Question about Kitchen Ranges
MY CANNON CAMBERLEY main oven is not working at all. No Gas, no ignition, hobs are okay, clock is blank.
  • Anonymous Nov 30, 2008
    Today our cannon lichfiled oven seams to have same problem, hobs and grill are fine but oven flame is very low. Has it had it??
  • AandMB Dec 18, 2008
    We have the same problem. Hobs and top oven/grill working fine, but main oven has no gas and no ignition. We had the same problem before and it was a problem with the clock/timer settings. Unfortunately, my tenant appears to have taken the manual when she moved out last month. If anyone would be kind enough to relay us instructions on setting the clock/timer, we would be very grateful. Our oven has 5 buttons associated with the clock, from left to right: 'minute minder', 'cook period', 'end time' '+' and '-'.
You need to press the cook period button. You'll see a counter that says 0.00. Press the + (or - button if you have gone too far) to set the time you want the oven to stay on for. When the timer runs out, it will beep with the alarm, and at the same time cut off the gas supply to the oven.
Annoying, but a good safety feature. I normally put 3 hours on to make sure it stays on for the full length I am cooking for.
How do I get my grill working???? Its how I found your question. The dial won't even turn in that direction, and I am sure there is a similar safety device in place. Might be the same one. Will try (just typing helps me think).
Posted on Feb 02, 2009
When i turn on the main oven it lights up but the flame does not get bigger to the setting on the dial,it just stays on small flame all the time.
Posted on Jun 28, 2009
My cannon duo cooker was working one day then next day the clock doesn't work, the ignition wont work theres no gas coming through to lite oven manually whats the problem the rings work perfectly
Gas ovens invariably have a safety thermocouple to cut the gas off automatically if the flame goes out, due to an interruption in the supply for instance. The thermocouple must be temporarily over-ridden for the purpose of lighting the burner and pilot and often the override is mechanical but considering the clock and ignition has stopped working it would be reasonable to assume your oven has an electrical or electronic thermocouple override.
It would seem either the mains supply to your cooker has failed or the internal power supply has a problem. With such a sophisticated oven, even if you had been able to light it manually, it is possible the temperature control wouldn't have worked.
Mar 26, 2016 | Cannon Kitchen Ranges
Cannon double oven
The quality of new stuff is not as good at the old, but they are shiny and clean to start with.
With the upper burners, they have just a standard gas igniter, but you say there is no gas. This can only be cause by two things, but most likely a blocked jet for some reason. The only other reason is a faulty control.
The grill is the same, some share igniters, some have one for each of the three department, hobs, grill, ovens.
So your choice is buy a new one or get a service engineer in. It is gas, so you shouldn't really work on this on your own for safety reasons.
Feb 02, 2018 | Ovens
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
Cannon camberley double oven the lower oven will not work and no gas is coming through to it but the top oven works fine can u help. Thanks Steve
Just got one today and have the same problem. Have read on here you need to set the clock to turn on the gas. Now i just need to figure how to set the clock.....
Nov 25, 2009 | Ovens
Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Jun 01, 2009 | Ovens
No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
May 07, 2009 | Ovens
Oven Ignition Keeps Clicking
it is the spark generator at back of cooker they are about £65
Mar 16, 2009 | Cannon Chesterfield C60G Kitchen Range
Gas in main oven
hello, i have looked into the problem and have come up with a fix for mine at least. take out all the trays, and peer into the rear. you will see a silver section which has three srcews. remove the centre one to get access to the burner which has the white igniter on it. this just slips sideways and off. with the aid of a small mirror you should see a small brass nut where the gas comes from. there is a small pinhole in the centre,mine was slightly blocked and this reduced the flow of gas. i cleaned this with a pin and the gas flow improved. i am not an expert and take no responsibilty if it goes wrong. it appears to have worked for me so the choice is yours.
regards. flask
Dec 19, 2008 | Cannon Chesterfield C60G Kitchen Range
MY CANNON CAMBERLEY DOUBLE OVEN HAS HAD A REPLACEMENT FSD BUT IS STILL NOT WORKING PROPERLY.
Nov 04, 2008 | Kitchen Ranges
Cannon Camberley 10305G (Double Oven)
trust you have set the clock as this turns the gas supply on to the ovens
Dec 19, 2007 | GE Profile JGS968 Gas Kitchen Range
Kitchen Ranges Logo
1,220 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
