom
We are getting what looks like motor grease on the bottom of out dishwashers sometimes. What could it be from. It also growls on some washes, and on others it operates fine. Any ideas?? Thanks
Vish2
  • 74 Answers
SOURCE: Noisy dishwasher
This is a known issue for GE dishwashers and may be similar for other models too.  The fix is simple.  The noise is due to vibration of the arm for the middle sprayer.  Just secure it with a tie wrap or wire and the noise should be gone.
Refer to the following link for my earlier response to a similar issue which fixed the problem.
http://www.fixya.com/support/t204050-ge_adorda_dishwasher
Posted on Oct 26, 2007
SOURCE: Jenn-Air dishwasher jdb1100aws problem
I had the same problem , needed a seal kit w/ alignment tool.
repair part # 99003341.
Posted on Mar 16, 2008
SOURCE: dishwasher issue
Have had this problem twice on my DWI614. First time engineer came out and I watched what he did and asked questions. He removed panel at bottom of dishwasher (2 screws) after removing facia panel from kitchen as it is a built in dishwasher. To the right is the drain pump. Remove 1 retaining screw and hose retaining clip. Ease out the drain pump and make sure to have some cloth beneath as residual water will flush out. Before I did this the second time I removed as much water from inside with a small cup first. Both times I had blockages in the drain pump. First was a piece of glass and second some food. I also pulled the drain pipe forward and blew through to make sure path to sink was clear. Clear out and reassemble. Start a simple program before putting the front back panel back on and you can touch the drain opump and feel it working as the water drains properly. That was my fix both times, good luck.
Posted on Jun 17, 2008
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: Jenn-air Dishwasher won't drain water from base
This happened to me after installation. they had installed a one way valve backwards in the drain line and had to reverse it.
Posted on Jan 03, 2009
Jenn-air dishwasher jdb1090aws wont drain
Most common issue on this model is the drain motor itself. More times then not it gets clogged with debris. Pull the unit out and remove the three screws that mount the pump to the bottom of the dw.
take the hoses off and clean the drain motor out. It will fix this issue I have seen it more times then you could imagine. Good luck with your repair friend
May 19, 2011 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
We have a dishwasher that has cleaned great for six or seven years but all of a sudden we have started seeing a white film on all of our black plastic utensils, like spoons and the such. Now some is on...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 13, 2011 | Jenn-Air JDB3610 Built-in Dishwasher
Won't drain
Look for the float.
It will be in the bottom somewhere. This is how your dishwasher knows it has water in it.
your float might be cracked or full of water (then it needs to be replaced. if you just want to drain the dishwasher in the short term, you can always prop up the float (but this will prevent the dishwasher from filling up again, because it will think it is still full...)
Or
sometimes it is an open bottom or air-trap type of float and it might just be filled up with grease and stuff.
Reach underneath with your finger (YUCK!) if you can, and scoop out the grease. Then it should work just fine.
Nov 24, 2010 | Amana ADB1600AW Builtin Dishwasher
Amana dishwasher won't drain
look for the float.
it will be in the bottom somewhere. This is how your dishwasher knows it has water in it.
Or sometimes it is an open bottom or air-trap type of float and it might just be filled up with grease and stuff.
Oct 20, 2009 | Amana 24 in. ADB1200AW Built-In Dishwasher
Does not get my dishes clean, leaving a film on my glasses, not getting food off. tried to take apart to clean but could not figure out how to get bottom filter out with the large water bracket going up...
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Oct 09, 2009 | Jenn-Air 24 in. JDB1100AW Built-in...
Maytag Quiet Series 300 smells broken door latch and lower rack
I have had the same problem and there is a simple fix.
The problem in my case was the floating water sensor was stuck and gummed up with grease.
On the bottom of the dishwasher, in the front right corner there is a round doughnut-looking thing. This is the water level sensor. It is open on the bottom, and grease collects there.
When this happens, the air pocket is too small, and the float won't float. then the dishwasher overflows. To clean it: just reach under with your finger, and scoop out the grease.
Sometimes, after doing this, the float then gets stuck in the "up" position. When this happens, the dishwasher completely drains, and the heater element for the dishwasher is exposed, and food cooks onto it, and that is where the smell is coming from.
Sep 05, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Won't drain
look for the float.
Apr 13, 2009 | Dishwashers
Leaking
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Mar 20, 2009 | Jenn-Air JDB4000AWS Stainless Steel...
I hate to sound like a broken record. But look for my vinegar and CLR fix. In my experience in most cases that works.
Thanks
Kashif. A
Mar 07, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Jenn-Air 24 in. JDB1090AWS Stainless Steel Built-in Dishwasher Logo
385 people viewed this question
Top Jenn-Air Dishwashers Experts
Marvin
Marvin
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
