Question about Toshiba Satellite A205-S4617 Notebook
Dual boot problem
I have been trying to install XP on a formatted hard disk which has Vista on it already. I always get this error when installing the XP: Setup did not find any hard disk drive s installed in your computer. Can you please help me solve this problem....Thanks.........
Here's a great tutorial regarding that
my question is did you create partition on your disk? or your using a secondary drive? if not read the tutorial
Posted on Nov 19, 2008
  • 849 Answers
Xp can not recognized the sata hard drive u have to install sata drivers before installing xp.
Upgrading windows vista to windows xp in presario 115DX
You cannot 'upgrade' Windows Vista to Windows XP - that is technically a 'downgrade' and would need you to save all your user data on Vista then format you Windows drive then do a clean install of Windows XP.
If you try to install XP over the top of Vista you will have lots of problems because of the difference in architecture and boot manager changes.
The only alternative would be to set up a dual-boot installation where you install XP alongside Vista but would be best done on either a separate disk partition or on a second disk. Normally such a dual-boot configuration would start with having XP installed then adding Vista as the second operating system.
Jan 11, 2012 | Compaq Presario CQ56-115DX Laptop
How to install xp on this unit from vista
You have to format the hard disk before you can insall XP on a Vista machine, or you can try to install a dual boot system. Go to Microsoft.com and search for dual boot system help
Jan 29, 2010 | Computers & Internet
While installing xp showing error
Hi Friend
Try this may help you in creating a dual boot.
First find the drivers for your network components, wireless card or nic, and save them to an external device such as a floppy disk or flash drive.
Then you will need to go into the BIOS on your computer startup. Scroll to the System Configuration tab and go down to the SATA Native Support and change its setting to Disabled. Then hit F10 to Save and Exit. (You don't need to change the BIOS if you have an ATA or IDE hard drive.)
Next, insert your Windows XPmag-glass_10x10.gif CD and create the partition you wish to install XP on. After the installation is complete you should boot automatically into XP. (To do this, right click the Computer icon in start, and select manage. Then select Disk Management, and you can do whatever you want with your partition.)
Now you need to move some files. First, make sure you have set your folder options to see hidden files and to show protected operating systemmag-glass_10x10.gif files. Then open Windows Explorer and go to the drive where Vista is installed. Copy the folder Boot, and the files bootmgr, boot.ini, NTDETECT.COM and ntldr and paste them to the root of your XP drive.
Then download Vista Boot Pro and save it to your desktop or somewhere else that you can easily access. Unless you already have .Net Framework (v2.0 at least) it will redirect you to a Microsoft page where you can download this necessary component.
Install and run Vista Boot Pro and open the "Bootloader" tab. Select "Reinstall the Vista bootloader" and press Apply. Then go to the Manage OS Entries tab and select "Add new operating system entry" and make sure you select "Windows Legacy". Give the new entry a name (ie: Windows XP) and select the drive letter you have XP on and then select Apply. You can also choose which entry you would like as the default the system will boot to.
And now you should be able to dual boot between Vista and a previous OS.
I hope this will help you out. Please vote for me.
Oct 06, 2009 | Compaq Presario Notebook
Error Loading Operating System
the two operating systems are not compatible. I assume that you are trying to rollback to XP on the computer. The problem is to remove the Vista o/s and install XP.
Oct 05, 2009 | Computers & Internet
How to uninstall Windows Vista
You must use a full retail or OEM version of XP (not the cd from your old computer) this makes life really easy and can usually be downloaded from the web.
You must also have a genuine XP key, which has not been used on another system.
Next you should know or find out the specifications of your system, to do this goto Manufactures website.
The most important step is to find out if your hardisk is using SATA interface (if so you will require the SATA XP drivers and a floppy disk, as this is the only way that XP can install these drivers.)
Install XP via cd rom by booting cdrom at system start (if you cannot do this then you must access your system bios at first boot by pressing F2 or Del keys(or whatever key your system uses) and change the boot option to cdrom as first drive.
If your system uses SATA press F6 when XP prompts “press F6 to install other” at very beginng of XP install and install sata drivers from floppy.
Jun 12, 2009 | Microsoft Windows Vista Home Premium SP1...
I'm using win2k pro sp5 can i do a vista upgrade?
How to dual boot Vista and XP (with Vista installed first) -- the step-by-step guide with screenshots
UPDATED | Got a Vista PC and want to install XP so you can dual-boot between them? Here's how to do it, in an easy, step-by-step format. Page 1 - Intro
Scenario: You want to install Vista on your PC alongside your XP installation, on the same drive. You have installed Vista already. (If you have XP installed first, check out our earlier tutorial on how to dual boot Vista and XP with XP installed first.)
Tutorial Summary: We need to shrink the Vista partition on the hard disk and create enough space for an installation of XP. This can be done in three ways - using the GPartEd Live CD, the DISKPART utility on the Vista DVD or the Vista Disk Management GUI - and we'll cover all three. We'll then install XP and install EasyBCD to reinstate the Vista bootloader which will be overwritten during the XP installation, and then use EasyBCD to configure Vista's bootloader to boot the XP partition.
Updated September 2008: This is an updated tutorial, based on our first Windows Vista/XP dual-booting workshop. The main differences are that we are now using Windows Vista SP1 and Windows XP SP3. EasyBCD has also been updated and this makes some of the steps in our first tutorial redundant - the whole process is now easier.
This tutorial has been tested on a VMWare 6 Workstation.
VISIT THIS FOR THE COMPLETE TUTORIAL :
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
Mar 16, 2009 | Microsoft Windows Vista Ultimate Edition
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
How to install XP in toshiba Satellite L45-S7423 laptop
I found it!!!>>>
Just go to Toshiba support web site Download the Storage Manager Driver for XP 32 then have an External floppy drive with formatted Disk ,install the drivers Files in the floppy connect the floppy drive put the XP sys CD Boot from the CD as in Solution #1 or by press on F12 tell choices boot screen popup select the CD then after that when the third party appear press F6 to chose the Driver for HDD to get recognized by the system. J
Mar 27, 2008 | Computers & Internet
Install xp pro
windows xp cannot be installed on a system with pre loaded vista . because the boot loader of xp is older than vista as it cannot create boot loader . the order of installing operating systems is from LOWER 2 HIGHER ie XP to VISTA . first of all u nedd to format drive containing vista and then try installing xp
Dec 14, 2007 | Creative Labs Sound Blaster Live! 24-bit...
Toshiba Satellite A205-S4617 Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
