Printer is not printing off the computer. All plugs are OK.
  • 4 more comments
  • morganclouds Nov 20, 2008
    Th Hppsc 1350 is not printing from the computer. I have unplugged & re-plugged it the next day, but ir still won't print. It prints from the scanner but not from the computer.
    Many thanks,
    Sylvia
    It is USB. It was an 'all of a sudden' issue. I am not sure how to do a self-print. I am a novice and don't know all the terms.
    I have made a self-testreport according to the HPpsc reference guide. Is that what you mean.
    Many thanks,
    Sylvia
    Thank you for your help. I have discovered that my printer was set at @ 'send to onenote'. It is printing since I have adjusted it to the printer,
    Many thanks once again,
    Sylvia
  • whai2karanga Dec 24, 2008
    I push printer and nothing happens.
    Push 'File - Print - OK - and then this appears - 'Windows needs more disk space to print this document'.
    I have turned it off - plugged un plugged & re plugged cords.
    go onto Microsoft help.
    Just a novice so please guide me through this.
    Pirihira
  • comment
    comment May 11, 2010
    The following questions were part of the clarification request, and were not answered. Can you please provide this information as well.
    How is the printer connected to the computer. USB ? Parallel ? Serial ?
    Was this an "all of a sudden" issue?
    Regards,
  • comment
    Will the printer do a self-test print? How is the printer connected to the computer. Was this an "all of a sudden" issue?
    Scholar:
  • 78 Answers
I'm happy that you were able to resolve the issue..
Best Regards..
Posted on Nov 20, 2008
Printer not printing from computer, copies OK no error signal just does not print. computer Toshiba laptop Satelitte
Turn printer off and then unplug it. Reboot computer. Plug in printer and turn it on. Go to printers, and see if it shows as default. Try printing a test page. Good luck.
Feb 22, 2017 | Toshiba Office Equipment & Supplies
Part way thro a print the printer stops, ejects the paper then starts to print symbols on new page i then have to switch off when i switch back on again it prints the whole page ok
Suspect communication error. Try different cable between computer and printer.
Try alternative computer.
After telling computer to print avoid any other activity on computer.
Make sure printer and computer are powered on the same receptacle with ground plug.
Dec 07, 2015 | Office Equipment & Supplies
I just connected a new printer. I installed the cable from the computer to the printer and plug in the cord for the printer. When I try to print there is a sign that says there is no communication with...
You did not mention installing the Kodak printer driver.
If you have not don so then install the printer driver and then do a test print.
If the test print prints OK then your printer is ready to work.
Mar 03, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
I bought a new cartridge for my printer and it still won't print...I just had my computer fixed for virvses..could that be the problem
No, that should not affect the printer, but I would suggest reinstalling your drivers for the printer. And make sure your cables are nice and snug and plugged in properly. Sometimes it doesn't work if a cable is loose. Also, try to print something without using the computer. Does your printer have a scanner? If it does, you can copy something and print it out, that will let you know the printer is ok and it could be a driver problem on the computer. And when you go to print make sure that printer is the one selected to print, because sometimes there is more than one printer option. Hope this helps. Cheers.
Oct 02, 2009 | Lexmark C533DN InkJet Printer
HP deskjet 1120c printer does not print -light blinks
ok try to add a printer in your computer select local port and it should be USB and the USB cable should be plugged in the computer and select the brand to be HP and the model to be 990c click on next till the FINISH appears and after that the printer will print from the computer
Feb 23, 2009 | HP Deskjet 1120c InkJet Printer
How do i uninstall the lexmark z53 printer from my computer and re install it.
Start Registry Editor. To do this, click Start, click Run, type regedit in the Open box, and then click OK. Locate and expand the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86View the list of subkeys. There should only be the following subkeys: • Drivers • Print Processors
in the delete any subkeys listed other than drivers and print processors
Locate and then expand the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\MonitorsView the list of subkeys. There should only be the following subkeys for the default print monitors: • BJ Language Monitor • Local Port • PJL Language Monitor • Standard TCP/IP Port • USB Monitor if there are others listed aside from the ones above delete it
then try adding back your lexmark
Jul 24, 2008 | Computers & Internet
Hp photosmart 1215 printer will not print on my new acer computer. It works fine on my old computer.
Resolution1:
For WinXP:
1. Click Start>>Run & type msiexec /unreg then Press OK.
2. Click on Start>>Run & type msiexec regserver Press OK.
3. Unplug & Re-Plug the printer & try to print.
Jul 21, 2008 | Acer Computers & Internet
Not printing
ok...unplug from computer...shut down printer...turn printer back on after 3 min, then plug back into computer. should see the printer and then just do a test page.
Jun 20, 2008 | HP Photosmart C3150 Printer
HP photosmart C7280 will not print. it is correctly plugged in and the computer screen is saying ready to rpint, but it will not print at all
Hit * and # at the same time on your printer
Enter code: 123
Hit Right Arrow
Go to System Configuration
Hit OK
OK again
and OK a third time
Unplug power from printer
Unplug power from wall
Wait 2 minutes
Replug the printer
It should boot fine and be able to print again.
May 22, 2008 | HP Office Equipment & Supplies
BJC 4550
chech if the ink cartrades are plugged in tight in they are check if all the chords are plugged in if that doesnt work go to a tech man or get a new printer
Jul 08, 2007 | Canon BubbleJet i550 InkJet Printer
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
