Question about Apple LaserWriter 12/640 PS Plus Printer
12/640 Laserwriter - driver needed.
Hi.
I can not print when I need the driver for my printer 12/640 Laserwriter, can some help please?
I need in for vista.
Thanks.
  • Ricky Ostrom
    Ricky Ostrom May 11, 2010
    I know this printer is already listed in Windows XP, but I'm not sure about Vista.
I had the same problem when I got a new computer with Vista. I just went through the available 600 DPI printer drivers until I found one that worked ok with the 12/640 printer. The driver I used was the Samsung 6000 PS. I have had no problems with it.
Posted on Mar 12, 2009
  • 685 Answers
Http://www.printcountry.com/drivers/APPLE_DRIVERS.asp
Posted on Nov 19, 2008
Apple Laserwriter 8500 paper light out, when there is paper in the cassette. Not blinking. Solid yellow.
make sure the usb lead connection is secure
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X
this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Oct 06, 2011 | Apple LaserWriter 8500 Printer
12/640 PS wont feed from tray
I found the owners manual for your model, and it has detailed explanations of how to turn off the printing of the Startup page: This is where the owners manual is available online in .pdf format, at this URL: http://download.info.apple.com/Apple_Support_Area/Manuals/printers/0340211ALW12640UM.PDF Startup Page Info From your Owners Manual: (Yes, I've been reading the Manual for your printer. I have no life. :P ) From page 25 of the manual: "The printer takes a minute or two to warm up, and then it automatically prints a startup page. It prints the startup page every time you restart unless you turn the startup page off using either the Apple Printer Utility for the Mac OS or the Apple LaserWriter Utility for Windows. See Appendix A for details on these utilities." From page 249 of the manual: "Appendix A - Setting the Printer Default Settings" "Though the printer itself has no control panel, you can configure it by using programs on computers connected to the printer: - On Mac OS?based computers, use the Apple Printer Utility and the desktop printer?s setup function." So the answer is YES, you CAN setup the printer to not print the test page, but you have to use the setup utility on your computer to do so. Opening the Apple Printer Utility (From page 251) "The Apple Printer Utility has two windows: the Printer Selector window, which is similar to the Chooser, and the printer features window, which you use to view or change the printer?s settings." 1. Double-click the Apple Printer Utility. - The Installer puts the Apple Printer Utility in the Apple LaserWriter Software folder. You can move it wherever you like. 2. In the Printer Selector window, select and open the printer you want. - If the network has zones, click the zone where the printer is located. - Click the name of the printer you want. 3. Click Open Printer. - The printer feature window appears with the Printer Information category displayed. 4. To view or change settings under a category, click the arrow beside the category name to open the category and display its information and options. - Additional options may appear that you can also open and work with. When you are finished changing options in a particular category, you can click the arrow again to collapse the options. (NOTE: The option you want is "Startup Page".) 5. After viewing the information and making changes, click the Send button to send your changes to the printer. 6. Click the Close box to close the window. Turning the startup page on or off (From page 257) "The LaserWriter 12/640 PS normally prints a sample page when you turn the printer on. This page shows the printer?s name, the total number of pages printed, the amount of memory, installed options, and communication settings. You can turn this feature off if you wish. 1. Open the Startup Page category. - The Startup Page panel appears. 2. Click the checkbox to turn the startup page on or off. - When an X appears in the checkbox, the printer is set to print the startup page. 3. Click Send to send the startup page setting to the printer. That should remove the default printing of your startup page. HOWEVER, there is another possibility to affect a repair to your problem... As the paper-feed rollers get older, the rubber on the rollers gets slick and won't grip the paper anymore. Try buffing the rubber rollers with some fine sandpaper and see if that allows the machine to pick the paper up once again. If this is your problem, then you might make the lower-feed paper tray work again. Hope this helps, but let us know if you need more information to solve this problem. ;)
Aug 07, 2007 | Apple LaserWriter 12/640 PS Plus Printer
Laserwriter 8500 prints splotches all over the page.
Toner bubbles are characterized by large blotches of color toner on
printed pages caused by color toner leaking from cartridges directly
onto the transfer drum.
Solve the problem of toner bubbles by checking the manufacturing
codes on the toner cartridges and replacing cartridges as needed. Compatible carts are notoroius for this so don't use them.
Heat-stamped on the toner cartridge, opposite the label-end of the
cartridge, is a manufacturing code. If a portion of the code does not
match the list below, replace the toner cartridge.
Use toner cartridges that contain any of the following manufacturing
codes:
 9I
 9J
 9K
 9L
 and any cartridge that begins with the numbers 0 through 6 in place of
the 9
Jun 08, 2009 | Apple LaserWriter 8500 Printer
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Drivers for a C3200 Oki laser printer to go with an Apple MacBook
Do a google search, there are 3rd party drivers that work all sorts of old and odd stuff, the Oki sounds mainstream, the term is GIMP driver I think
Feb 01, 2009 | Apple LaserWriter 300 Printer
Laserwriter 8500 "dirty" print outs
onto the transfer drum. Solve the problem of toner bubbles by checking the manufacturing codes on the toner cartridges and replacing cartridges as needed. Compatible carts are notorious for this so don't use them.
codes:
 9I
 9J
 9K
 9L
the 9
Oct 09, 2008 | Apple LaserWriter 8500 Printer
Error 6911
You'll have to use google.com to translate this because I don't speak Spanish, but I used it to translate your text into English.
What you're seeing is PostScript being output to a non-PostScript printer. Mac OS 9 LaserWriter driver prints only PostScript. Make sure you've downloaded the correct driver from HP, and then make sure you're selecting the HP driver in the Chooser.
Please let me know if this information helps or not.
Jul 16, 2008 | HP LaserJet 1300 Printer
Laserwriter 12/640 PS
hello the printer paper pick-up rollers are bad. this why you caanotuse the pick tray. the solution now is to set the printer to default and clear allstuff off memory. read the instruction below: LaserWriter 12/640 PS: IBM PC or Compatible Troubleshooting This article explains IBM PC or Compatible Troubleshooting. A message on the screen says the printer can't print. If you get such a message, try the following steps. Make sure that the printer is turned on. Check the network or parallel cables. Make sure that the PostScript printer driver has been installed. Nothing is printed; no paper comes out of the printer. If you don't get any response from the printer when you try to print a document, try the following steps: Check the Installed Printers list to see that your printer is selected. Try printing the document again, but choose Download PostScript Error Handling in the Printer Setup PostScript Options dialog box. Check the Paper Out light. If it is on, add paper and replace the paper cassette. If it is blinking, make sure the paper cassette is securely in place. Check for a paper jam. Check the printer cables. Check the position of the port communication switch. The port may have been turned off or the Interpreter settings may not be correct. Reset the communications settings to their factory default values by setting the communication switch to the Reset (out) position. Turn the printer off and back on again. Set the communication switch to the Normal (in) position. Turn the printer off and back on. Check the startup page. Reinstall the printer driver. For Windows 95 users, check the following additional item: Open the Printer folder, select the printer, and click Properties. click the PostScript tab and click the Advanced button. Make sure that ASCII data and "Send CTRL+D after job" are selected. For Windows 3.1 users, check the following additional item: Open the Printer Control panel, select the printer, and choose Setup. Select the PostScript tab in the Properties dialog box. Make sure that Protocol Options is set to Default if using the parallel port, or None if printing via NetWare. Sometimes Printing the First Page Takes Longer than I Expect The LaserWriter 12/640 PS automatically goes into an energy-saving mode after it's been idle for a while. When you print while it's in this mode, the printer takes about a minute to warm up before it can print the first page. The printer is properly connected and configured, but printing is garbled or displays unwanted characters. Check the communication switch and make sure that the Interpreter is set to the correct value. If you are printing a PostScript document, the Interpreter mode should be PostScript or AutoSelect.
Aug 08, 2007 | Apple LaserWriter 12/640 PS Plus Printer
Apple LaserWriter 12/640 PS Plus Printer Logo
1,235 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Don  Farrell
Don Farrell
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
