Question about Samsung SCX-4720FN All-In-One Laser Printer
PCL6 ERROR - sb_count ! = -128
Error when I print to SCX-4720FN , Position : 0x3x8b (15499); System : XLPGP/xl_pattern; Line : 890; Version : PCL6 3.59
  • 2 more comments
  • FrankieFX Dec 05, 2008
    Hi everyone, I also have the same problem. When I print a PPT file, the print out as the following message.
    PCL ERROR - sb_count != -128
    POSITION : 0x3c28 (15400)
    SYSTEM : XLPGP / xL_pattern
    LINE: 890
    VERSION : PCL6 3.61 11-13-2007
  • amfp413 Apr 07, 2009
    My Xerox wc 4118 have same problem.
    POSITION : 0x1bf66 (114534)
    LINE: 890
    VERSION : PCL6 3.59 02-12-2007
  • Anonymous Apr 15, 2009
    I have the same problem with a Ricoh BP20N
  • Anonymous Apr 24, 2009
    Tengo el mismo problema
Two differents internal error
The cable could be Faulty replace it with a new or known to be working fine .
Jun 25, 2015 | Samsung SCX 4200 All-In-One Laser Printer
PCL 6 ERROR - Undefined XL code Posistion: 0x0 (0) System: ../XLPGP/xl_pa Line: 821 Version: PCL6 5.75 24-04-2008
I Had the same problem from my Windows 7 pc's only,
i loaded the printer on an XP OS and Shared it and it solved the problem.
Apr 26, 2011 | Samsung Office Equipment & Supplies
I keep trying to simply print to this printer via usb and I get this error, the printer then goes into offline mode. I can scan to the computer, so the connection must be fine. What's the deal smee? The...
There could be few reasons for this. One of then is the Printer Spooler that much be corrupted and another would be the actual printer printing drivers
Click on START button and Click on Run
Type the word CMD ( or COMMAND ) and hit enter key
You will find a new black window on screen.
Execute the following commands,
net start spooler ( hit enter key )
net stop spooler ( hit enter key )
follow the same Start and stop command for 4-5 times. End the Command with NET START SPOOLER ( hit enter key )
Disconnect the Printer USB Cable and re-connect.
It should start printing.
Dec 07, 2010 | Samsung SCX-4720FN All-In-One Laser...
Spl-c error- Incomplete session by time out Position : 0xf807 (63495) System : src/os_hook Line : 1646 Version : SPL-C 5.35 11-20-2007
Hi
you need to replace motherboard
the cost of it is to high
you better replace your printer
Pls vote us to keep us alive
Nov 25, 2010 | Samsung SCX-4720FN All-In-One Laser...
Printing error
I had the same error message printed with the same printer. I solved my problem by printing my PDF document with another program.
Jul 03, 2010 | Samsung SCX 4521F All-In-One Laser Printer
"Internal error - false" when printing on Samsung SCX-4200
Good day Sir, These are the possible causes why your machine print the wrong text.
Problem: The machine prints, but the text is wrong, garbled, or incomplete.
  • The printer cable is loose or defective.
  • the wrong printer driver was selected.
  • The software application is malfunctioning.
  • The operating system is malfunctioning.
Have a nice day!
Oct 25, 2009 | Samsung ML 1710 Laser Printer
Internal error
We received a similar problem on ours:
Internal Error - False
Position: 0x268f3b (2527035)
System: H6FW/xl_image
Line: 476
Version: QPDL 1.22 12-02-2003
We would also like to know exactly how to fix this problem as it doesn't seem to work at all now!
Dec 28, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-4720FN All-In-One Laser Printer Logo
3,389 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
